Показано с 1 по 3 из 3
    High Power Аватар для W6BVB
    23.02.2006
    Лос-Анжелес, Laguna Hills, CA , USA
    522
    186
    23
    Новый спутник на орбите
    SB SPACE @ ARL $ARLS007
    ARLS007 South African Amateur Radio Payload Reaches Orbit
    ZCZC AS07
    QST de W1AW
    Space Bulletin 007 ARLS007
    From ARRL Headquarters
    Newington, CT September 18, 2009
    To all radio amateurs
    SB SPACE ARL ARLS007
    After several delays, South Africa's SumbandilaSat satellite finally blasted to orbit aboard a Soyuz rocket from the Baikonur Cosmodrome in Kazakhstan on September 16. The main payload is a multi-spectral imager, but the satellite also carries an Amateur Radio component consisting of a 2 meter/70 cm FM repeater.
    After SumbandilaSat is fully commissioned, the repeater will be activated with an uplink at 145.880 MHz and a downlink at 435.350 MHz; there will also be a voice beacon at 435.300 MHz. The transponder mode will be controlled by a CTCSS tone on the uplink frequency. The CTCSS tone frequencies have yet to be announced.
    SumbandilaSat was sponsored by the Department of Science and Technology and was built at SunSpace in cooperation with the Stellenbosch University.
    In addition to the SA-AMSAT amateur module, the satellite carries Stellenbosch University's radiation experiment and software defined radio (SDR) project, an experiment from Nelson Mandela Metropolitan University and a VLF radio module from the University of KwaZulu-Natal.
    NNNN
    /EX
    SumbandilaSat будет работать в режиме FM репитора 144/430
    Uplink:144.880 Downlink:435.350 CTCSS пока неизвестна. Голосовой маяк работает на частоте 435.300
    Только читает
    11.02.2003
    Калуга, Россия
    1,361
    168
    85
    Много общаюсь с ЮАРовцами ... после прочтения Вашего поста, всех их поздравляю с успешным выводом его на орбиту. Ребята просто визжат от счастья! Особенно от факта, что мы, великая космическая держава следим за их успехами.
    Благодаря Вам! Спасибо!
    11.06.2009
    Новосибирск
    656
    157
    978
    Присвоен номер NORAD 35867.
  1. 10 новых спутников на орбите
    от W6BVB в разделе Космические виды связей
    Ответов: 13
    Последнее сообщение: 01.05.2008, 20:20
  2. 5) Спутник 4XTECH (RX/TX)
    от UA3IRS в разделе APRS: SAT
    Последнее сообщение: 03.12.2007, 21:12
  3. 4) Спутник RAFT (RX/TX)
    от RX3AOE в разделе APRS: SAT
    Последнее сообщение: 27.01.2007, 00:50
  4. Ответов: 4
    Последнее сообщение: 25.12.2006, 11:59
  5. Спутник
    от alex_x в разделе Космические виды связей
    Последнее сообщение: 16.03.2003, 14:31
