03.11.2010, 14:53 #1nomade
- 29.04.2008
- Донецк
- 48
- 1,910
- 624
- 2321
Как в США наказывают радиолюбителей
Two US Attorneys have filed a Complaint (see below) in US District Court against Glenn Baxter, K1MAN, for not responding appropriately to an order that he pay a $21,000 fine for violating several sections of Part 97. The Complaint was filed October 25 in the US District Court for Maine.
The civil action was brought under Section 503(b) of the Communications Act of 1934, as amended, and Section 1.80 of the FCC Rules and Regulations.
The fine had been levied, according to the Complaint, “for defendant’s willful and repeated violations of Sections 97.101(d) [commencing transmissions on top of existing communications on 3.890 MHz] and 97.113(a)(3) [transmitting communications in which the station licensee or control operator has a pecuniary interest] of the Commission’s Rules, and for the defendant’s willful violation of Section 97.105(a) [exercising control over station] and 97.113(b) [broadcasting] of the Rules, and for failure to file requested information pursuant to an Enforcement Bureau directive.” [information in brackets added]
The Complaint seeks to force payment of the $21,000 fine along with a filing fee and “such other and further relief as the Court deems just and proper.”
Additional FCC actions are anticipated.
http://www.arrl.org/news/view/us-cha...re-to-pay-fine
Если нужен перевод, чуть позже накропаю.73! Стас US4IPQ
03.11.2010, 15:19 #2Silent Key
- 22.03.2006
- 73
- 1,454
- 195
Круто! это же в переводе на наши получается более 600тыс. руб
Последний раз редактировалось UI9O; 03.11.2010 в 15:23.
[I][COLOR="#808080"]Николай, UI9O[/COLOR][/I]
03.11.2010, 15:29 #3Радиолюбитель
- 22.11.2009
- 9,911
- 2930
- 2312
Переведен онлайн-переводчиком:
Два американских Поверенных подали Жалобу (см. ниже) в американском Окружном суде против Гленна Бэкстера, K1MAN, для того, чтобы не отвечать соответственно на заказ, что он платит штраф в размере 21 000$ для того, чтобы нарушить несколько разделов Части 97. Жалоба была подана 25 октября в американском Окружном суде для Мэна.
Гражданский процесс был принесен согласно Разделу 503 (b) закона о Коммуникациях 1934, как исправлено, и Разделу 1.80 Правил и норм FCC.
Штраф был наложен согласно Жалобе, “для преднамеренных и повторных нарушений ответчиком Секций 97.101 (d) [начинающий передачи сверху существующих коммуникаций на 3.890 МГц] и 97.113 (a) (3) [передача коммуникаций, в которых у станционного лица, имеющего патент или оператора контроля есть финансовый интерес] Правил Комиссии, и для преднамеренного нарушения ответчиком Раздела 97.105 (a) [осуществляющий контроль над станцией] и 97.113 (b) [радиовещание] Rules, и для отказа подать требуемую информацию в соответствии с директивой Бюро Осуществления.” [информация, в скобках добавленная]
Жалоба стремится вызвать оплату штрафа в размере 21 000$ наряду с платой за регистрацию и “таким другим и дальнейшим облегчением, поскольку Суд считает только и надлежащий.”
Ожидаются дополнительные действия FCC.С уважением Анатолий, 73!
03.11.2010, 15:30 #4High Power
- 20.10.2006
- Жуковский МО
- 562
- 167
- 269
да поможет вам ПРОМТ
переводит конечно криво. но суть понятна...
RU3DUC
03.11.2010, 22:43 #5Very High Power
- 18.09.2009
- все время в экспедициях
- 4,133
- 1504
- 962
Жозенько но правильно. Я считаю, что так и надо. Не для того существует любительское радио, чтобы мешать другим.
Добавлено через 2 минуты
И я уверен, что это он туде не один раз влез, ибо всякий может ошибиться, например спьяну... Он там наверняка долго фигней страдал.Последний раз редактировалось RU2FB; 03.11.2010 в 22:43. Причина: Добавлено сообщение
Олег RU2FB
03.11.2010, 22:48 #6
У нас бы так кого, за "киловатты" с "полосой".... Да на 600 тыс.
И в эфире - чистота-а-а....R3XD :: Стремление субъекта к порядку приводит к всеобщему бардаку...
03.11.2010, 23:05 #7Радиолюбитель
- 22.11.2009
- 9,911
- 2930
- 2312
04.11.2010, 07:10 #8High Power
- 13.04.2009
- Минск, Марьина Горка
- 889
- 417
- 277
Лет так с десять назад один америкенНАМ(потом его лишили лицензии,но он продолжал)так достал все соответствующие службы,что об этом писали в прессе и т.д.Тоже штрафовали ,помнится,тыщ на 10,но то был реально больной человек.
Грустно,что иной раз кого-то слушаешь из тутейших,и создается то же впечатление.
04.11.2010, 07:56 #9Big Gun
- 02.01.2009
- SA-43
- 11,123
- 5513
- 2775
Вот оно золотое дно для Роскомнадзора. Даже не надо на любительские диапазоны заходить. На 2.0-3.0 MHz поле не паханое!
73. Сергей.
05.11.2010, 20:33 #10TX SWL
- 24.12.2008
- Volgograd
- 3,305
- 1747
- 2563
05.11.2010, 22:01 #11Silent Key
- 13.01.2003
- Жабомишодраківка
- 13,850
- 3918
- 1415
05.11.2010, 22:23 #12Радиолюбитель
- 22.11.2009
- 9,911
- 2930
- 2312
Игорь, я что-то не вьехал к чему эта таблица, получается из нее что обратная зависимость например для SSB при уровне -35dB полоса 3,75 кГц; а при уровне -60dB 16,2 кГц???
И когда приводите документ, приводите его полностью, а то из этого клочка понять ничего нельзя.С уважением Анатолий, 73!
05.11.2010, 22:24 #13Silent Key
- 13.01.2003
- Жабомишодраківка
- 13,850
- 3918
- 1415
Читайте журнал РАДИО !!! Внизу справа - написано какой .
-73- Игорь
06.11.2010, 01:24 #14Радиолюбитель
- 22.11.2009
- 9,911
- 2930
- 2312
Прочитали! для информации: В таблице №1 приведены значения "контрольной" (нормированной) полосы частот при различных видах излучения.
В таблице №2 приведены нормированные значения полосы частот при внеполосных излучениях на соотв. уровнях, но только мне кажется что в ней какая-то ошибка.
Связи между мощностью передатчика и его шириной полосы частот в этой статье не прослеживаются.С уважением Анатолий, 73!
06.11.2010, 11:42 #15Big Gun
- 20.09.2005
- 79
- 8,283
- 3864
- 3486
Насчет контроля за эфиром у нас, в частности в ЦФО.
Из Москвы в местный Роскомнадзор пришло сообщение о работе любительской радиостанции RTTY на чатоте 13,170 МГц. Работа радиостанции зафиксирована документально с двух контрольных пунктов, приводиться позывной и передаваемый текст. Когда стали разбираться выяснилось, что товарищ использует самодельный трансивер с выходнай мощностью 10 Вт (в РА стоит транзистор). А теперь самое интересное, на этой частоте было его побочное излучение, когда его измерили с помощью фирменного анализатора НР, то уровень оказался - 10 dB меньше основного сигнала.
Выводы насчет контроля эфира делайте сами.Последний раз редактировалось R3MM; 06.11.2010 в 11:46.
Евгений.
Практика - критерий истины.
В эфире практикую с 1966 г.
