В меню Tools нужно выбрать Repeat Loop. Там и длинна паузы устанавливается.
Кстати вышла новая версия программы сегодня.
Hi all.
After a bit longer time than usual, version 2.3.10 is finally released.
There are a lot of fixes included in it as well as some new features.
Some of them are noted in release notes and also in this email.
New antenna server application is now supported, we work on compatibility
support for few
devices there (currently K1LZ and MOAS II by K1XM is supported). Need more
testing on this,
so this isn't shipped with this version yet.
The team is now more focused on new multiplatform edition v3, so hope to
start
beta testing very soon. But more on that in separate topic, when it will be
ready.
Enjoy.
73,
Chris - 9A5K
Ver 2.3.10
- When visible in log lines, operator name and frequency wasn't refreshed
until scrolling wasn't activated. Fixed. (TNX G4IRN, 9A3OS)
- Some fixes added when ESM mode is used in combination with SHIFT binding
to opposite radio and RST hidden. (TNX LZ5VK)
- New language available: Norwegian. (TNX LB3RE)
- IARU 2m contest added as new contest. (TNX M0CKE)
- EUHFC and SCC RTTY Contest - Cabrillo output adjusted according to the
current rules. (TNX S57AW)
- New contest supported: RSGB International DX contest. (TNX M0CKE, EI3JE)
- Alt + space - grabs last known callsign from digi decoder window if
exists. Otherwise, works as before, grabs call from partner window. (TNX
K3JO)
- $OTRSP=x macro implemented. Send custom commands to OTRSP device. (TNX
K3JO)
- ARI DX contest config changed to new rules. (TNX IK2NCJ)
- When contest with periods was active, radio 2 entry line period wasn't
updated correctly. Fixed.
- QSO editing, problem with qso editing, when dupe qso existing in the log
after edit qso. Multiplier wasn't updated correctly. Fixed. (TNX IU3AZC)
- UBA PSK63 config adjusted to new rules.
- NAQP/NASprint config changed for new rules. (TNX W9PA)
