Показано с 1 по 3 из 3
    07.04.2002
    г.Москва, г.Троицк
    49
    9,497
    2569
    7704
    Восклицание Технология D-STAR на спутнике AO-27
    AO-27 does D-Star
    On July 1st, 2007 during the 20:00 UTC pass over North America, AO-27 was again providing a new round of enjoyment for Amateur satellite experimenters. Thirteen years ago, AO-27, which coined the term "Easy Sat" by employing an FM bent pipe in space, provided many hams the ability to use a satellite without the expense of multi mode radios.
    This time around, AO-27 was used to provide the first D-Star via Satellite contact between Michael, N3UC, FM-18 in Haymarket VA and Robin, AA4RC, EM-73 in Atlanta GA. Signals were reported as strong and easy to copy. Call signs were received digitally on both sides of the link. Communications were possible for most of the pass. Both Robin and Michael were surprised at just how well the digital link was received.
    The Analogue repeater on-board AO-27 is well suited for D-Star work. The radios were designed to pass 1200-19200 baud GMSK data. The Analogue mode was not a primary mode of operation in the design. Using a free switch setting in the switching board, the design team hooked up the output of the receiver to the input the transmitter to create the Analogue mode. There is not the normal low frequency filtering that is found in normal FM Repeaters. This means the Analogue mode passes the low frequencies required by D-Star.
    The equipment for the contact were IC-2200s on the Uplink at both N3UC and AA4RC, an IC-2820 on the downlink at N3UC, and an IC-91AD on the downlink at AA4RC. Doppler shift did prove to be a minor problem while using these radios. The D-Star signal would decode out to about 1.5 KHz in frequency error. The IC-2820 would only tune on 5 KHz spacing (the 6.25 KHz channels did not fall in the right locations to help.) so at times we could not decode the digital signals.
    For others that want to try D-Star via Satellite we have a few things to keep in mind.
    1) Remember that the FM users can't hear you on the bird.
    They hear a strong "noise" but can't decode you. So please keep the D-Star transmitting short.
    If you can monitor the FM side, you can time your transmitting as to not step on them.
    Please try to schedule with other D-Star users instead of calling CQ for the entire pass.
    2) Watch the doppler, at times you may not be able to decode a signal even if the other station can decode you.
    Keep your uplink on 145.850 for the entire pass. Program your radio call signs the same as for simplex, AO-27
    does not have a D-Star call sign. You don't need to set up your radio for repeater use.
    3) Before using other satellites besides AO-27, please check with the control operators of those satellites. Every
    FM satellite may not pass the D-Star signal nor may the control operators wish to have D-Star traffic on the bird.
    4) If you hear us on the Bird, please give us a call. We would love to have as many D-Star users on AO-27 as possible.
    The AO-27 Control Operators fully support and encourage the use of D-Star via Satellite on AO-27.
    A shout goes out to ICOM for creating Radios for this Fun new Amateur mode of operation. Without their radios we could not have made this contact.
    - Michael
    N3UC
    Ссылка на сайт - http://www.ao27.org/AO27/index.shtml
    21.03.2008
    Алушта, пгт.Партенит
    195
    11
    16
    Цитата Сообщение от RV3DHC Посмотреть сообщение
    AO-27 does D-Star
    Так а ОНА(он), как к Д-стар применимо) действует???
    Standart Power Аватар для RA3APW
    03.03.2006
    197
    189
    107
    AO-27 does D-Star
    Валерий, AO-27 (в отличие от OUTF-1) не несет на борту никакого D-Star оборудования. Просто его линейный транспондер ретранслирует через свой аналоговый радиоканал сигнал uplink D-Star. При этом входная полоса аналогового транспондера достаточно широка для GMSK 0.5 4800 бит/с и доплеровского сдвига по частоте.
    Так как при аналоговой ретрансляции не происходит регенерации (восстановления) сигнала на борту спутника перед передачей вниз, то это решение просто, но не эффективно из-за повышенного количества ошибок (плохой BER/MER).
  1. Технология D-STAR от ICOM
    от UA3IRS в разделе D-STAR
    Ответов: 65
    Последнее сообщение: 08.01.2015, 23:48
  2. D-STAR vs. 802.11
    от VE3EUT в разделе D-STAR
    Ответов: 9
    Последнее сообщение: 19.06.2010, 18:11
  3. Технология VoIP и молодежь
    от RC3C в разделе Связь через интернет
    Ответов: 39
    Последнее сообщение: 27.03.2007, 13:20
  4. ICOM D-STAR дружит с APRS
    от UA3IRS в разделе APRS: Аппаратура
    Последнее сообщение: 12.06.2006, 10:07
  5. Gold Star. Экран не светится!
    от Fevzi в разделе Телевизоры
    Последнее сообщение: 06.12.2003, 05:47
Метки этой темы
