08.06.2020, 08:29 #991
- 08.06.2020
- 45
- 13
- 11
08.06.2020, 18:19 #992
- 24.09.2019
- Санкт-Петербург
- 34
- 174
- 26
08.06.2020, 18:23 #993
- 27.04.2020
- 6
- 53
08.06.2020, 19:43 #994
- 25.11.2019
- 17
Вентилятор мелковат, предусматривать конструкцию под 120 мм достаточный обдув и тихая работа. А то смысл звук на себя направлять и глушить вентилятором.
08.06.2020, 19:52 #995
- 24.09.2007
- Вязьма
- 795
- 980
- 269
Update Description:
This update is based on the function of version 1.74-beta, which mainly focuses on optimization with no functions added or deleted.
1. Fixed the problem that MIC Gain is relatively high
2. Added auto FFT scale
3. Added background VFO frequency display function under channel mode
4. Widened the maximum bandwidth of CW filter
5. Optimized the filter bandwidth/center frequency point adjustment and CW Tone adjustment range under CW mode ★ If CW Tone is adjusted under CW or CWR mode, the range of CW Tone is the upper and lower limits of filter under current mode ★ If CW Tone is not adjusted under CW or CWR mode, the range of CW Tone shall be within the upper and lower limits of filter under CW and CWR mode
6. Changed RF GAIN to directly act on receiving channel gain Adjustment range: 1~100% (default: 50%), corresponding gain (on the basis of receiving channel gain): -19.6~+20dB,step=0.4dB ★ Note: RF GAIN will influence the value of Table S and FFT
7. Added microphone filter of SSB mode to attenuate partial low frequency component of microphone signal and improve emission efficiency
8. Changed the color of lines in frequency spectrum picture into green and fill color into semitransparent green
9. Optimized the encoder to prevent it from interference or impulse as the first one
10. Optimized stack and enhanced the stability
11. Optimized the control characteristics of AGC and ALC
12. Fixed the bug of channel storage function
13. Fixed the spectrum display bug during emission
14. Fixed the bug of standing wave detection threshold
15. Fixed the problem of interrupted voice during low.
Вольный перевод:
Описание обновления:
Это обновление основано на функции версии 1.74-бета, которая в основном фокусируется на оптимизации без добавления или удаления функций.
1. Исправлена проблема, что MIC Gain относительно высока
2. Добавлена автоматическая шкала FFT
3. Добавлена функция отображения частоты VFO в фоновом режиме.
4. Увеличена максимальная пропускная способность CW фильтра
5. Оптимизирована настройка полосы пропускания фильтра / центральной частоты и диапазона регулировки CW Tone в режиме CW ★ Если CW Tone регулируется в режиме CW или CWR, диапазон CW Tone - это верхний и нижний пределы фильтра в текущем режиме ★ Если CW Тон не регулируется в режиме CW или CWR, диапазон CW Tone должен находиться в пределах верхнего и нижнего пределов фильтра в режиме CW и CWR
6. Изменен RF GAIN для непосредственного воздействия на усиление приемного канала. Диапазон регулировки: 1 ~ 100% (по умолчанию: 50%), соответствующее усиление (на основе усиления приемного канала): -19,6 ~ + 20 дБ, шаг = 0,4 дБ ★ Примечание : RF GAIN повлияет на значение таблиц S и FFT
7. Добавлен микрофонный фильтр режима SSB для ослабления частичной низкочастотной составляющей сигнала микрофона и повышения эффективности излучения
8. Изменил цвет линий на изображении частотного спектра на зеленый и закрасил полупрозрачный зеленый.
9. Оптимизировал кодировщик, чтобы предотвратить его помехи или импульс в качестве первого
10. Оптимизирован стек и улучшена стабильность
11. Оптимизированы характеристики управления AGC и ALC
12. Исправлена ошибка функции хранения каналов
13. Исправлена ошибка отображения спектра во время излучения
14. Исправлена ошибка порога обнаружения стоячей волны
15. Исправлена проблема прерванного голоса во время низкого
Для меня снова бесполезная прошивка - САТ так и не поправили.
08.06.2020, 20:05 #996
- 25.11.2019
- 17
Подскажите пожалуйста, при подключении оригинального USB в win7 не может драйвера найти, не работает корректно сериал порт.
Сталкивался кто-нибудь?
08.06.2020, 20:38 #997
- 08.06.2020
- 45
- 13
- 11
Антон, 3д печать
08.06.2020, 20:53 #998
- 24.09.2019
- Санкт-Петербург
- 34
- 174
- 26
08.06.2020, 21:45 #999
- 13.01.2019
- 133
- 138
- 83
08.06.2020, 23:20 #1000
- 24.09.2019
- Санкт-Петербург
- 34
- 174
- 26
Скачал, поставил.
Не вижу беты в названии файла (от 8.06. build004 release) и сходу вижу улучшения!
1. Наконец добавили мощность на настройку тюнера и теперь стоит ну прям почти идеально. Но почему то на диапазоне 80м мощность настройки 1.5 ватта, хотя строит корректнее, чем было. На других 3-4 ватта мощность настройки.
2. Поправили задержку перехода с передачи на прием при AGC-S, но AGC-A по прежнему=AGC-F.
Бегло прошёлся, пока каких то других косяков не выявил. Использую трансивер исключительно для HF SSB.
Подпираний в сигнале на малой мощности (1вт) мои корреспонденты не заметили. Видимо с ALC поработали.
09.06.2020, 09:42 #1001
- 08.06.2020
- 45
- 13
- 11
Интересно, когда нить они допилят шумоподавитель? Ноиз Бланкер там вообще же мертвый. Не возможно слушать! Разбаловал меня Малахит DSP.
09.06.2020, 10:40 #1002
- 03.03.2007
- 1,599
- 685
- 1101
Аналогично. Интересно , а добавить ключевание можно программно или требуются изменения в железе. Если этой функции не появится , не смотря на все достоинства аппарата буду от него отказываться, жаль конечно очень хороший экземпляр попался , да и задуман аппарат не плохо. Но увы , поскольку CW - основной мой вид . Невозможность подключения к контест логам и CWType без доп.шнурков и танцев с бубном для меня сводит на нет все его достоинства ((
И с этим трудно не согласитьсяСергей UR4IOR 73! [url]http://ur4ior.jimdo.com/[/url]
09.06.2020, 17:24 #1003
- 27.04.2020
- 6
- 53
получил сегодня трансивер.
Почему он такой маааленький??1 ))
Точнее маленький экранчик и маленькие кнопочки.
По видео-обзорам мне казалось, что раза в два больше должно быть
Проводки питания и разъём, конечно, "несерьёзные".
Сейчас нет готовой "инфраструктуры" для подключения. На выходных буду заниматься.Антон
09.06.2020, 22:00 #1004
- 08.06.2020
- 45
- 13
- 11
Сконстролил новую крутилку с микроподшипничком.
Видосик : https://youtu.be/KfjsMKOqDZI
10.06.2020, 08:31 #1005
- 27.04.2006
- Татарстан Russia
- 637
- 202
- 245
Приехал ко мне 2 экземпляр трансивера, первое что проверил как звучит телеграф, с этим все отлично никаких искажений, работает на прием хорошо.
Но мне "везет" пропажа чутья после перехода на передачу обнаружилась в аппарате. Изначально стояла 1.74 первая бетта. Обновился до последней 174 версии "стабильной". Практический все восстановилось и аппарат заработал как следует. Чувствительность не пропадает.
Но остался не большой косяк на диапазоне 160 метров. Если выключить трансивер на этом бенде и включить то чутья нет, но стоит перещелкнуть тангенту все восстанавливается. Но в любом случае этот аппарат ведет себя намного лучше. С последней прошивкой тюнер работает адекватно.RN4R
