ССЫЛКА 1 ССЫЛКА 2 на пару групп мордокниги по х6100.
Что пишут в релизе (сами гуглом переведёте же):
I did a Google Translate on the X6100 FW 1.1.6 change details file in the X6100 FW 1.1.6 Update Package that I downloaded earlier today. Its shown below. There was a several other files in Chinese that have related information "How to use the Bluetooth virtual serial port and the tools used:", "Added CI-V Commands" and "X6100 Firmware Update Tutorial". So all of this gives you an idea of what to expect. I've asked my contact if the actual update may be distributed or await its appearance on the typical Xiegu related web sites.
X6100_FW_V1.1.6-20221102001.zipX6100 Firmware Update Instructions >>> The latest version number: V1.1.6 >>> Last updated on: 2022.11.02
The firmware version number information after this update is as follows: (View in SYSTEM SETTING---SYSTEM INFO)
APP : V1.1.6 Nov 2 2022,13:10:22
BASE : V1.1.6 Nov 1 2022, 17:37:32
2022.11.03 Update details
1. Added some CI-V instruction sets. (For details, please refer to "X6100 Added CI-V Instructions" in the folder).
2. Added Bluetooth SPP, you can use FLRIG, Omni-Rig and other PC software to control X6100 wirelessly.
After the Bluetooth is connected to the computer, press the key combination Win+R, enter bthprops.cpl and press Enter, click "More Bluetooth Settings" in the pop-up interface,
In the pop-up "Bluetooth Settings" window, click the "COM Port" tab, the port named "X6100 Bluetooth 'Serial Port'" is the Bluetooth CI-V interface,
example:
Port Direction Name
COM3 outgoing X6100 Bluetooth 'Serial Port'
For the usage and configuration of the Bluetooth virtual serial port, please refer to the file "Bluetooth virtual serial port usage and tools" in the compressed package.
3. Fixed the problem that the fc marker on the spectrogram is wrong when the MODEM is turned on (for example, the CW mode will display 2 marker lines, but there can only be one)
4. Optimized the sd card flashing process, user data (channel data, recording data, configuration data) will not be deleted when flashing
5. Adjust the main interface display content
5.1 Added time display area, showing LOCAL TIME and UTC TIME respectively
5.2 Added RIT/XIT display area
5.3 Added time domain graphic display of demodulated signal (oscilloscope)
5.4 Added filter icon and filter group display
6. Added the automatic reference level of waterfall chart, which will be automatically adjusted under strong signal, and the signal can be seen more clearly
7. Corrected the Bluetooth connection algorithm to solve the problem that the interface cannot be started due to Bluetooth, and the interface has been waiting in circles
8. Fixed NTP time synchronization problem (NTP time synchronization needs to be able to access the Internet)
9. Display the MAC address in the title bar of the Bluetooth/WiFi setting menu, which is convenient for users to query
10. Optimized the operation logic of the time setting menu
11. Optimized FFT SPAN function, changed to 4 blocks: 100k, 50k, 25k, 12.5k
12. Adjust the operation logic of the flat menu, when pressing "MFK", select the current item to the "Quick Adjustment Tab" and return to the main window
Example 1: "TX POWER" is selected in "RADIO SETTING1", press "MFK", "TX POWER" is added to the "Quick Adjustment Tab" in the upper left corner
Example 2: "FFT SPAM" is selected in "DISPLAY SETTINGS", press "MFK", "FFT SPAM" is added to the "Quick Adjustment Tab" in the upper left corner
13. Optimized baseband AGC algorithm
1) AGC time constant is more accurate
2) The noise floor is very small when the antenna is not connected (except FM mode)
The modified algorithm has a higher recognition degree for small signals. If you feel that the waterfall chart is too blue, you can appropriately increase the WF REF parameter value in the DISPSETTING menu.
Вложение 330583 Вложение 330584
