Страница 1 из 4 1234 ПоследняяПоследняя
Показано с 1 по 15 из 47
Тема: Работает ли eqsl.cc?
    01.04.2007
    717
    231
    204
    Что-то не могу попасть на eqsl.cc. Вместо сайта выскакивает огромный текст на английском языке. Подскажите, пожалуйста, этот сервис работает или только у меня проблема?
    07.12.2008
    3,144
    1264
    2248
    У вас.
    Very High Power Аватар для SO4TT
    09.06.2010
    Tallinn
    1,165
    744
    1065
    Работает.
    Проверено сегодня.
    18.03.2013
    39
    978
    304
    1034
    Работает, но на заглавной странице какая-то текстовая хрень про сообщения.
    01.04.2007
    717
    231
    204
    Выкладываю кусочек сообщения, чтобы это значило? И что можно сделать?
    EQSL.CC REAL-TIME ELECTRONIC QSO (eQSO) PROTOCOL
    revised 04 July 2016
    Not final! Subject to change without notice!
    SYNOPSIS
    Users of the eQSL.cc system can communicate with each other online in short, 160 character, SMS-like messages.
    The preferred client program is a ham radio logger that is already using the Real-time eQSL upload interface.
    Typical purposes might be to arrange an on-the-air QSO, to set a SKED, to coordinate a contact elsewhere,
    or whatever (legal) purpose the communicators desire.
    Bronze membership or higher is required to send messages, to offset the expense of managing the new load
    on servers and network bandwidth. Message recipients may receive up to three (3) messages before they will
    be required to establish a Bronze membership. Messages beyond the first three free ones will be queued
    and delivered upon membership upgrade.
    Loggers may have been seeing the following New Message Notification in response to their logger operations,
    indicating that an eQSO message has been sent to this user and can now be picked up:
    INFORMATION: Message(s) for user. See www.eQSO.center for details
    HOW TO USE THE "eQSO.cfm" PROGRAM
    While logged into the eQSL.cc server as usual, you can send an HTTP POST, or supply the commands in the URL:
    1. AS AN HTTP POST
    Send an HTTP POST and retrieve and analyze the results page very simply.
    The URL is case-insensitive and is:
    http://www.eqsl.cc/qslcard/eQSO.cfm
    Example:
    <FORM METHOD="POST" ACTION="https://www.eqsl.cc/qslcard/eQSO.cfm">
    Callsign to Send To: <INPUT TYPE="TEXT" NAME="CallsignTo" SIZE="15" MAXLENGTH="15" VALUE="WB4WXX">
    <INPUT TYPE="HIDDEN" NAME="EQSL_USER" VALUE="mycallsign">
    <INPUT TYPE="HIDDEN" NAME="EQSL_PSWD" VALUE="mypassword">
    <INPUT TYPE="HIDDEN" NAME="COMMAND" VALUE="Send">
    <INPUT TYPE="TEXT" NAME="MESSAGE" SIZE="160" MAXLENGTH="160">
    <INPUT TYPE=SUBMIT VALUE="Transmit">
    </FORM>
    2. AS A URL
    Remember that special characters such as slashes (i.e. WB4WXX/5) should be escaped.
    Ampersands & and question marks ? have special meaning to our programs and should be escaped
    when they appear in the data itself.
    See the example below:
    https://www.eqsl.cc/qslcard/eQSO.cfm...=Hello%20World
    RETURN PAGE FORMAT:
    The returned HTML page can be identified by the comment string near the top of the page:
    <!-- Reply form eQSL.cc eQSO Interface -->
    If this is missing, something is wrong and the rest of the response should not be trusted
    FATAL ERRORS:
    A line beginning with "ERROR:" is a fatal error indicating an unsuccessful completion of the command
    Most all of the error messages here are verbatim. However, in order to provide for upward compatibility,
    you should display any line beginning with "ERROR:" if you don't process it as one of the errors below.
    INFORMATIONAL RESPONSES:
    A line beginning with "INFORMATION:" is not an error. Most of these are shown below verbatim, however,
    you might want to display any line beginning with "INFORMATION:" if you are not processing it as one of the replies below.
    UBIQUITOUS RESPONSES: (One or more of these could be returned in response to ANY of the commands)
    INFORMATION: System is down until HH:MM Z
    INFORMATION: Message Number xxxxxxxxxxxxx delivered at YYYYMMDDHHMMSS
    INFORMATION: Minimum polling period xx seconds
    (Note: Message Numbers are not contiguous but will normally be in chronological sequence. They are 10 digits long)
    (Note: Best practice is to store the Message Number assigned by the system and track those that have been delivered)
    (Note: The minimum polling period varies dynamically with system load and must be adhered to by the polling logger.
    Best Practice is to default to 10 seconds until change is requested. Loggers that regularly ignore the minimum delay
    between polls will be penalized. Use the returned number to set the delay before the next poll.)
    ERROR MESSAGES THAT ARE ALWAYS FATAL:
    ERROR: Missing eQSL_User
    07.12.2008
    3,144
    1264
    2248
    Сначала нужно войти.
    01.04.2007
    717
    231
    204
    И как это сделать? Набираю адрес или с закладки пытаюсь войти и этоттекст выскакивает
    Коротковолновик
    07.10.2010
    Фергана
    668
    268
    У меня такая же бяка,один к одному
    Very High Power Аватар для LY1CE
    07.06.2002
    Каунас
    76
    1,618
    185
    178
    Сегодня утром было нормально.
    Теперь выдает это описание протокола.
    Видимо ТС что-то поломал
    Удалось войти через сюда - Login - eQSL.cc
    01.04.2007
    717
    231
    204
    Спасибо,Tadas! Значит это не только у меня, подождем пока наладится
  12. #12
    Big Gun
    12.10.2007
    Петропавловск, Северо-Казахстанская обл.
    6,808
    1351
    168
    Все работает .
  13. #13
    Big Gun Аватар для R6LCF
    21.04.2015
    г.Таганрог
    5,119
    1534
    1116
    Вообще то войти необходимо сначала.А я уж правда подумал что не работает.Все нормально!
  14. #14
    Коротковолновик
    07.10.2010
    Фергана
    668
    268
    Тоже пролез через дырку,показанную Тадасом )
  15. #15
    Funkamateur Аватар для DL9NO
    12.12.2005
    Kitzingen am Main
    2,305
    784
    29
    вот так войти получилось............а как всегда www.eqsl.cc не получается
    а вот если вот так написать то попадаеш сюда как всегда
    http://www.eqsl.cc/qslcard/index.cfm
    Последний раз редактировалось DL9NO; 05.06.2016 в 22:37.
    Meine Name ist Funk und meine Hobby ist Funk
    Georg von Funk aus Bayern
