Сообщение от
RN3RQ
Привет всем!
Не знаю куда это "засунуть",думаю перекинут,если что:)
Starting after the ARRL Board meeting today (January 20, 2018) a new
DXCC criterion will be added to Section II for Political Entities
(point 1). Currently there are three criteria for Political Entities.
If any one of the following three criteria are met the entity qualifies
as a Political Entity on the DXCC list:
1) United Nations Member State
2) Prefix is on ITU callsign prefix block
3) "The entity contains a permanent population, is administered by a
local government, and is located at least 800 km from its parent.
To satisfy the "permanent population" and "administered by a local
government" criteria of this sub-section, an Entity must be listed
on either (a) the U.S. Department of State's list of "Dependencies
and Areas of Special Sovereignty"
as having a local "Administrative Center," or (b) the United Nations
list of "Non-Self-Governing Territories.
The new criterion, which goes into effect after the BOD meeting, will be
if the potential entity is a member society of the IARU
and is listed on the United
States Department of State Independent States of the World list
. The Entity must be on both
lists in order to qualify as a Political Entity. QRX for the exact timing
that the new rule will go into effect.
Кратко по-русски.С 20 января изменились критерии внесения новых территорий в список DXCC.
С удивлением обнаружил,что теперь Госдеп США является "высшей инстанцией"...По-моему раньше
так не было,хотя может я ошибаюсь.Готовьтесь,Косово теперь будет новой кантри для дипломов ARRL.
