03.10.2020, 12:23 #76
- 25.03.2020
- 30
- 20
03.10.2020, 21:55 #77
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
Here only one digit:
https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
May be problem here. Try this version with comma-separated (local delimiter):
http://rx4hx.qrz.ru/files/loghx/prer..._build_576.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
03.10.2020, 23:02 #78
- 25.03.2020
- 30
- 20
03.10.2020, 23:41 #79
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
Not problem!
From https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
color set here:
<status>single mult</status>
My variants compliance of colors:
double mult = new country
single mult = new country on band
dupe = also dupe.
Now colored:
04.10.2020, 00:28 #80
- 25.03.2020
- 30
- 20
Works nicely!
Would it be possible with not too much programming effort to add a function in setup excluding spots that otherwise would be marked as dupe beeing sent with UDP at all? This way one can choose only to show spots for needed entities in the waterfall.
A yes/no choice in setup, e.g. in the Broadcast data pane would be nice.
73 de LB2EG Richard
04.10.2020, 09:45 #81
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
04.10.2020, 13:35 #82
- 25.03.2020
- 30
- 20
05.10.2020, 08:46 #83
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
05.10.2020, 21:08 #84
- 25.03.2020
- 30
- 20
As shown in my earlier screenshot, the spots window in loghx shows filtered spots, but no filtering in SmartSDR waterfall. (LogHX only spot source for SmartSDR)
I will be out of home shack for some days, operating from my 2d. home shack with no Flex-radio. Only IC-7610 and Elad FDM-DUO.
73 de LB2EG Richard
05.10.2020, 21:45 #85
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
Ok Richard, i'm understand! "Hide Dupe QSO" - it's for other: if you wkd with call, it will be not showed.
You have a different problem - same spots. I'm use trx SunDSR2 with program ExpertSDR, and ExpertSDR show only one spot for one call, it make this self. New spot delete old spot for call.
How it's done in N1MM? Or not done?
I can make so: if spot is in log spots base - it will be not send to UPD.
By the way: is spots on SmartSDR use "time life spots"? Or can manually delete spot?73 de RX4HX, Alexei, http://rx4hx.qrz.ru
05.10.2020, 22:00 #86
- 25.03.2020
- 30
- 20
Excluding spots from the UDP stream is the way to go, I guess.
As far as I can tell there is an age function in the N1MM UDP function that can define the spot "age" in smartSDR, but I am not sure how it works.
Most other apps that send spots to SmartSDR use the Flex-API. https://www.flexradio.com/api.
The N1MM option is the only straight forward UDP method.
The Flex radio spot function is described here: https://edge.flexradio.com/www/uploa...escription.pdf
73 de LB2EG Richard
07.10.2020, 09:12 #87
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
Now via UDP sends only new spots:
http://rx4hx.qrz.ru/files/loghx/LogH..._build_577.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
09.10.2020, 00:13 #88
- 16.04.2020
- 64
I am trying to export an ADIF file just containing 1 stations callsign for an OQRS request. I follow the export and type the callsign in I want, press enter and the callsign goes into the box above, but each export has zero entries. Am I missing something?
Also is the new QRZ function load straight into QRZ.com? I added my API key to LogHXbut it doesn't seen to go up automatically.
09.10.2020, 09:02 #89
- 03.02.2006
- 51
- 17,239
- 8058
- 4227
09.10.2020, 12:13 #90
- 16.04.2020
- 64
I have this paid membership version "QRZ XML Logbook Data".
Ah select via "space" excellent I learnt something today
