Если лог не понимает позывные, то я обычно вручную редактирую CTY файлы. Так было например с 4Y1A, 4U2U и C7A. Никаких проблем после этого не возникло.
Нашел , забыл немного :
Win-Test 4.x and later
Options | Data Files | Country Files
Choose one
Click on Download
You will get a prompt to download – answer Yes
Надо только выбрать обновленный CTY_WT.DAT , который сейчас от 26.10.2015
Теперь все нормально
73! Vlad
В рефлекторе дан ответ N6TV в теме TO station on CQWW
Да , пока TO2A не проставляется , надо исправить руками
73! Vlad
The Country (CTY) Files were updated on 27 October 2015:
CTY-2512 – 27 October 2015 | Amateur Radio Country Files
Please use this file to ensure your CQWW Phone log is properly scored.
Remember that official scoring is done by the log checking software.
For installation instructions, start at:
Amateur Radio Country Files | Jim Reisert AD1C
Hover your mouse over the word Contest in the menu, then select the
software you are using.
To install the file, follow the link to your software at the top of the page.
If you are interested in a bigger CTY.DAT for everyday logging, you can get
it here:
Big CTY | Amateur Radio Country Files
Note that the release notes (and Version Entity) for this larger file are
different than what is shown below. There is a separate link to them.
Here are the release notes:
27 October 2015 (CTY-2512)
VER20151027, Version entity is Spratly Islands, 1S
Added/changed Callsigns/prefixes:
* BG9XD/7 is China, BY
* TO8M is Martinique, FM
* TO2A is French Guiana, FY
* KL7HM and W8BFX are both United States, K in CQ zone 3, ITU zone 6
* K9DIG is United States, K in CQ zone 4, ITU zone 7
* K4DXV is United States, K in CQ zone 4, ITU zone 8
* AH0AX is Guam, KH2
* KF6ZAL, N6ZAB and NH2CD are all Hawaii, KH6
* KE5ZRK and KE7TRX are both Alaska, KL
* KC9MCN is US Virgin Islands, KP2
* KC1DRV, KK4DCX and KM4AKA are all Puerto Rico, KP4
* LU5XP/D and LU6FEC/O are both Argentina, LU
* RT9K/7 is European Russia, UA
* R15CWC/2 is Kaliningrad, UA2
* R15CWC/8 is Asiatic Russia, UA9
* R15CWC/9 and R2015RR are both Asiatic Russia, UA9 in CQ zone 18, ITU zone 31
* R15CWC/0 is Asiatic Russia, UA9 in CQ zone 19, ITU zone 34
* VE2IDX is Canada, VE in CQ zone 2, ITU zone 4
* VK6FMON/3 is Australia, VK
Retired Callsigns/prefixes:
* EA5RKB/9 in Ceuta & Melilla, EA9
* TX7EME in French Polynesia, FO
* GB0DPK and GB0SBC in Scotland, GM
* GB0CEW, GB100BVU and GB1PCA in Wales, GW
* AC4M, AD5OW, K4AMQ, K5AUP, KC7QY, KK5OQ, KO4XJ, N4FZ, N6BM, N8PR,
NP2MR, W5XB and WS6X in United States, K
* KD3FZ and KI6WOJ in Hawaii, KH6
* K0CAW, KF5YYK and KI4COG in Alaska, KL
* LU6HBB/H in Argentina, LU
* TA1BX/3 in Asiatic Turkey, TA
* R90IARU, R9DA/6, RU9CK/6/P and RV9CX/6/P in European Russia, UA
* R2015KM and RI0BV/0 in Asiatic Russia, UA9
* VK2015TDF in Australia, VK
73 - Jim AD1C
Jim Reisert AD1C, <jjreisert at alum.mit.edu>, Jim Reisert's Home Page
Почему-то не сделал он во время новый CTY . Сейчас всё добавлено.
Приветствую всех!
Вопрос знатокам Win-Test
При включении Contest recoder в Win-Test, совместно с FT DX 5000, при записи
не слышно своей передачи (само прослушивания).
Сигнал берется с разъема AF OUT, режим MONI на трансивере включен.
Если подать сигнал с разъема Phones (головные телефоны) то все OK.
Может кто то подскажет где косяк.
Alex,
Ew2A
Коллеги,
У меня не обновляются country files. Пробую автоматическую загрузку - загружает, но версия фала в окнке N показывается стараю. Если клинкуть мышкой на окне N - показывает, что ищет файл HF.dtb.
Загрузил в ручную, переименовал в HF.dtb - показывает версию текущую, но не находит даже мой позывной :-(, т.е. версия старая.
Я, правда, нахожусь в режиме DX Pedition. Попробую переключится в режим контеста.
Может кто-то посоветовать ?
Постараюсь разобраться. 73 !
Не знаток FT техники, но мне кажется причина именно в конструктивных особенностях самого FT DX 5000 или некорректных настройках в меню - что именно требуется подать на выход AF OUT. Если при наличии записи своего CW сигнала все корректно, а нет записи SSB в режиме MONI, то однозначно смотреть мануал и схему. Расскажите как решите проблемку, интересно :)
Павел , у меня почему то с самого начала не работает окно Check Partial , то есть в нем появляются только позывные из текущего лога , а из базы нет , при этом в N+1 все появляется нормально . CP_1 - CP_3 - это настройки окна , а CP_4 - это отсутствие информации в окне . Может есть какие мысли ?
73! Vlad
Взял сигнал с разъема REC, на нем есть само-прослушивание. Рэнди сказал, что если одно радио, то писать можно все на один канал (имеется ввиду второй приемник).
Единственное, что применил внешнюю звуковую карту SB 1140. При использовании внутренней звуковой карты не смог выключить внутренние микрофоны на ноутбуке (в режиме SSB), нажимаешь педаль и все запело...
Запись получилась вполне приличная, не для концерта конечно, но для прослушивания каких то "вопросов" - самое то что надо.
Использую ноутбук FUJITSU с ДОК станцией, на которой есть COM и LPT порты и Win-Test 4.19.0
Забыл скриншоты пристегнуть - вроде все правильно
73! Vlad
Вложение 153712Вложение 153713Вложение 153714Вложение 153715
TO R7LV.
Проверил у себя, всё работает.. Создал новый лог в DX-педишен моде. При вводе, позывной обнаруживается:Вложение 153730
..даже если 7NW ввожу, то подсказывает первую букву.
Попробуйте сравнить записи в файле wt.ini по этим строкам:
[CheckPartial]
DisplayExchange=1
LogOnlyChecked=0
[DataFiles]
CtyFile=2
[NP1]
LimitSearches=0
DisplayExchange=1
по default он лежит в C:\ProgramData\Win-Test\cfg
Где-то что-то неверно указали. Рекомендации от "производителя" по подготовки к контесту и уборке лишнего есть в таком виде. Да, и файл SCP_VERxxxxx.zip распакуйте в папке databases.
