15.09.2004, 18:10 #1
- 15.09.2004
- Курск
- 53
- 25
- 9
Ts-440s
В 440 кенвуде столкнулся с проблемой:
в SSB нет регулировки выходной мощности,
а для PA нужно ватт 30-50.
Может кто подскажет, как можно уменьшить выходную мощность.
15.09.2004, 18:24 #2
- 30.12.2003
- Kyiv
- 545
- 204
- 84
И что нет даже ступенчатой регулировки, типа 10-50-100Вт?
73! UT7UV
15.09.2004, 21:58 #3
- 15.01.2003
- Novokuibyshevsk
- 1,084
- 134
- 47
В TS430S есть внутри ступенчатая регулировка 100/50 Вт,а 440 по выходному каскаду практически копия.
15.09.2004, 23:52 #4
- 24.11.2003
- Vancouver BC
- 7
Здравствуйте RUS, попробуйте регулировать выходную мощность в SSB регулятором усиления микрофона MIC. Успехов и удачи во всём. 73! Юрий / VE7GBC
16.09.2004, 02:28 #5
Re: Ts-440s
Первоначальное сообщение от RUS
Hello TS 440 user..
The last few weeks I've seen questions of how to make the power in SSB mode for the TS440S adjustable without changing the Mic-Gain. It's a very easy job to do.
Take off the top cover of the rig.
At that moment you have a sight on the first unit (IF-Unit)
Than you have to look for Diode 49.
You will find Diode 49 at about 5 CM from the backend of the unit and about 6,5 CM from the leftside of the unit.
Just next of C138 and between plug 38? (red/orange wires) and plug 26 (black-cover/blank wires) Just cut that Diode 49,bend one part a little away and leave the part's where they are. It's the best way to do I think.
Replace the topcover.
From now on it is possible to adjust only the power in SSB mode by just turning the CARRIER Control at the front of your rig and leave the Mic-gain for where it is.
Turning counterclock will minimize the power until a 20mW or something like that.
Because most TS440 users have'nt used their carrier control that much I think it's better to pull off the MIC/CAR knobs and spray some contact cleaner in the shafts. (I know,it's not the best way).
When you switch your rig into the CW mode you can adjust the power in what you like,switch the mode in to USB or LSB and if it is correct the power will not come above the level that what you have adjusted in the CW mode.
Just simple , is'nt it?
Of course you will do this all in your own responsibility because I won't take any!!! Agree?
Человек столкнулся с подобной проблемой и поборол ее вышеуказанным путем. Успехов!
27.11.2011, 21:05 #6
- 20.08.2004
- Белебей
- 73
- 143
- 9
- 26
как вот такой перевод как понять?
-----Только сокращение, что Диод 49, изогните одну часть немного далеко и оставьте часть, где они. Это - лучший способ сделать, я думаю.
Замените topcover.------
можно понять что ДИОД 49 НАДО УДАЛИТЬ-т.е один конец отрезать,кто знает точно?? и что такое topcoverSDR MALAMUT
28.11.2011, 08:32 #7
- 28.01.2003
- Мыски
- 529
- 89
- 331
Да, с диодом правильно поняли. topcover - верхняя крышка
Replace the topcover - в том смысле, что закройте(восстановите на место) верхнюю крышку. Напоминает чтоб не забыли :-)Последний раз редактировалось UA9UNG; 28.11.2011 в 08:36.
73! Вадим (UA9UNG)
28.11.2011, 12:21 #8
Здравствуйте !!!
Посмотрите на сайте : youtube.com
TS-440S MOD - SSB PWR CONTROL WITH CARRIER KNOBLZ2HR
28.11.2011, 14:47 #9
- 20.08.2004
- Белебей
- 73
- 143
- 9
- 26
очень наглядно снято кино,описание этой процедуры слишком расписано,а все очень просто!
SDR MALAMUT
28.11.2011, 15:04 #10
28.11.2011, 15:23 #11
- 02.05.2007
- Липецк
- 203
- 38
- 349
22.08.2023, 01:01 #12
Тема не актуальна
но вдруг кто то захочет сделать нормальную регулировку мощности
на D8 нужно подать напряжение с CAR резистора +9 вольт вроде
без подбора R22 и D9 будет регулировка от 50 до 100 ват
я у себя добился от 10 до 100 ват подбором стабилитрона D9 и резистором R22
на эмиттере Q3 (-1.2в) - 100ват при 10-15 ваттах (-4.7) вольт
в интернете что то такого не нашел,вот и решил выложить.
