Страница 23 из 74 ПерваяПервая ... 131617181920212223242526272829303373 ... ПоследняяПоследняя
Показано с 331 по 345 из 1096
Like Tree241Спасибо
Тема: DXLog
  1. #331
    High Power Аватар для RW9OW
    19.03.2012
    Новосибирск
    55
    902
    883
    572
    В меню Tools нужно выбрать Repeat Loop. Там и длинна паузы устанавливается.
    Кстати вышла новая версия программы сегодня.
    Hi all.
    After a bit longer time than usual, version 2.3.10 is finally released.
    There are a lot of fixes included in it as well as some new features.
    Some of them are noted in release notes and also in this email.
    New antenna server application is now supported, we work on compatibility
    support for few
    devices there (currently K1LZ and MOAS II by K1XM is supported). Need more
    testing on this,
    so this isn't shipped with this version yet.
    The team is now more focused on new multiplatform edition v3, so hope to
    start
    beta testing very soon. But more on that in separate topic, when it will be
    ready.
    Enjoy.
    73,
    Chris - 9A5K
    Ver 2.3.10
    - When visible in log lines, operator name and frequency wasn't refreshed
    until scrolling wasn't activated. Fixed. (TNX G4IRN, 9A3OS)
    - Some fixes added when ESM mode is used in combination with SHIFT binding
    to opposite radio and RST hidden. (TNX LZ5VK)
    - New language available: Norwegian. (TNX LB3RE)
    - IARU 2m contest added as new contest. (TNX M0CKE)
    - EUHFC and SCC RTTY Contest - Cabrillo output adjusted according to the
    current rules. (TNX S57AW)
    - New contest supported: RSGB International DX contest. (TNX M0CKE, EI3JE)
    - Alt + space - grabs last known callsign from digi decoder window if
    exists. Otherwise, works as before, grabs call from partner window. (TNX
    K3JO)
    - $OTRSP=x macro implemented. Send custom commands to OTRSP device. (TNX
    K3JO)
    - ARI DX contest config changed to new rules. (TNX IK2NCJ)
    - When contest with periods was active, radio 2 entry line period wasn't
    updated correctly. Fixed.
    - QSO editing, problem with qso editing, when dupe qso existing in the log
    after edit qso. Multiplier wasn't updated correctly. Fixed. (TNX IU3AZC)
    - UBA PSK63 config adjusted to new rules.
    - NAQP/NASprint config changed for new rules. (TNX W9PA)
  2. #332
    Very High Power Аватар для R9IR
    13.08.2010
    Томск
    1,113
    1181
    517
    Цитата Сообщение от RT0R Посмотреть сообщение
    Приветствую !!
    Подскажите, AUTO CQ негде не нашёл.
    Команда с клавиатуры
    RPT
    отменить:
    NORPT
    Начало передачи после определенного знака
    CWAUTO
  3. #333
    13.08.2010
    Томск
    1,113
    1181
    517
    из другой темы перетащил RN6L пишет :
    Пока приходится прыгать. В основном это из-за того что не все программы говорят голосом набранный позывной, поэтому пока при необходимости пользую N1MM. Хотя недавно вышла новая версия, может там уже есть эта фишка, не проверял и аннонс внимательно не читал. Еще у меня возникла проблема с RTTY. Матюкался DXLog на что то, поэтому перед WPX зарядил тоже N1MM, но и там какая то засада с манипуляцией вышла, скорее всего из-за интерфейса. К тому же редуктор на новой антенне замерз, в общем все в кучу, поэтому вообще не стал участвовать, хотя очень хотелось антенну испытать. В общем, как говорил Фоменко на "Русском Радио" - "любовь это не просто так, ею надо заниматься"
    Любая инфа, в т.ч. и по поводу "светофора" конечно полезна. Вованыч, я повторю (вдруг не заметил) свою просьбу постом выше про макрос. Макросы штука интересная, я ума не приложу как у меня на одном из компов получались в режиме SO2R контрольные номера в виде 000. Ты еще смеялся, но это реально было на рабочем компе. Потом когда на выходной приехал в деревню, такого эффекта не получилось.
    По поводу говорящих файлов , это будет на другой мултиплатформе - версия 3 - так обещали
    Василий , ты в каких контестах марафонах работаешь , тебе эта фича нужна как воздух ?? Чота с номером за 2-3-5 тыщи QSO замечен не был Все время вижу отмазки , то погода , то рыбалка )).. - .... шучу.
    В DIGI - все работает супер ! 4 декодера поддерживает . Просим автора сделать , что бы в отдельно настраивать макросы для CW и DIGI но он пока этого не сделал.((( На что ругалась программа , если не описаны симптому- помочь не смогу.
    По поводу работы места на поиск чтобы не резервировался номер а можно было вписать инфо в RCVD поле - сделать нужно так
    В MSGS поиска ( РЕЖИМ ПОИСКА S/P активируется в Tools - в онкно часов становится желтым появляется S/P )
    Зовем кнопкой F4
    Макрос должен выглядеть так
    $FOCUSRCVD $MYCALL - значит перевести курсов в поле "номера" и отправить свой позывной
    отвечаем корреспонденту кнопкой F2
    $RESERVENR ++$RST-- $SERIAL $CR - что значит - зарезервировать номер - передать rst - передать серийный номер - $CR - внести в лог
    ПО поводу 000 номера
    Ты включил USE NUMBER SERVER - что значит использовать номерной сервер
    НО в в конфиге сети - Start number server ты его не активировал
    Вот программа обратилась к серверу номеров , а сервера то и нету и выдала 000
    Я и намекнул - кури хелп , не понятно - спрашивай тут !
    Насрать - ( читай с пробелом) т.е. много ))) - поможем !!!
    73 !
  4. #334
    Low Power Аватар для RT0R
    18.03.2014
    87
    153
    Владимир опишите действия "парикмахера" при "причёсывании" через 5м-contest.
  5. #335
    13.08.2010
    Томск
    1,113
    1181
    517
    Sorry , off Dxlog subject
    Ответил в ЛС
  6. #336
    13.08.2010
    Томск
    1,113
    1181
    517
    По просьбам и требованиям трудящихся в Чемпионате РФ :
    Исправил ошибки в модуле SSB
    Добавлен модуль под Чемпионат CW
    В оба два модуля добавлен Крым и Севастополь
    Разрешены переходы для MOST
    Сделан модуль RUCH_rgx - автоматически подставляет зону в номер , определяет станции РФ , в БМ фильтрует "иностранцев" , они будут показаны как "ненужные", их можно по желанию скрыть. ( ранее все станции не сработанные и тех кто не был в базе - на БМ обозначались как DUPE)
    Туры переключаются врукопашную Ctrl+F10
    Более ничего не осилил
    т.к.
    The beer was over (((
    RUCH.txt и RUCH_CW.txt - положить в папку Contest
    Модуль RUCH_rgx - положить в папку Database
    injoy!
    73 !
    Вложения Вложения
  7. #337
    13.08.2010
    Томск
    1,113
    1181
    517
    Кто будет работать в Кубке Урала Multi Single замените модуль в папке Contest
    Было Включено правило 10 минут для смены диапазона - подправил , теперь можно безпредельничать !
    сингл-ОППЫ могут не волноваться , у них все чотко !
    Вложения Вложения
    • Тип файла: txt URAL.txt (2.1 Кб, Просмотров: 7)
  8. #338
    Big Gun Аватар для RN6L
    22.01.2003
    пос. Керчикский, Россия
    12,626
    5294
    198
    Вованыч, подскажи пожалуйста как настроить отправку клепежа на стадион. Что то у меня крайний раз не получилось...
  9. #339
    13.08.2010
    Томск
    1,113
    1181
    517
    Так это не только я могу подсказать ))
    Commands-Live score- поставить птицу Enable auto posting
    там же в Setup можно настроить если работаешь на каком-то определенном диапазоне , а так же переодичность отправки и возможно скрыть раскладку по диапазонам - отправлять только очки - , для этого убрать птицу - Send qso/mult breakdown
    Что бы проверить - нажми Post now ( отправить сейчас)
    Внизу info строке увидишь - нарисуется текст , что данные отправлены на сервер .
    В каком контесте отправлял и не получилось ?
  10. #340
    22.01.2003
    12,626
    5294
    198
    Да ни в каком пока не получилось... Спросил перед UA1DZ... Я же изучаю на ходу, СТ-шку то давно пользовал, да и не было в ней многого. Просто не нашел меню откуда это управляется... В N1MM многое по другому. Многое проще и оно на виду для ламеров, но поэтому он и "тяжелее" в плане ресурсов.
    Commands-Live score- поставить птицу Enable auto posting....
    Спасибо, попробую не забыть до следующего теста.
  11. #341
    04.02.2015
    270
    618
    818
    Владимир, этот чудо лог может показывать азимут на корреспондента? Ну не могу найти где должна быть "галка"!
  12. #342
    13.08.2010
    Томск
    1,113
    1181
    517
    Да, показывает ,в трех местах можно посмотреть .
    В окне Chtck mult - там по умолчанию.
    В окнах BMap и cluster ann можно настроить по желанию
    В BM закладка list - еще позволяет сделать фильтрацию по направлению
    На мультовом/подборном месте стоит AD335 с редуктором RAK он работает по протоколу PSTRotator
    Эта программка нормально вяжется с логом, я назначил на одну их клавиш сочетание Ctrl+F12 и клацаю в случае необходимости - ант автоматически поворачивается на корреспондента .
    73 !
  13. #343
    04.02.2015
    270
    618
    818
    Спасибо! Запустил, работает. Только почему то когда РФ позывные ввожу, и всегда показывает азимут 287 гр или 284 гр.
  14. #344
    Аватар для RX1AG
    30.07.2006
    9,916
    Записей в дневнике
    5
    2478
    714
    Скачал Дх лог версия 2. 3. 12. с офиц сайта. Установил, запустил. Система пишет "Лог не зарегистрирован" и ниже цифры 1-2-3. Предлагается нажать на 1. Нажимаю-открывается интерфейс лога.
    Нажимаю на 2.
    И далее сразу табличка , "сейчас лог будет закрыт" . И все закрывается...... Появился платный вариант? Чем он отличается от бесплатной версии? Подскажите, плс...
    Ранее стояла версия 2.1. 8. Она денег не требовала...
  15. #345
    13.08.2010
    Томск
    1,113
    1181
    517
    Широка страна моя родная ))
    Да все верно . У нас по DXCC - три страны Европейская Россия, Азиацкая Россия и Калининград .
    Определены три точки QTH локатора . По ним идет определение азимута относительно локатора который ты вводишь при конфигурации .
    Поменяй свой QTH локатор - изменится азимут.
    Правильный расчет азимута должен быть в некоторых УКВ тестах ( очки по расстоянию) , где данные локатора по DXCC отключены.
