18.10.2010, 22:15 #1
- 18.10.2010
- 74
- 14
FT-857, 897 и автоматические тюнеры
Кто нибудь пробовал стыковать FT-857, 897 с внешними автоматическими тюнерами других производителей Icom AH-4, Alinco EDX-2, WAT-500 и т.д.
18.10.2010, 23:35 #2
- 22.02.2007
- Симферополь, Крым
- 55
- 517
- 90
- 27
Из ныневыпускающихся тюнеров от LDG
AT-897Plus заточен под FT-897
* Microprocessor controlled
* 2000 fast memories arranged by frequency
* Switched L tuning network
* Mounts on the side of the Yaesu FT-897 with four M3-0.5x10 screws (included)
* Dual function tune control button
* Continuous coverage 1.8 to 54 MHz
* Power rating HF: 0.1 to 100 Watts
* Latching Relays
* CAT control at 4800 baud with extra CAT Port
* Tuning time: 1 to 7 seconds, 4 average
* Antenna impedance: 6 to 800 Ohms (Approximately up to 10:1 SWR, 3:1 on 6M)
* Tunes nearly any coax fed antenna. Use optional Balun for long wires.
* Power requirements: 11 to 14 volts DC @ 300 milliamps during tune
* Operating voltage supplied via the CAT Port (cable supplied with tuner)
* Enclosure sizes: 11.5D x 3.25H x 1.5W (measured in inches)
* Weight: 2 pounds
YT-100 для FT-857.
* RF Power: 1 to 100 watts SSB, CW and digital modes.
* Latching relays for ultra low power consumption
* Built-in CAT interface for FT-100(D), 857(D) and 897(D) radios.* Powered from Yaesu radio over CAT port.
* CAT thru port for computer control of radio. 4800 baud.
* 2000 memories sorted by frequency.
* 1.8 to 54 MHz coverage (continuous coverage for MARS)
* Tunes 4 to 800 ohms. (16 to 150 on 6M)
* SO-239 in and out connections for dipoles, verticals, beams, G5RV, OCF, Cobra, ect.
* Dimensions: 7.0”L, 7.0”W, 2.0”H. Weight: 20 ounces
* Includes 1 foot CAT interface cable and 1 foot coax jumper.73, Владимир R6KV ex UU3JC
19.10.2010, 20:17 #3
- 15.01.2003
- Novokuibyshevsk
- 1,084
- 134
- 47
FT-857D + LDG Z-100.
Постоянно в экспедициях таскаю с собой. Z-100 настраивает всё в РАЗУМНЫХ пределах. Всегда размещаю его около антенны.RW4HM, Павел
19.10.2010, 20:34 #4
- 18.10.2010
- 74
- 14
Спасибо за ответы. У меня есть LDG Z-100 и я его использую, и еще есть WAT-500 для кенвуда, у него больший предел согласований и он герметичный, вот его я хотел бы стыковать с FT-857.
RA6UL
19.10.2010, 21:23 #5
- 13.01.2003
- Жабомишодраківка
- 13,850
- 3914
- 1415
YAESU FC 20 = VSWR до 1:7
-73- Игорь
25.10.2010, 20:49 #6
- 18.10.2010
- 74
- 14
А как управляете тюнером?
RA6UL
25.10.2010, 20:50 #7
- 13.01.2003
- Жабомишодраківка
- 13,850
- 3914
- 1415
Через соответствующий хвост .
-73- Игорь
26.10.2010, 03:34 #8
- 17.02.2009
- Темрюк
- 69
- 53
- 17
Имею автоматический тюнер MFJ-993 B, прекрасно работает со всеми трансиверами. через соответствующий кабель управляется, как FT 857. IC 7200. TS 430. Одним словом прекрасный тюнер. рекомендую!!!
Геннадий (RK6BDT)
25.04.2011, 22:09 #9
- 19.01.2011
- OM-24
- 922
- 319
- 298
Какой тюнер предпочесть для FT-857 из: YT-100, Z-100 Plus, Z-11 ProII? И почему?
Сергей
25.04.2011, 23:11 #10
- 24.04.2008
- 55
- 2,393
- 234
- 132
Тот который удовлетворяет Ваши требования.
Потому что удовлетворяет.
Они по смыслу/качеству/надежности.... все одинаковы. Но чем то, да отличаются.
Просто выбирать надо под конкретные задачи. А есть еще 200 и 600. А вдруг усилитель купите?
А может Вам лучше 897? Автомат с САТ. Вы опишите чего хотите. А то писать про их отличия долго... Тогда бы и посоветовать было б проще.Игорь (RN3AHT)
Разрешение имеется.
25.04.2011, 23:46 #11
- 19.01.2011
- OM-24
- 922
- 319
- 298
Вот уже 3 дня как есть 857 .
Тюнер нужен в основном для выездов, для работы на "компромиссные" антенны. Ну и дома, если без РА. Если с РА, предполагаю согласовывать трансивер с РА с помощью самодельного ручного тюнера.
Ну вот, как-то так, если кратко...Сергей
25.04.2011, 23:56 #12
- 24.04.2008
- 55
- 2,393
- 234
- 132
http://www.cheapham.com/products/LDG-Z%252d11ProII.html
http://www.cheapham.com/products/LDG-YT%252d100.html
http://www.cheapham.com/products/LDG-Z%252d100Plus.html
или
http://www.ldgelectronics.com/c/252/products/1/49/3
http://www.ldgelectronics.com/c/252/products/1/9/1
http://www.ldgelectronics.com/c/252/products/1/52/1
Кратко и образно.
z100-базовая модель. один вход, один выход. питание. управление. одна кнопка. нажали, трансивер включил несущую, тюнер настроился. или нажали тангенту, тюнер подстроится. или найдет в памяти...
z11- тоже самое, но можете в ручную менять емкость и индуктивность наблюдая за ксв метром трансивера. есть возможность записать в память свои настройки. и выбора мин ксв при котором прекращается авто настройка...
y100- питается от сат. работает через сат. или кнопкой. полный автомат(в смысле нет возможности вмешаться. а автоматы они все), ничего делать не надо...
но. отличаются они только кнопками. база одна. весь выбор, в том что именно нужно. не хотите автомат... хотите полностью ручной 100про... и тд...
Добавлено через 1 минуту
позравлям!
Вы полазьте по ссылкам... выберите под то как им пользоваться хотите...
они отличаются как копейка, двойка, треха, шестерка...пятерка...семерка...Последний раз редактировалось RN3AHT/WWW; 25.04.2011 в 23:58. Причина: Добавлено сообщение
Игорь (RN3AHT)
Разрешение имеется.
26.04.2011, 21:54 #13
- 15.01.2003
- Novokuibyshevsk
- 1,084
- 134
- 47
Значит тюнер нужно ставить около антенны.
У меня Z-100 запихан в пластиковую коробку и имеет соответствующие выводы(управление на DB-9, PL-259 in и out, клемники для out).
Есть к нему два куска 50 ом кабеля по 14 метров и два кабеля управления по 14 метров. Возможно последовательное включение , общая длинна от трансивера до тюнера 28 метров или раздельное включение для разных антенных систем.
Постарайтесь обходится без тюнеров около трансивера, лучше настроить антенную систему.
Кстати,это и к походным вариантам относится.RW4HM, Павел
27.04.2011, 00:50 #14
- 19.01.2011
- OM-24
- 922
- 319
- 298
То, что выполняемые функции почти одинаковы, это понятно. Интересует - в чем различие по управлению. В Z-100 и Z-11 имеется выход 3,5мм Radio. Если я правильно понимаю, он соединяется с разъемом АСС трансивера. При нажатии на кнопку Tune на тюнере, с тюнера по этому кабельку закорачивается на землю контакт разъема АСС "Запрос передачи", трансивер начинает передавать несущую, тюнер настраивается. А выходная мощность при этом уменьшается автоматически или ее уменьшает трансивер, как следствие большого КСВ? Это один вопрос.
Вот здесь можно поподробнее? Механизм хотелось бы понять... У YT-100 на заднице 3 разъема - Computer, Radio и Remote. Тоже хотелось бы поподробнее узнать о назначении каждого, что вкусного у этого тюнера появляется дополнительно по отношению к двум предыдущим.
А в каких случаях возле трансивера?
Согласен, только не всегда возможность есть...Сергей
27.04.2011, 01:35 #15
