14.09.2022, 15:46 #526
- 02.05.2021
- 51
- 6
Hi Alexei,
As you are working on CW, I hope you remember my request
It was about a way (Macro or button, ..?) to set the CW speed identical as our contact .
73s and have a nice day
Christian F8GHE
18.09.2022, 02:35 #527
- 16.04.2020
- 64
I have just installed the ERC rotator control in my yaesu 450DC. All works using the Easy rotor control software. Com 6, Yaesu GS232A 9600,. I have tried using the Yaesu option and the universalcom port in Loghx and tick auto rotation to spot, but nothing turn when using HX. It certainly opens COM6 as when I try to open ERC while I have HX openwith a rotor connected it says COM6 in use. So I am not sure what is missing?
18.09.2022, 11:07 #528
- 03.02.2006
- 51
- 17,200
- 8047
- 4221
Ant.: UW4HW, Pwr.: ~500 Wtts
19.09.2022, 00:03 #529
- 16.04.2020
- 64
19.09.2022, 01:06 #530
- 16.04.2020
- 64
22.09.2022, 23:47 #531
- 16.04.2020
- 64
; Created at 22/09/2022 19:10:30
[RotorSetup]
AutoRotation=True
BaudRate=5
ByteSize=3
COMPort=COM6
COMPort_Command=
Correction=0
DTRControl=False
Parity=0
RTSControl=False
RotorType=1
StopBits=0
01.10.2022, 08:48 #532
- 03.02.2006
- 51
- 17,200
- 8047
- 4221
To M0CGF:
I remember about you problem, pse QRX! I will deal with your problem in the very near future.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
04.10.2022, 10:38 #533
- 03.02.2006
- 51
- 17,200
- 8047
- 4221
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_705.exe
Check "Auto rotation to spot" or click here:
04.10.2022, 14:12 #534
- 16.04.2020
- 64
06.10.2022, 10:51 #535
- 16.04.2020
- 64
deleted
Последний раз редактировалось M0CGF; 06.10.2022 в 10:56.
06.10.2022, 12:23 #536
- 03.02.2006
- 51
- 17,200
- 8047
- 4221
06.10.2022, 15:07 #537
- 16.04.2020
- 64
Hi Alexei
I had the ERC guy remote into my set up today to check a few things, he found the following, I made the change to 14400 and it works OK.
"I tested the rotor function in LogHX.
The command-syntax for GS232 is correct but I found the bug in LogHX: The Baudrate chosen in SETUP – ROTOR SETUP is wrong.
If you choose 9600 Baud the real Baudrate is 4800
If you choose 14400 Baud the real Baudrate is 9600
If you choose 19200 Baud the real Baudrate is 14400"
08.10.2022, 12:49 #538
- 02.05.2021
- 51
- 6
Hi Alexei,
Do you think that it could be possible to add MULTIPSK from F6CTE (index) as an LogHX external program ?
73s Christian F8GHE
19.10.2022, 13:42 #539
- 03.02.2006
- 51
- 17,200
- 8047
- 4221
Thank you for help! Yes, problem is here - fixed. Try now:
http://rx4hx.qrz.ru/files/loghx/prer..._build_706.exe
I can't promise that it will be fast. But I will try to do it.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
26.10.2022, 01:27 #540
- 02.05.2021
- 51
- 6
