Кстати, так как у нашего проекта есть вполне определенный интерес к System Fusion, на нашем сайте запущен новый раздел по данной тематике - https://www.dstar.su/forum/viewforum.php?f=66
RE: New Additional Features - Important FTM-400D / FT1D Firmware Update
Dear Valued Yaesu Customers;
Yaesu’s System Fusion has been spreading around the world at a tremendous rate as the global Amateur Radio community becomes increasing aware of its ability to provide total integration and compatibility of both digital and conventional FM communications. Yaesu has now released the major firmware updates for our Dual-Band / Dual-Mode FTM-400DR/E Mobile and FT1DR/E Handheld Transceivers, which brings more flexibility in System Fusion operation.
AMS function now breaks down into the following operating modes that are fully selectable by the radio user:
AUTO: The both RX/ TX mode is automatically selected from one of the four operating modes (DN, VW, DW and FM) to match the characteristics of the received signal. This is the current AMS operation.
TX MANUAL: The both RX/ TX mode is automatically selected from four operating modes to match the characteristics of the received signal. And if desired to change the TX mode, by pressing the Microphone PTT switch momentarily, the TX mode switch between DN and FM modes.
TX FM FIXED: The RX mode is automatically selected from one of the four operating modes, but the TX mode is fixed to FM.
TX DN FIXED: The RX mode is automatically selected from one of the four operating modes, but the TX mode is fixed to the ‘DN’ (Digital Voice Narrow) mode.
TX VW FIXED: The RX mode is automatically selected from one of the four operating modes, but the TX mode is fixed to the ‘VW’ (Digital Voice Wide) mode.
All AMS operating modes automatically match the received signal on RX which is hassle-free operation as ever. We believe that the new TX Manual is most flexible for many of Amateur Radio operators on any occasions since you can continue to transmit the signal corresponding to the received signal without operating manually as ever, while easily switching between digital DN (Digital Voice Narrow) and FM modes in transmit just by pressing the PTT button quickly.
The new TX FM FIXED, TX DN FIXED, and TX VW FIXED will be also helpful modes for operators who desire to fix the transmitting signal.
As one more functional feature of System Fusion, we have added “Standby Beep” feature to our FTM-400DR/E and FT1DR/E; a courtesy beep is sounded after the end of the other stations transmission when communicating in a digital mode. This new feature must be useful for operators to easily recognize a drop signal of other stations.
All above features are currently available by updating the firmware version to MAIN Ver2.04 for FT1D/ MAIN Ver1.8 for FTM-400D. Please visit Welcome to Yaesu.com for any further details. We always thank you for your continuing patronage to Yaesu.
YAESU MUSEN CO., LTD.
HRI-200 прибыла
Жду WIRES-X NODE ID Nunmber и WIRES-X ROUND QSO ROOM ID Number
Вложение 127759Вложение 127760
Запустил ПО Wires-X
Порты все UDP
20000
46100
46110
46112
46114
46120
46122
46130
46132
46160
Ну и пытается соединиться по HTTP c 71.139.254.252
Кинь плз софтец пощупать
он не запускается без HRI-200 :-( и WIRES-X NODE ID Number
ЗЫ В Америке клубам DR-1X предлагается за 500 зеленых попугаев
Первый тест
Первый тест показал след: если через DFL-860E делать проброс портов то не запускается, через UPNP роутер все работает.
По странное конечно.
а все я разобрался работает.
Да, аналоговый :-)
