07.03.2007, 23:58 #16
- 27.12.2006
- 51
- 204
- 546
- 4
А кто в Москве делал апгрейд 7800? - не знаю, к кому обратиться
15.03.2007, 19:47 #17
- 21.11.2002
- 2,285
- 260
- 228
Ну вот и удалось воткнуть узкий руфинг в про 3 без особенных извращений.
Возможно, до сих пор обделенных руфингами обладателей про3 скоро ждет хорошая новость.
С другой стороны никто не мешает их уже сейчас слезно пинать и просить поделится схемой и фотками. Фильтры есть в наличии уже давно.
Из инрадовского мейл листа:
Thought I'd forward this e-mail to the group. George, W2VJN and I had modified my Icom Pro2 for an INRAD roofing filter. We started off putting the filter further downstream and ended up in it's present location. The after results are phenomenal and quite visible on the rigs pan adapter. Wide band noise is suppressed and signals are very visible. The modification is not that hard for a technically inclined person and is certainly worth the effort. The RF board does need a trace cut and a couple of miniature coaxial cables soldered onto it. George found a spot in the rig to mount the board and filter. It is activated by "Dual watch" and rotating the balance control fully CCW. If both receivers are set to the same frequency and dual watch is activated the balance control can be rotated CCW for narrow band and CW for wide ban receiving. Recently I read an article about the Pro series of Icom rigs and how wonderful the DSP worked in relation to crystal filtering. I beg to disagree with the author of this article. DSP isn't the only cure for intermod. The IF strings still perform a lot better when the signal to be amplified is narrow. 73's
Charlie W5VIN
-------- Original Message --------
Subject: Re: IMPRESSIVE
Date: Wed, 14 Mar 2007 19:55:18 -0700
To: Charlie Mazoch Jr. <w5vin@earthlink.net>
References: <45F8B1C5.2070008@earthlink.net>
Charlie,
Thanks for the comments. That wide band noise you see is intermod from all
the strong signals. I never measured the isolation. The point I cut is a
low impedance, so there is not much trouble there. You can see from the
curve that there is adequate isolation.
George
To: "George Cutsogeorge" <w2vjn@rosenet.net>
Sent: Wednesday, March 14, 2007 7:39 PM
Subject: IMPRESSIVE
> Hi George:
> I took some time this evening to listen to an extremely noisy band with
> the Icom Pro2. One has to be in "Dual Watch" and the balance control CCW
> to receive through the roofing filter. I set both VFO's to the same
> frequency and rotated the balance control right or left while in dual
> watch. On tonight's noisy 75 meter band the results of the INRAD roofing
> filter were very impressive. Watching the pan adapter while rotating the
> balance control from one receive path to the other I noticed the broad
> band noise displayed between signals was much less with the roofing filter
> inline. There is definitely a visual indication of the receivers
> improvement. Very, very impressive. Putting the roofing filter right after
> the 1st mixer certainly gets rid of a lot of broad band noise being
> amplified and IMD generated in the RF amplifier after the receive
> combiner. Smart thinking. Thanks and 73's
> Charlie W5VIN
> PS: What sort of isolation were you getting after cutting the circuit
> trace where you tied in? According to the literature you didn't cut it in
> two places and ground the center trace.
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.11/721 - Release Date: 3/13/2007 4:51 PM
_______________________________________________
INRAD mailing list provided as a service by International Radio
INRAD Web Site: http://www.qth.com/inrad
To Submit Message to the List: list@inrad.net
List Help:
http://mail.inrad.net/mailman/listinfo/list_inrad.netLife's too short for QRP!
73, Артур VE3EUT, EW1CK
15.03.2007, 22:45 #18Сообщение от EW1CK
2.Фильтр более узкий и имеет большие потери которые нужно компенсировать скореее всего дополнительным каскадом усиления?
3.Igor.Blinov@t-helper.ru
Я попробую узнать по ним информацию.
И потом сообщу вам.
4.Поделитесь где достали, фотками и поделимся позже.
15.03.2007, 23:49 #19
- 21.11.2002
- 2,285
- 260
- 228
Сообщение от RK9FBO
http://www.qth.com/inrad/vhf-filters.htm
Сообщение от RK9FBO
Сообщение от RK9FBOПоследний раз редактировалось VE3EUT; 15.03.2007 в 23:53.
16.03.2007, 00:26 #20
- 21.01.2006
- Магдебург, Германия
- 194
Performance enhancemant- "kit" для 775, 6-ти кристальный фильтр с
усилителем на 2 транзисторах,монтажная мелочь - 175 зеленых.
Попроще -http.....VHF Filters-там только фильтр за 125 баксов.
Кстати - купил "руфинг" для МК5,упаковка и счет инрадовские,а на
коробке фильтра: Made in Japan ?!
16.03.2007, 01:42 #21
- 21.11.2002
- 2,285
- 260
- 228
Сообщение от DJ4MBLife's too short for QRP!
16.03.2007, 21:16 #22
- 18.05.2003
- Sillamae
- 76
- 11,750
- 3761
- 2086
Сообщение от EW1CK
Так, возможно или ждет, или фантазии?Владимир
https://www.qrz.com/db/ES4RZ
16.03.2007, 21:35 #23
- 21.11.2002
- 2,285
- 260
- 228
Сообщение от ES4RZ
С другой стороны, я не знаю, дойдет ли дело до коммерческого продукта. Может да, а может нет
Но вывод я могу сделать следующий:
1. существует решение по установке руфинга которое работает
2. не нужно извращаться с планарным монтажом
3. существует ненулевая вероятность выпросить схему у авторов
А это значит что вполне возможно сделать руфинг своими силами на основе инрадовского фильтра уже сейчас, т.е. до того как они начнут его продавать в виде мода.Последний раз редактировалось VE3EUT; 16.03.2007 в 21:37.
16.03.2007, 22:16 #24
- 18.05.2003
- Sillamae
- 76
- 11,750
- 3761
- 2086
Спасибо! Постараюсь на неделе послушать у знакомого ФТ-2000 с разными руфингами.
Владимир
05.04.2007, 22:12 #25Сообщение от ES4RZ
Сделаем конфетку из PRO-III
06.04.2007, 00:09 #26
- 24.11.2005
- Поле в лесу
- 3,365
- 1754
- 577
Сообщение от RA3CO73! Павел RU3DNN .... HAM-ANIMALS
