Показано с 1 по 7 из 7
    Standart Power Аватар для RX3AOE
    04.08.2006
    Москва, Россия
    390
    27
    25
    APRS клиент: PocketPacket
    PocketPacket is an APRS client for your iPhone/iPod Touch. The "Automatic Position Reporting System" is a packet communication protocol used by amateur radio operators (HAMs) around the world, to report position, status, station capabilities, weather or other information in real time.
    PocketPacket incorporates a software-based TNC, allowing you to directly capture and visualize 1200 baud packets (AFSK modulation) using a VHF radio transceiver. With PocketPacket you can also get and send packets over the Internet, by selecting one of the available Tier 2 servers of the global APRS-IS network.
    Incoming data is presented on a map, as most packets define some object, with a specific symbol and location. By selecting a symbol, you can view the latest information sent for the corresponding object, as well as the raw packets that produced it. All available objects are also shown in a list, which allows you to search for the ones you are looking for.
    With PocketPacket you can follow the status of the APRS network or submit your station's info from anywhere. Monitor moving objects, get real time weather reports directly from local stations and more. Now, with an iPhone/iPod Touch and PocketPacket, you can have a full-fledged picture of packet activity in a small, portable package - ideal for field work or the ham shack.
    Смысл в том, что можно напрямую подключить к любому радио, без TNC, и принимать 1200 бод APRS пакеты.
    Silent Key Аватар для UA3IRS
    03.04.2002
    Химки, Московская обл.
    5,371
    Записей в дневнике
    8
    920
    1393
    Кстати вот ссылки на программу APRS-клиент PocketPacket (автор: SV1OAN):
    1) Для iOS: ссылка
    2) Для Mac OS X: ссылка
    3) Сайт автора: http://koomasi.com/pocketpacket/
    Цена программы: 4.99$
    Последний раз редактировалось UA3IRS; 30.05.2014 в 09:06.
    [SIZE=1][FONT=Verdana]73. Сергей ([B]UA3IRS[/B] aka [B]UR3IRS[/B]) :ru: :: OnLine: [url=facetime://ur3irs@gmail.com]FaceTime[/url], [url=callto://ur3irs]Skype[/url], [url=xmpp://ur3irs@gmail.com]Jabber[/url] :: Web: [url=twitter.com/ur3irs/]Twitter[/url], [url]aprs.ru[/url], [url]echolink.ru[/url], [url=https://www.flickr.com/photos/ur3irs/sets/]Flickr[/url], [url]ur7iwz.qrz.ru[/url][/FONT][/SIZE]
    03.04.2002
    5,371
    Записей в дневнике
    8
    920
    1393
    Обновилась версия этого клиента под Mac OS X.
    Текущая версия [Mac OS X]: 1.4.2 (68)
    Текущая версия [iOS]: 1.4.1
    Изображения Изображения
    Последний раз редактировалось UA3IRS; 12.11.2011 в 09:29.
    03.04.2002
    5,371
    Записей в дневнике
    8
    920
    1393
    Сегодня написал письмо автору программы и попросил его, чтобы он добавил в программу для Mac OS X следующие возможности:
    1) При получении Message пакета от корреспондента, программа должна сообщать ему пакетом, что его сообщение получено, иначе корреспондент посылает много лишних одинаковых сообщений (пакетов) не получая при этом подтверждения. Это не есть хорошо.
    2) При получении Message нужно сделать так, чтобы программа сигнализировала пользователю об этом звуковым сигналом, на иконке программы должно высвечиваться количество принятых сообщений и иконка программы должна подпрыгивать.
    Ответ был получен сегодня от SV1OAN и он пообещал это добавить в следующей версии PocketPacket.
    03.04.2002
    5,371
    Записей в дневнике
    8
    920
    1393
    11.10.2013 PocketPacket для iOS обновился до v.2.0
    Что нового в v 2.0:
    - Redesigned interface to support iPhone 5 and iOS 7.
    - Background operation.
    - Map shows moving objects' tracks.
    - Option for bigger map annotations.
    - Updated APRS-IS server list.
    - Bug fixes.
    Последний раз редактировалось UA3IRS; 13.10.2013 в 08:16.
    03.04.2002
    5,371
    Записей в дневнике
    8
    920
    1393
    29.05.2014 PocketPacket для iOS обновился до v.2.1
    Что нового в v 2.1:
    - Offline map support
    - Configurable VOX trigger
    - Message acknowledgements
    - Local and push notifications for received messages
    - Unread message count indicator
    - Updated APRS-IS Tier 2 Network server list
    - Bug fixes
    03.04.2002
    5,371
    Записей в дневнике
    8
    920
    1393
    07.07.2014 PocketPacket для iOS обновился до v.2.2
    Что нового в v 2.2:
    - Secondary map screen on Apple TV
    - Option to show distance to object
    - Bug fixes
  1. U2APRS: APRS клиент
    от UA3IRS в разделе Android
    Ответов: 12
    Последнее сообщение: 03.09.2013, 16:09
  2. APRS клиент: Ham Tracker (iOS)
    от UA3IRS в разделе iOS
    Последнее сообщение: 01.04.2012, 09:00
  3. APRS клиент: PinPoint (Windows)
    от UA3IRS в разделе Win-XP/7
    Последнее сообщение: 12.03.2011, 20:52
  4. APRS-клиент на JAVA
    от UA3IRS в разделе Java
    Последнее сообщение: 01.11.2006, 07:43
Метки этой темы
