12.02.2024, 06:42 #1Big Gun
- 24.09.2011
- 14,604
- 5057
- 5872
Xiegu X6200
X6200-Brochure-20231225-EN.pdf
The new Xiegu X6200 is an ultra-portable direct sampling SDR transceiver for HF and 6m with additional receive capability in the VHF Air band and wide FM receive in the FM broadcast band.
Xiegu X6200 Key Features
HF/50MHz all-mode
8 W transmit power with external power source, 5 W with internal battery
4″ high-resolution color screen, 800*480 pixels resolution
Detachable battery pack
Built-in efficient automatic antenna tuner
Integrated SWR scanner
Voice memory keyer
CW memory keyer
Integrated USB line control/transmission, built-in sound card
Remote control support
Wireless FT8 operation
WFM broadcast RX
Aviation band RX
Xiegu X6200 General Specifications
Frequency coverage: 0,5-30+50-54MHz (Transmit in Ham Bands)
Operating modes: USB/LSB (J3E), CW (A1A), FM (F3E), RTTY (F1B), AM (A3E)
Minimum Frequency Step: 1 Hz
External power supply voltage: DC9-15V
Frequency stability: ±1ppm within 20 minutes after startup
Antenna Impedance: 50 Ohm
Antenna connector type: BNC
Operating temperature range: 0C to +50C
Current consumption RX: <65o mA, TX: 3,5A
Xiegu X6200 Receiver Specifications
Frequency coverage:
0,5-30+50-54MHz
88~108MHz (FM broadcast)
108~136MHz (aviation band)
Receive sensitivity (10dBS/N)
(PRE=on, ATT=off, NB=off,NR=off, SSB/CW/AM = 10dB S/N, FM = 12dB SINAD)
0,55-1,79 MHz AM: 10 uV
1,8-30 MHz SSB/CW 0.20 uV, AM 2uV
50-54 MHz FM 0.2 uV AM 2uV
88-108 Wide FM 5uV
Audio output: 0,45 (4 Ohm ≥10% THD)
MDS: -138 dBm
Xiegu X6200 Transmitter Specifications
Frequency range
1.8~2.0 MHz
3.5~3.9 MHz
5.3515~5.3665 MHz
7.0~7.2 MHz
10.1~10.15 MHz
14.0~14.35 MHz
18.068~18.168 MHz
21.0~21.45 MHz
24.89~24.99 MHz
28.0~29.7 MHz
50~54 MHz
Output Power, external power: 8W +/- 1dB
Output Power, internal battery: 5W +/- 1dB
Spurious suppression: 1.8~29.6MHz: ≥50dB
50-54 MHz ≥60 dB
Carrier suppression: ≥50dB
SSB Frequency Response: 300-2700Hz (-6dB)
FM Modulation Swing; +/- 5kHz
Mic Impedance: o,2-10k
Antenna tuner tuning impedance range: 20-175 Ohm
Antenna tuner initial tuning time: ≥ 10s
Antenna tuner memory recall time ≥ 0.1s
Xiegu X6200 Wireless network/Bluetooth
Wireless LAN standard: IEEE802.11b/g/n
Authentication and encryption: WEP (64/128bit)
WPA-PSK(TKIP)
WPA2-PSK(AES)
Frequency band: 2.4G
Bluetooth version: 4.0
Dimensions: 200 x 89 x 51 mm
Weight: 880 g (radio unit only)
Xiegu X6200 In the Box
X6200 radio unit complete with antenna tuner and rechargeable battery
Microphone with backlit remote control keypad
Serial cable for PC connection
12 Volt DC power cord
English manual
Xiegu Service Card
Xiegu X6200 Suggested Accessories
XPA125B 100W Solid State Linear Amplifier
L4001 amplifier control cable for XPA125B
UHF to BNC adapter for connecting antennas with UHF connector
Portable AntennasАлександр, UA8U (ex. RZ9UI, RA9UGR)
12.02.2024, 06:52 #2Покинул форум
- 10.07.2005
- 47
- 5,454
- 4757
- 2906
А что без фото?
«Знающий не говорит, говорящий не знает» (Лао Цзы)
12.02.2024, 06:56 #3Big Gun
- 24.09.2011
- 14,604
- 5057
- 5872
Дима, не проснулся? См. брошюру.
12.02.2024, 06:58 #4Покинул форум
- 10.07.2005
- 47
- 5,454
- 4757
- 2906
Так брошюру скачать надо, а картинку сразу видно
12.02.2024, 06:58 #5Big Gun
- 20.01.2004
- Башкортостан
- 7,889
- 4470
- 3146
Трансивер превращается, трансивер превращается, превращается трансивер - в коротковолновый смартфон!
12.02.2024, 07:02 #6
12.02.2024, 07:17 #7Покинул форум
- 10.07.2005
- 47
- 5,454
- 4757
- 2906
Посмотрел в брошюре - фото чёрно-белые, а так сразу видно - продолжение "шести сотого"
12.02.2024, 07:25 #8Very High Power
- 18.06.2004
- Курган
- 4,936
- 3829
что то в описании нигде не увидел DDC/DUC. значит какой то апгрейд 6100...
73! Андрей aka Модест Петрович. Не член и не многочлен никаких клубов.
12.02.2024, 07:28 #9Big Gun
- 24.09.2011
- 14,604
- 5057
- 5872
Пишут: direct sampling SDR transceiver
12.02.2024, 07:33 #10Very High Power
- 18.06.2004
- Курган
- 4,936
- 3829
в PDF-овском файле не нашел ничего про дайрект сэмплинг.
мож смотрел не внимательно...73! Андрей aka Модест Петрович. Не член и не многочлен никаких клубов.
12.02.2024, 07:39 #11Big Gun
- 24.09.2011
- 14,604
- 5057
- 5872
12.02.2024, 07:50 #12Very High Power
- 18.06.2004
- Курган
- 4,936
- 3829
может мы разные PDF файлы смотрим?
я тот, который ты выложил. нет там ни слова про дайрект сэмплинг.73! Андрей aka Модест Петрович. Не член и не многочлен никаких клубов.
12.02.2024, 07:56 #13Big Gun
- 24.09.2011
- 14,604
- 5057
- 5872
Информация моего предыдущего сообщения с их сайта. Трудно их понять, без "пузыря".
12.02.2024, 08:17 #14
12.02.2024, 08:33 #15
11Спасибо
