18.09.2009, 19:38 #1
- 23.02.2006
- Лос-Анжелес, Laguna Hills, CA , USA
- 522
- 184
- 23
Новый спутник на орбите
SB SPACE @ ARL $ARLS007
ARLS007 South African Amateur Radio Payload Reaches Orbit
ZCZC AS07
QST de W1AW
Space Bulletin 007 ARLS007
From ARRL Headquarters
Newington, CT September 18, 2009
To all radio amateurs
SB SPACE ARL ARLS007
After several delays, South Africa's SumbandilaSat satellite finally blasted to orbit aboard a Soyuz rocket from the Baikonur Cosmodrome in Kazakhstan on September 16. The main payload is a multi-spectral imager, but the satellite also carries an Amateur Radio component consisting of a 2 meter/70 cm FM repeater.
After SumbandilaSat is fully commissioned, the repeater will be activated with an uplink at 145.880 MHz and a downlink at 435.350 MHz; there will also be a voice beacon at 435.300 MHz. The transponder mode will be controlled by a CTCSS tone on the uplink frequency. The CTCSS tone frequencies have yet to be announced.
SumbandilaSat was sponsored by the Department of Science and Technology and was built at SunSpace in cooperation with the Stellenbosch University.
In addition to the SA-AMSAT amateur module, the satellite carries Stellenbosch University's radiation experiment and software defined radio (SDR) project, an experiment from Nelson Mandela Metropolitan University and a VLF radio module from the University of KwaZulu-Natal.
NNNN
/EX
SumbandilaSat будет работать в режиме FM репитора 144/430
Uplink:144.880 Downlink:435.350 CTCSS пока неизвестна. Голосовой маяк работает на частоте 435.30073. Владимир (W6BVB) : Laguna Hills CA 92653
24.09.2009, 09:34 #2
- 11.02.2003
- Калуга, Россия
- 1,362
- 167
- 85
25.09.2009, 09:38 #3
- 11.06.2009
- Новосибирск
- 51
- 656
- 157
- 978
Присвоен номер NORAD 35867.
