Показано с 1 по 5 из 5
    Standart Power Аватар для RX3AOE
    04.08.2006
    Москва, Россия
    390
    27
    25
    Три новых APRS спутника уже на орбите
    Провёл QSO c Jerry (k6koz), вот что он сообщил:
    2006-дек-21 19:30 [33] Hello Yuri, How are you?
    2006-дек-21 19:32 [34] Yes I did, thanks you very much, did you receive mine?
    2006-дек-21 19:34 [35] Pretty good mail delivery for a change!! so how have u been?
    2006-дек-21 19:36 [36] are u at home in Moscow?
    2006-дек-21 19:39 [37] I am doing okay, I will try and check your server out.
    2006-дек-21 19:40 [38] The weather in Southern California is arounf 70 degrees F
    2006-дек-21 19:42 [40] are you flying on the Holidays?
    2006-дек-21 19:45 [41] thats good, nice to be with family!
    2006-дек-21 19:45 [42] I will be doing the same here
    2006-дек-21 19:47 [43] I have been doing a little Satellite tracking
    2006-дек-21 19:47 [44] the last week or so.
    2006-дек-21 19:49 [45] no, a new one that was just deployed called RAFT
    2006-дек-21 19:50 [46] Downlink is 145.825 MHz.
    2006-дек-21 19:50 [47]
    2006-дек-21 19:50 [48] there are 2 more being deployed today or tomorrow
    2006-дек-21 19:51 [49] called ANDE & NMARS
    2006-дек-21 19:51 [50] Ande is on 145.825 & Nmars is on 10 Meters
    2006-дек-21 19:51 [51] Yes it is APRS
    2006-дек-21 19:52 [52] I am using a program called ALOGGER
    2006-дек-21 19:52 [53] and it works really good
    2006-дек-21 19:53 [54] it is a download from the Internet
    2006-дек-21 19:56 [55] Yes, http://cadigweb.ew.usna.edu/pcsat
    2006-дек-21 19:57 [56] once you get in to the site, you will have to browse around
    2006-дек-21 19:57 [57] a little bit until you find whagt you are looking for
    2006-дек-21 19:58 [58] there is one section that gives you instructions on
    2006-дек-21 19:58 [59] setting up a SATGATE.
    2006-дек-21 20:00 [60] DID U GET ALL THAT?
    2006-дек-21 20:03 [61] Yuri, I have to go for now, I will give you a call back
    2006-дек-21 20:04 [62] in the next day or 2 when you return from your next job
    2006-дек-21 20:04 [63] I have some errands to run, it is 9:00 am here
    2006-дек-21 20:05 [64] regards & 73 de K6KOZ, "Koz".
    2006-дек-21 20:05 [65] Merry Xmas & Happy New Year!!!
    Зайдите на сайт посмотрите. Использует Jerry программу ALOGGER.
    ANDE Side A: 145.825 Digipeater up/downlink 1200 baud packet
    ANDE Side B: 145.825 downlink (backup to side A only)
    RAFT System: 145.825 Digipeater up/downlink 1200 baud packet
    RAFT PSK-31: 28.120 HF PSK-31 uplink -downlink on 145.825
    Скачать видео старта: http://www.ew.usna.edu/~bruninga/cra...T%20Deploy.wmv - 5Mb
    Если DialUp то здесь: http://www.ew.usna.edu/~bruninga/cra...%20DeployZ.wmv - 600Kb
    Very High Power Аватар для DL8RCB
    21.10.2005
    Marktplatz 5, 94157, Perlesreut, Германия
    80
    2,823
    30
    14
    Цитата Сообщение от RX3AOE
    ничего не понял пробовал посмотреть ссылки "битые"к чему бы это_?
    04.08.2006
    Москва, Россия
    390
    27
    25
    попробуй сменить руку....
    Качаем Alogger v2.04: http://www.billdiaz.dynip.com/Alogger204.zip
    Setup Satgate используя Alogger: http://eng.usna.navy.mil/~bruninga/pec/PC2satgateA.txt
    Сейчас у меня нет времени искать, может кто найдёт и подскажет где взять "кеплеры" для этих игрушек?
    Admin отруби мне голову если ссылки битые!
    21.10.2005
    80
    2,823
    30
    14
    аналогичный случай был в городе Канатопе:
    корова упала и рога отвалились
ID:	5017   Нажмите на изображение для увеличения.
    21.10.2005
    80
    2,823
    30
    14
    вот таблица с официального сайта показывающего sat работающий APRS
  1. Программа новых MOTOROLA GP-340
    от olegkad в разделе УКВ: MOTOROLA
    Ответов: 7
    Последнее сообщение: 20.02.2008, 17:19
  2. Радио со спутника
    от HA5JAN в разделе Радио и ТВ вещание
    Ответов: 16
    Последнее сообщение: 17.02.2008, 22:55
  3. Подключение новых БП в PC
    от UA9QAQ в разделе Компьютеры и сети
    Последнее сообщение: 03.10.2006, 16:58
  4. ИК диапазон со спутника
    от RA3POD в разделе Космические виды связей
    Последнее сообщение: 22.09.2006, 01:01
