Показано с 1 по 15 из 30
    Silent Key Аватар для UA3IRS
    03.04.2002
    Химки, Московская обл.
    5,372
    Записей в дневнике
    8
    910
    1393
    Post Трансивер YAESU FTM-10R
    Новый трансивер с функциями cтерео-сканера + bluetooth + 500 memories с alpha tags + часы/календарь + WIRES + Line in. + DTMF + CTCSS & DCS + 9K6 packet ready + Twin RX
    1) http://www.rigpix.com/yaesu/ftm10r.htm
    2) http://blog.big-dutch.com/?p=41
    Кто видел или юзал его?
    ПРИМ:
    # Wide Band Receive, including AM broadcast, WFM radio, air, weather.
    # Angle Sub Panel (Detachable Front Panel?)
    # Bluetooth Capability
    # 50 watt output VHF, 40 watts on UHF
    # Vox (usefully for optional Bluetooth Headset)
    # Stereo Reception
    # Dual Receive (FM Radio & HAM Band, or any combination)
    # Clock & Calendar
    # EPCS (Enhanced Paging & Code Squelch) Operation
    # Alpha Memory Tags
    # WIRES Ready
    # Line-IN (for MP3 player)
    # Public Address/Horn Alert Operation
    Optional Accessories
    DTMF Microphone MH-68A6J
    Normal Microphone MH-68B6J
    Panel Separation Kit YSK-M10
    Bluetooth Head Set BH-1
    Bluetooth Adapter Unit BU-1
    Head Set Charger Sleeve CAB-1
    Microphone Jack MEK-M10
    Ear Phone for BH-1 FEP-4
    High-Power External Speaker MLS-200-M10
    AC Power Supply (25 A) FP-1025A
    AC Power Supply (30 A) FP-1030A
    Yaesu FTM-10R dual bander operates on 2 m and 70 cm. High power output is featured with 50 wt on 2 m 40 wt on 430 MHz.
    Three power levels are available for 2M/440: 50/40, 20/20 and 5/5 wt.
    Very extended receive includes: 0.5-1.8,76-108, 108-137, 137-174, 174-222, 300-420, 420-470, 470-800 MHz and 800-999 MHz (less USA Cellular Blocked).
    Requires +13.8 VDC at 8.5 amps. 5 x 1.8 x 7 inches (112 x 38 x 178 mm).
    Yaesu FTM-10RS compact version (main body and front panel may be separated) is 10 wt on 2 m and 7 wt on 440 MHz.
    Последний раз редактировалось UA3IRS; 09.05.2007 в 06:58.
    [SIZE=1][FONT=Verdana]73. Сергей ([B]UA3IRS[/B] aka [B]UR3IRS[/B]) :ru: :: OnLine: [url=facetime://ur3irs@gmail.com]FaceTime[/url], [url=callto://ur3irs]Skype[/url], [url=xmpp://ur3irs@gmail.com]Jabber[/url] :: Web: [url=twitter.com/ur3irs/]Twitter[/url], [url]aprs.ru[/url], [url]echolink.ru[/url], [url=https://www.flickr.com/photos/ur3irs/sets/]Flickr[/url], [url]ur7iwz.qrz.ru[/url][/FONT][/SIZE]
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    Новое фото с немецкой выставки 2007 года
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    А начал-ли продаваться этот трансивер в Москве или нет ещё?
    Радиолюбитель Аватар для RN9AAA
    30.10.2002
    49
    2,093
    285
    59
    Да начал еще летом.
    bluetooth -опция (без BU-1 неработает)
    тангента -опция (в комплекте нет т.к. микрофон уже вставлен в панель)
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    Цитата Сообщение от RN9AAA Посмотреть сообщение
    Да начал еще летом
    И что? Кто и где покупал? Цена какая?
    Отзывы о работе этого трансивера есть какие хорошие или плохие?
    О! Это интересно! Можно об этом поподробнее плиз...
    Последний раз редактировалось UA3IRS; 14.10.2007 в 08:51.
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    Заметки увлечённого человека
    Yaesu затеяла интересную шармань — автомобильную УКВ-радиостанцию FTM-10R. Интересна она в двух плоскостях:
    Первая — внешний вид. На мой взгляд, получилось необычно и достаточно красиво (FYI: дисплей нарисованный). Только несколько портит впечатление «малокнопочноть». Ведь радиостанции Yaesu традиционно не так просты в управлении, как хотелось бы. В «малокнопочных» станциях, а в особенности, если речь идет об использовании в автомобиле, этот момент решает.
    Вторая — возможности, ставшие известными из предварительных данных:
    1) Приём вещательных станций в диапазонах СВ (да, да, средние волны), УКВ и FM (названия последних двух идиотские по сути, но что поделать, прижились в России). Фича не критичная для меня, но её полезность очевидна;
    2) Двойной приём. Полагаю, что это опечатка и имелся ввиду Dual watch, чем можно удивить только туземца;
    3) И самое многообещающее — Bluetooth ready. Похоже, что речь идет о возможности подключения внешнего Bluetooth-модуля для работы с беспроводной гарнитурой (лучше бы конечно еще и с тангентой).
    Потом, явно завялен Tone Split. Наконец-то до Yaesu допёрло, что эта функция достойна отдельного подзаголовка в инструкции.
    Вот если бы они сделали пропуск частот для режима VFO (как это сделано в VX-6R/VX-7R), то было бы вообще круто. Но в предварительной инструкции по эксплуатации об этом ничего не сказано, и я так понимаю, вероятность того, что этого режима не будет, крайне велика. Увы и ах.
    Но, тем не менее, затея выглядит интересной. Будем посмотреть.
    Источик: http://aptem.ru/2007/03/17/1/comments от 17.03.2007
    Последний раз редактировалось UA3IRS; 14.10.2007 в 09:11.
    30.10.2002
    49
    2,093
    285
    59
    Ничего
    например http://yaesu.ru/, точнее http://www.yaesu.ru/tovar_yaeftm-10.php
    450 у.е.
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    А интересно, cross-band режим у этого трансивера есть или нет?
    30.10.2002
    49
    2,093
    285
    59
    Нет. Трансивер позиционируется для активного использования в авто, мото-технике (особенно для последнего оправданно такое исполнение).
    Цена явно завышена.
    Для домашнего применения вполне подойдет тот же FT-7800.
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    Цена явно завышена.
    Ну не особо, я бы сказал, и завышена... Гм...
    Вот если сравнивать с KENWOOD от Беромоса, то там ситуация следующая (по новым интересным моделям подобного класса):
    1) TM-V71 (цена в USA=$399, в МСК=$520)
    2) TM-D710 (цена в USA=$599, в МСК=$800)
    Вот такие вот интересные цифры получаются.
    Последний раз редактировалось UA3IRS; 14.10.2007 в 09:24.
    30.10.2002
    49
    2,093
    285
    59
    А вы не сравнивайте совсем с другими производителями.
    Cравните с тем же функционалом FT-7800 325 у.е.
    Ну а если уж сравнивать то приплюсуйте к цене FTM-10 Тангенту DTMF Microphone MH-68A6J Normal Microphone MH-68B6J или модуль Bluetooth Adapter Unit BU-1 + BT Гарнитуру.
    Ведь не будете же вы в панельку кричать.
  12. #12
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    А вы не сравнивайте совсем с другими производителями / сравните с тем же функционалом FT7800 325 у.е. / Ну а если уж сравнивать то приплюсуйте к цене FTM-10 Тангенту DTMF Microphone MH-68A6J Normal Microphone MH-68B6J или модуль Bluetooth Adapter Unit BU-1 + BT Гарнитуру / Ведь не будите же вы в панельку кричать.
    Гм... Ну если так рассуждать, то смею заметить, что ваши размышления весьма и весьма убедительны... Пока от комментариев воздерживаюсь...
    А что можете сказать о наличии в этом трансивере режима - 9K6 packet ready ?
    Последний раз редактировалось UA3IRS; 14.10.2007 в 09:46.
  13. #13
    30.10.2002
    49
    2,093
    285
    59
    Ничего. Советую скачать инструкцию и почитать самостоятельно
    http://www.thiecom.de/ftp/yaesu/ftm1...ing-manual.pdf (4,7 MB)
  14. #14
    03.04.2002
    5,372
    Записей в дневнике
    8
    910
    1393
    1) Спасибо за ссылку.
    2) Скачал. Просмотрел, но ничего (никаких упоминаний) про '9K6 packet ready' в данном трансивере не обнаружил. 8((
    Последний раз редактировалось UA3IRS; 14.10.2007 в 10:17.
  15. #15
    Радиолюбитель
    09.07.2008
    Нижний Новгород
    Доброго всем времени суток!
    Не так давно стал обладателем станции FTM-10R, автомобильная версия 50 Ватт мощность, ещё есть мотоциклетная, 10 Ватт, но она меня не интересовала.
    Выбор был в принципе осознанным, осознанным мною, человеком в радио любительстве являющимся полным 0-ём.
    до этого в принципе обращался с 130 алинкой, Yaesu ft-60R (В которой полностью разочаровался), Yaesu 1802.
    Всё началось с того как я решил подарить отцу Мартышку, он всегда хотел, ну купил я ему FT-60R мы её тестили вместе с ним 2 дня, не поймали ни одногол канала, даже с хорошей внешней антенной, с которой Алинка 130 ловит всё что только возможно. В общем чувствительность оказалась дубовой. Поехал я её менять, аналогов небыло, пришлось взять 1802, не плохой аппарат, удобный быстро настраивается, не плохая чувствительность. И в общем то в поисках и тестирование всего этого я решил исполнить свою давнюю мечту, я купил себе станцию, меня интересовала 2-ух диапазонная, с большим количеством функция, в общем то FTM 10 была очень кстати. Конечно в последствии функция блютуз разочаровала, т.к. её в принцыпе то в станции и нет. Но в общем то это не огорчило меня в целом. Начал тестировать, имея в арсенале 2 антенны 144 и 430 МГц, в общем то чувствительность на высоте. Настроился на репитер, задал субтон, и связался с отцом, т.к. у меня позывного нет я просто поговорил в эфир он послушал и дал комментарии, в общем на высоте.
    Очень понравилась функция прослушивания 2-ух каналов, 1 приоритетный, второй постоянный, тоесть слушаю я грубо говоря радио, а на другой частоте таксист начал говорить, рация гасит радио и переходит на таксиста. В общем интересно. Очень удобная в управлении, по началу испугало отсутствие механического SQL и регулировки громкости, но очень быстро привык. В общем доволен.
    Т.к. я пока позывного не имею, в эфир не суюсь, а так бы установил связь с кем нибуть
    А вообще таксистов слушаю, уж больно приятный голос у операторши.
    Большая просьба, очень надо русскую инструкцию, дайте кто имеет, т.к. с английским я хоть и дружусь, но многие термины для меня не знакомы, и очень тяжело разобраться с аппаратом, т.к. функций много.
    Спасибо!
  1. FT-857: трансивер от YAESU
    от Andry RV4PHU в разделе FT-857
    Ответов: 23
    Последнее сообщение: 12.03.2011, 18:26
  2. Трансивер РВП-94
    от RK9AKP в разделе КВ техника
    Ответов: 10
    Последнее сообщение: 21.02.2010, 11:00
  3. КВ-трансивер
    от VADSOL в разделе КВ техника
    Ответов: 55
    Последнее сообщение: 11.04.2006, 06:42
  4. Трансивер YAESU FT-101
    от RADIO2005 в разделе Военное радио: снова в эфире
    Ответов: 12
    Последнее сообщение: 21.11.2005, 18:10
  5. Трансивер Луч
    от Alessandro в разделе Радиолюбительский форум QRZ.RU
    Последнее сообщение: 01.11.2005, 16:29
Метки этой темы
Яндекс.Метрика
