Показано с 1 по 2 из 2
    15.09.2003
    43
    Вопрос Други, может быть есть у кого дамп EEPROM 24C32 от YAESU VX-1R?
    Что-то в родном слетело и р-станция вообще не включалась.
    Я "обэFFил" содержимое программатором - заработала игрушка, но SQL неуправляем... шипит, зараза. Видимо, коэффициэнт какой-то в еепромке хранится и софтом недоступный.
    15.09.2003
    43
    Нашел "секрет"!!!
    http://mywpages.comcast.net/sllewd/squelch.htm
    Here's how to reprogram the squelch and "S" meter settings
    1. Press & hold the VOL+FW+MON buttons down together and power up the radio
    Display should now show HSSQ 03 (also important: there must be a 3 in the top of the display. If
    anything but 3 appears at the top of the display, Press BAND button until the 3 appears)
    2. Press the UP Button to display HASQ **
    3. Turn the dial until the display shows HASQ 08 (Auto Squelch Hystersis)
    4. Press the UP button to display THSQ **
    5. Turn the dial until the display shows THSQ 4F (Squelch Preset Threshold)
    6. Press the UP button to display TISQ **
    7. Turn the dial until the display shows TISQ 2F (Squelch Preset Tight)
    8. Press the UP button 2 times to display S1LV **
    9. Turn the dial until the display shows S1LV 34 (Low Scale S1 Adjust)
    10. Press the UP button to display S9LV **
    11. Turn the dial until the display shows S9LV A3 (Full Scale S9 Adjust)
    12. Press the UP button to display HSSQ 03 (Squelch Hystersis, Adjusted by Dial)
    13. Press the BAND button 3 times until the display shows HSSQ 06 (note: after pressing BAND button 3 times, there
    should be a 6 in the small top display)
    14. Press the UP button to display HASQ **
    15. Turn the dial until the display shows HASQ 08 (???)
    16. Press the UP button to display THSQ **
    17. Turn the dial until the display shows THSQ 4D (Squelch Preset Threshold)
    18. Press the UP button to display TISQ **
    19. Turn the dial until the display shows TISQ 30 (Squelch Preset Tight)
    20. Press the UP button 2 times until the display shows S1LV **
    21. Turn the dial until the display shows S1LV 27 (Low Scale S1 Adjust)
    22. Press the UP button to display S9LV **
    23. Turn the dial until the display shows S9LV 96 (Full Scale S9 Adjust)
    Press the FW button for 0.5 seconds to store these settings into memory
    ** Could represent any number - depending on how scrambled your VX-1R's memory is.
  1. Глюки FT-1000MP, что может быть ?
    от UA9KAA в разделе FT-1000
    Ответов: 16
    Последнее сообщение: 02.02.2010, 15:40
  2. Разве такое может быть?
    от serg101010 в разделе Телефонная, сотовая связь
    Последнее сообщение: 23.08.2003, 09:27
  3. Может быть кто-то использует или пытался...
    от в разделе Цифровые виды радиосвязи
    Последнее сообщение: 09.03.2002, 18:32
  4. Уважаемые господа, может быть кто-то из ...
    от в разделе Радиолюбительские технологии
    Последнее сообщение: 01.01.2002, 03:22
