19.05.2017, 16:48 #1
Новые SDR от FlexRadio (6600 и 6600M)
FLEX-6500 A Real SDR for Every Operator
Both the FLEX-6600™ and FLEX-6600M™ offer the ultimate performance direct sampling SDR technology and the best value for the serious HF/6m operator. The FLEX-6600 model is designed for the Ham who wants to operate the radio exclusively as a server from PC, laptop, Maestro, Mac, or iOS clients – whether local or remote. Both models share the same game changing band awareness, industry leading phase noise performance/ receiver dynamic range, and brick wall filters to give you the advantage in the most competitive DXing or contesting activities while maximizing your fun in casual operations. With a PC, laptop, or Mac client, you can utilize up to four 14 MHz spectrum/waterfall displays and independent band/ mode receivers to revolutionize your view of the bands, especially on digital modes.
Contest grade filters, ultra low spurious emissions, and the ability to operate full duplex cross band on two antennas let you transmit on one band while receiving on another – no external equipment required. Even switch to synchronous diversity reception when needed to help you pick out the weak ones in the midst of QRM. By adding FlexRadio’s new PowerGenius XL LDMOS solid state amplifier a complete legal limit, all mode SO2R station is now practical with one radio, one amp and only three interconnect cables – half the cost and none of the complexity.
The FLEX-6600M places the most used controls right at your fingertips. Controls are labeled for intuitive operation and designed to minimize hand motion for the most common operations. Occasionally used controls are easily accessible on the large touch screen display bypassing the complexity of multi-function buttons and multi-level menus found on other transceivers. Like modern smartphones and tablets, capacitive touch control is provided on the large LCD display for intuitive pan, zoom, tune, and menu operation. The FLEX-6600M controls are designed to provide maximum tempo in the most demanding applications including SO2R, Run, S&P, and Multi-op contesting.
Подробнее ...73! de RW3AH
19.05.2017, 17:56 #2
29.05.2019, 17:21 #3
- 03.02.2014
- 1,254
- 825
- 1692
Вопрос по FLEX-6400. Как отключить QSK ? Прочитал их форум, там ничего толкового нет. Из-за включенного QSK не работает правильно PTT. Работаю через winkeyer, и PTT включается при первой посылке сигнала без задержек. Delay во FLEX работает только на отключение PTT.
Сергей
29.05.2019, 17:57 #4
- 19.09.2012
- Киев
- 223
- 142
- 98
29.05.2019, 19:52 #5
29.05.2019, 20:49 #6
- 07.03.2010
- 1,740
- 1066
- 115
Павел, VA6AM ex VA6LBI, UN7LG, UL7LG, UL7LBI, UL7-026-495
[URL="https://va6am.com/"]Мой сайт[/URL]
29.05.2019, 22:19 #7
29.05.2019, 22:41 #8
- 26.09.2007
- 3,816
- 5451
- 1461
Если говорить точнее, то РТТ в телеграфе не работает вообще, а только brake-in с задержкой, и задержкой именно на выключение.
Это один из «сюрпризов»))
Обычное ключевание через DTR-RTS не запустить, только winkey.
Зато вы теперь в высшей касте !
А какой геморой вас ждёт при настройке DAX, и говорилки из контест-лога, ммммм, это просто чистый оргазм длинною в вечность))Последний раз редактировалось RX3APM; 29.05.2019 в 22:45.
30.05.2019, 00:38 #9
- 03.02.2014
- 1,254
- 825
- 1692
Да, Сергей, именно это и получилось.. Из логгера CW нет, запускаешь Winkey, PTT уже с логгера не работает. PTT срабатывает при первой посылке CW, что конечно очень плохо. Хорошо что реле в PA стоят вакуумные быстродействующие. Папа Женя сказал, проверить раз точку не сьедает в позывном первую, значит работать можно..
До DAX еще не дошел, но уже понял, что пару 590-х SG всё равно оставить надо бы.. Там кроме DAX, еще "вылезло" : при подборе на одном диапазоне, в FLEXе реле щелкать начинает и окно вылетает, что-то с переусилением и перегрузом входа, я так понял, в тесте некогда было разбираться.
P.S. В крайнем случае, свой скиммер не помешает...Сергей
30.05.2019, 08:08 #10
- 23.01.2009
- Харьков
- 1,689
- 1075
- 582
В свое время для меня это было решающим фактором для отказа от 6х00 серии Флексов.
Как вариант. У него на задней панели есть вход для "клоподава" и педали? Спаять переходник от СОМ порта в эти входы. Тогда можно обойти winkey и задержку PTT->CW устанавливать, как обычно, в логе. Правда, не знаю, можно ли при этом сохранить работу обычным ключом?
Это переполнение АЦП и Флекс начинает автоматически подключать аттенюаторы. Попробуйте вручную включить эти же аттенюаторы, чтобы предупредить появление этого окна. Посмотрите на S-метре Флекса, с каким уровнем Вы принимаете соседнюю станцию?
30.05.2019, 09:00 #11
- 19.09.2012
- Киев
- 223
- 142
- 98
30.05.2019, 09:09 #12
- 19.09.2012
- Киев
- 223
- 142
- 98
30.05.2019, 09:22 #13
- 23.01.2009
- Харьков
- 1,689
- 1075
- 582
Во всех известных мне логах есть задержка PTT->CW для прямого ключевания через СОМ порт. winkey есть не везде, если его наличие является необходимым условием, выбираем лог, где он есть.
Но, если уж трансивер работает через winkey, то задержка PTT ON->CW, как и CW->PTT OFF должна устанавливаться в нем, а не в логе. Это неправильно, когда PTT устанавливает одна программа, а CW ключевание производит другая.Последний раз редактировалось UT4LW; 30.05.2019 в 09:26.
30.05.2019, 09:36 #14
- 19.09.2012
- Киев
- 223
- 142
- 98
Согласен. Но выше я привел два скрина о настройках РТТ различных задержек во флексе. Регулировка delay дает переключение из режима QSK (0мс) to BK-in. Да, индикатор QSK при этом не гаснет.
Думаю смысл настройки задержки РТТ по второму скрину понятен.
PS: К стати ранее писал, что при локальной работе добивание позывного работает без проблем, а была проблема при ремоуте. Так вот, попробовал при ремоуте заменить N1MM на win-test. В последней и при ремоуте работает все отлично ( добивание). Выходит, что то не так на программировали программисты N1MM.Последний раз редактировалось UR5MID; 30.05.2019 в 09:42.
Сергей UR5MID
30.05.2019, 11:18 #15
