Показано с 1 по 15 из 39
Тема: Xiegu X6200
    24.09.2011
    14,695
    5074
    5900
    Xiegu X6200
    X6200-Brochure-20231225-EN.pdf
    The new Xiegu X6200 is an ultra-portable direct sampling SDR transceiver for HF and 6m with additional receive capability in the VHF Air band and wide FM receive in the FM broadcast band.
    Xiegu X6200 Key Features
    HF/50MHz all-mode
    8 W transmit power with external power source, 5 W with internal battery
    4″ high-resolution color screen, 800*480 pixels resolution
    Detachable battery pack
    Built-in efficient automatic antenna tuner
    Integrated SWR scanner
    Voice memory keyer
    CW memory keyer
    Integrated USB line control/transmission, built-in sound card
    Remote control support
    Wireless FT8 operation
    WFM broadcast RX
    Aviation band RX
    Xiegu X6200 General Specifications
    Frequency coverage: 0,5-30+50-54MHz (Transmit in Ham Bands)
    Operating modes: USB/LSB (J3E), CW (A1A), FM (F3E), RTTY (F1B), AM (A3E)
    Minimum Frequency Step: 1 Hz
    External power supply voltage: DC9-15V
    Frequency stability: ±1ppm within 20 minutes after startup
    Antenna Impedance: 50 Ohm
    Antenna connector type: BNC
    Operating temperature range: 0C to +50C
    Current consumption RX: <65o mA, TX: 3,5A
    Xiegu X6200 Receiver Specifications
    Frequency coverage:
    0,5-30+50-54MHz
    88~108MHz (FM broadcast)
    108~136MHz (aviation band)
    Receive sensitivity (10dBS/N)
    (PRE=on, ATT=off, NB=off,NR=off, SSB/CW/AM = 10dB S/N, FM = 12dB SINAD)
    0,55-1,79 MHz AM: 10 uV
    1,8-30 MHz SSB/CW 0.20 uV, AM 2uV
    50-54 MHz FM 0.2 uV AM 2uV
    88-108 Wide FM 5uV
    Audio output: 0,45 (4 Ohm ≥10% THD)
    MDS: -138 dBm
    Xiegu X6200 Transmitter Specifications
    Frequency range
    1.8~2.0 MHz
    3.5~3.9 MHz
    5.3515~5.3665 MHz
    7.0~7.2 MHz
    10.1~10.15 MHz
    14.0~14.35 MHz
    18.068~18.168 MHz
    21.0~21.45 MHz
    24.89~24.99 MHz
    28.0~29.7 MHz
    50~54 MHz
    Output Power, external power: 8W +/- 1dB
    Output Power, internal battery: 5W +/- 1dB
    Spurious suppression: 1.8~29.6MHz: ≥50dB
    50-54 MHz ≥60 dB
    Carrier suppression: ≥50dB
    SSB Frequency Response: 300-2700Hz (-6dB)
    FM Modulation Swing; +/- 5kHz
    Mic Impedance: o,2-10k
    Antenna tuner tuning impedance range: 20-175 Ohm
    Antenna tuner initial tuning time: ≥ 10s
    Antenna tuner memory recall time ≥ 0.1s
    Xiegu X6200 Wireless network/Bluetooth
    Wireless LAN standard: IEEE802.11b/g/n
    Authentication and encryption: WEP (64/128bit)
    WPA-PSK(TKIP)
    WPA2-PSK(AES)
    Frequency band: 2.4G
    Bluetooth version: 4.0
    Dimensions: 200 x 89 x 51 mm
    Weight: 880 g (radio unit only)
    Xiegu X6200 In the Box
    X6200 radio unit complete with antenna tuner and rechargeable battery
    Microphone with backlit remote control keypad
    Serial cable for PC connection
    12 Volt DC power cord
    English manual
    Xiegu Service Card
    Xiegu X6200 Suggested Accessories
    XPA125B 100W Solid State Linear Amplifier
    L4001 amplifier control cable for XPA125B
    UHF to BNC adapter for connecting antennas with UHF connector
    Portable Antennas
    Покинул форум Аватар для RW4C
    10.07.2005
    47
    5,454
    4760
    2906
    А что без фото?
    24.09.2011
    14,695
    5074
    5900
    Дима, не проснулся? См. брошюру.
    10.07.2005
    47
    5,454
    4760
    2906
    Так брошюру скачать надо, а картинку сразу видно
    Big Gun
    20.01.2004
    Башкортостан
    7,909
    4479
    3151
    Трансивер превращается, трансивер превращается, превращается трансивер - в коротковолновый смартфон!
    24.09.2011
    14,695
    5074
    5900
    Виден явный прогресс, у XIEGU.
    Так она в первом сообщении. И там не только фото но и .....
    10.07.2005
    47
    5,454
    4760
    2906
    Посмотрел в брошюре - фото чёрно-белые, а так сразу видно - продолжение "шести сотого"
    18.06.2004
    Курган
    4,946
    3834
    что то в описании нигде не увидел DDC/DUC. значит какой то апгрейд 6100...
    24.09.2011
    14,695
    5074
    5900
    Пишут: direct sampling SDR transceiver
    18.06.2004
    Курган
    4,946
    3834
    в PDF-овском файле не нашел ничего про дайрект сэмплинг.
    мож смотрел не внимательно...
    24.09.2011
    14,695
    5074
    5900
  12. #12
    18.06.2004
    Курган
    4,946
    3834
    может мы разные PDF файлы смотрим?
    я тот, который ты выложил. нет там ни слова про дайрект сэмплинг.
  13. #13
    24.09.2011
    14,695
    5074
    5900
    Информация моего предыдущего сообщения с их сайта. Трудно их понять, без "пузыря".
  14. #14
    Модератор Аватар для UN7JID
    18.05.2007
    Усть-Каменогорск
    49
    2,466
    1400
    1147
    Очень похоже.... Навесили дополнительно рюшечек и бантиков, полноценное УКВ не смогли добавить... Интересно ценник какой будет?
    73. Валерий UN7JID!
  15. #15
    10.07.2005
    47
    5,454
    4760
    2906
    Пишут, что на Алибабе по предзаказу цена 999$.
  1. Xiegu G90
    от RA4RAK в разделе Xiegu
    Ответов: 2926
    Последнее сообщение: 15.03.2026, 16:42
  2. Xiegu GSOC
    от Valeri53 в разделе Xiegu
    Ответов: 22
    Последнее сообщение: 30.03.2024, 11:03
  3. XieGu X108G
    от RU2FB в разделе Xiegu
    Ответов: 212
    Последнее сообщение: 24.03.2024, 22:19
  4. Ответов: 47
    Последнее сообщение: 07.01.2021, 16:28
  5. XieGu X1M
    от UB6LOT в разделе Xiegu
    Ответов: 7
    Последнее сообщение: 31.05.2017, 00:07
