12.09.2013, 14:57 #46
- 12.07.2010
- Балашиха, Московская обл.
- 856
- 429
- 320
v1.32
- some minor changes in decoding algorithms,
- important change in path configuration: now you can freely define packet paths as 6-symbol names + 0-15 SSID. Older
firmware versions limited it to New-N paradigm paths,
- removed RF and IS checkboxes in beacon, weather and telemetry packets configuration. These checkboxes were redundant and
only took precious space in configuration memory. Now you should set RF rate and/or IS rate to a value of 0 to disable
beacon,
- IF YOU IMPORT YOUR CONFIGURATION FROM OLDER FIRMWARE VERSIONS PLEASE MAKE SURE TO CHECK IMPORTED SETTINGS BECAUSE
PACKET PATHS WILL NOT BE IMPORTED BECAUSE OF PATH FORMAT CHANGE,
- added temperature/humidity sensor false reading check for Davis weather station.
- added consecutive packets send burst mode option (in Radio Tab), when there is more than one packet in TX fifo, they are
sent one after another with only start/end flag between them (and not full preamble, quiet time, etc.). That's a standard
feature of most APRS devices, not implemented in my units earlier. Difference will be visible for telemetry parameter
packets, which were sent separately before,
- added first telemetry data packet delay after power-up (in Telemetry reports Tab). This gives time to gather enough
data before sending it to RF or IS (useful for 1h window stats or 10 min window stats),
- added telemetry params, data, and weather packets send command in telnet.
06.01.2014, 18:41 #47
- 12.07.2010
- 856
- 429
- 320
Обещают к марту WX3in1 Dual :-) двухдиапазонный
27.04.2014, 19:37 #48
29.04.2014, 00:14 #49
- 16.02.2012
- Ханты-Мансийск
- 48
- 77
- 7
- 8
Все, запустил.
Алексей UB9JBL
29.04.2014, 01:04 #50
- 16.02.2012
- Ханты-Мансийск
- 48
- 77
- 7
- 8
В Интернет не выходит...
Алексей UB9JBL
29.04.2014, 10:43 #51
- 12.07.2010
- 856
- 429
- 320
29.04.2014, 16:51 #52
- 16.02.2012
- Ханты-Мансийск
- 48
- 77
- 7
- 8
Нет, метеостанция отсутствует - пока не до жиру, да и ЖЭУ летом собирается на доме ставить двухскатную крышу(сейчас ровная как блин). Думаю ближе к осени будет видно, куда 3-ю мачту ставить для метеостанции.
А на 5 рисунке APRS IS Пассворд свой придумывать? При переводе инструкции указано, что его надо получить при регистрации ...чего то...Последний раз редактировалось UB9JBL; 29.04.2014 в 16:55.
Алексей UB9JBL
29.04.2014, 17:23 #53
- 12.07.2010
- 856
- 429
- 320
Тогда метео и не должно быть :-)
02.05.2014, 21:21 #54
- 16.02.2012
- Ханты-Мансийск
- 48
- 77
- 7
- 8
не выходит WX3in1 Plus 2.0 в интернет.. надо "сливать" и "завязывать" с этим делом
Алексей UB9JBL
18.09.2014, 15:14 #55
- 28.03.2011
- Истра
- 45
- 13
- 13
Коллеги всем привет! Я наконец то купил и настроил wx3in1mini. Теперь в Истре будет шлюз APRS!!! Правда всего 5 Вт.
Но так и не смог понять как менять иконку гейта. Домик тоже ничего, но сам факт, что не могу докопаться просто бесит!!!
Помогите плиз ткните носом где копать...Юрий R2DNB ex. UB4AAD
18.09.2014, 15:28 #56
- 28.03.2011
- Истра
- 45
- 13
- 13
Все спасибо разобрался сам! Как говориться прочитайте инструкцию если ничего не работает!
Теперь буду с уровнями играться..и прочими тонкими настройками.Юрий R2DNB ex. UB4AAD
18.09.2014, 20:23 #57
- 12.07.2010
- 856
- 429
- 320
21.11.2015, 17:44 #58
- 16.02.2012
- Ханты-Мансийск
- 48
- 77
- 7
- 8
Здравствуйте! Скажите, а можно как то WX3in1 Plus 2.0 опросить принудительно о его состоянии? Например: Въезжаю я в зону "видимости" диджика и что бы не ждать , когда он маякнет: да я такой то (UB9JBL-10) на этой зоне покрытия, а отправить ему команду/пакет/сообщение, на которое он ответит, что вот он я, живой здоровый и вот вам температура и питание 13вольт..
Алексей UB9JBL
22.11.2015, 01:16 #59
- 14.03.2011
- Moscow
- 117
- 27
- 19
Для большинства транслирующих узлов APRS предусмотрены команды для тестирования состояния и других нужд.
Они выполняются через отправку сообщения с командой на позывной.
Список таких команд не регламентирован жестко и каждый создатель включает в поддержку то, что хочет.
Наиболее популярные команды можно найти поиском в инете:
?APRSP - sends a location beacon.
?APRSS - sends the status text.
?APRSO - sends your active objects.
?APRSD - sends a list of stations that have been heard direct.
?APRST (or ?PING?) - sends the route by which the query was received.
?APRSH <callsign> - sends information on when <callsign> was last heard.
?VER? (not an APRS query, but some APRS software support s it) - sends information on the software version in use
Думаю, что у WX3in1 Plus 2.0 могут быть и дополнительные команды, надо читать документацию. Проверьте по списку, возможно ответ с нужной инфой придет по одной из этих команд.С Уважением, Виктор (UB3AAZ)
07.10.2018, 18:33 #60
- 17.08.2017
- 47
Никак не могу победить эту проблему. Может есть идея?
Купил LaCrosse/Technoline WS-2350 + WX3in1 Plus 2.0
Зарегистрировался в Weather Underground метеостанция WS-2350 все отправляет на сервер.
WX3in1 тоже запущен как APRS I-GATE. Прописаны в настройках сервер пароль Weather Underground но погоду не ретранслирует. Я подумал возможно американцы сервера удалили с Weather Underground .
Последний раз редактировалось UB2FCA; 07.10.2018 в 18:47.
