Показано с 1 по 15 из 35
    Very High Power Аватар для EW6BN
    15.08.2006
    50
    1,502
    735
    644
    2) Спутник PCSAT-1 aka OSCAR-44 (RX/TX)
    SATELLITE DWNLNK UPLINK DIGI-PATH DESCRIPTION
    PCSAT-1 145.825 145.828 ARISS,APRSAT,WIDEn-N packet to be gated to the FINDU system more easily.
    Вот понаблюдал немного сегодня на отремонтированном контроллере KPC-3+ за спутником NO-44 (PCSAT-1):
    16:48:20R EA7AHA>CQ,PCSAT-1* <UI Len=22>:PSE QSL if QSO via SAT
    16:48:21R EA7AHA>APU25N,PCSAT-1* <UI C Len=17>::GM4VYU :73{97
    16:48:23R UT4QU>CQ,PCSAT-1* <UI Len=60>::EA7AHA :Hello de Eugen. Ukraine kn77nu list@optima.com.ua
    16:48:28R UT4QU>CQ,PCSAT-1* <UI Len=60>::EA7AHA :Hello de Eugen. Ukraine kn77nu list@optima.com.ua
    16:48:36T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
    16:49:44T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
    16:49:50T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
    16:50:06R DF9EY>CQ,PCSAT-1* <UI C Len=38>:=/4:P#P5{0- BHello to all de Manfred
    16:50:18R MM0HMM-1>APU25N,PCSAT-1*,APRSAT,WIDE <UI C Len=42>:=5624.57N/00528.60W>73s,De David 145.825
    16:50:21R GM4WMM-7>U9PTQQ,PCSAT-1*,WIDE,PCSAT-1 <UI R Len=39>:'yY'l R/]Stuart Orkney Islands IO89LB
    16:50:31R UT4QU>CQ,PCSAT-1* <UI Len=35>::SM7KUQ :de UT4QU bye and best 73
    16:50:37T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
    16:50:54R UT4QU>CQ,PCSAT-1* <UI Len=35>::SM7KUQ :de UT4QU bye and best 73
    16:50:57R IW4EPP>APRS,PCSAT-1* <UI Len=27>::BLN :73 at all folks
    16:51:00R PCSAT-1>APRS1 <UI Len=67>::BLN1PCSAT:Alive and well during full sun period for a week or so.
    16:51:44R PCSAT-1>BEACON,SGATE <UI Len=42>:T#115,132,135,136,120,214,00111111,0110,1
    16:51:45R IW4EPP>APRS,PCSAT-1* <UI Len=54>::BLN :Packet Mail : IW4EPP@I4UKI.#MO.IEMR.ITA.EU
    16:51:54R 2E0EXL>APRS,PCSAT-1*,WIDE <UI Len=62>:=5125.04N/00007.99W-73' Via Satellite Phil , London . {UISS50}
    16:52:00R UT4QU>CQ,PCSAT-1* <UI Len=35>::EA7AHA :de UT4QU bye and best 73
    Последний раз редактировалось UA3IRS; 23.12.2007 в 22:12.
    73! Юрий EW6X (ex EW6BN) Если не QRP, то 100Вт@палка/верёвка
    Very High Power Аватар для DL8RCB
    21.10.2005
    Marktplatz 5, 94157, Perlesreut, Германия
    80
    2,823
    30
    14
    Цитата Сообщение от EW6BN
    Вот понаблюдал немного сегодня на отремонтированном KPC-3+ NO-44
    а на передачу можешь?
    15.08.2006
    50
    1,502
    735
    644
    Нету пока антенны, хотя пурскал и так, но...
    И надо вообще-то UISS, а там был UI32
    21.10.2005
    80
    2,823
    30
    14
    вообще-то UISS
    да она UISS ,удобна в смысле оперативности, но тогда ставь sv2agw драйвер
    15.08.2006
    50
    1,502
    735
    644
    Да уже поставил, может сегодня послушаю сатты.
    А AGW и с кантрониксами дружит, только что грядка большая получается.
    21.10.2005
    80
    2,823
    30
    14
    для kpc-3, что выбираешь КАМ__?
    и еще вопрос
    TNC2S-SYMEK AFSK 1200/2200 + 300 baud ,650/850Hz если КВ какую частоту выставлять__?
    15.08.2006
    50
    1,502
    735
    644
    2DL8RCB
    Анатолий. был пост, но вы его наверное удалили, всё-таки отвечу.
    В AGW есть KPC-3Plus.
    А по настройке расчёт следующий:
    Стандартом на КВ, как правило, являются частоты тонов "0"= 1600 Гц, "1"= 1800 Гц, т.е. Средняя = 1700 Гц.
    Итак, на 30м указаны в источниках частота 10147,6 USB, т.о. 10147600+1700=10149300 Гц - это средняя частота излучения в эфире.
    Далее в вашем примере 0=650 Гц, 1=850 Гц, средняя = 750 Гц. Отсюда находим 10149300-750=10148550 Гц - ваша искомая чатота настройки трансивера в USB.
    С LSB наоборот, например LSB 7035000. 7035000-1700=7033300 Гц. Отсюда для вашей настройки TRX 7033300+750=7034050 Гц.
    Для других диапазонов аналогично.
    Ну и для точной подстройки можно попробовать покрутить +-50Гц.
    P.S. Проскочил сегодня разок через PCSAT-1(NO-44)
    EW6BN>CQ,PCSAT-1*,qAr,DK3WN-1:=5532.39N/02837.37E-Yuri, KO45hm via SAT {UISS50}
    15.08.2006
    50
    1,502
    735
    644
    via PCSAT-1
    Вчера сотворил обычный J-pole на двойку, поставил его просто на балконе третьего этажа кирпичной пятиэтажки.
    Вот утром провёл два QSO через NO-44 c MM0HMM-1 и UT4QU.
    Пока ещё опыта маловато, не приспособился к UISS, но начало положено :-)
    P.S. а вот и чудо антенна :-))
ID:	5294   Нажмите на изображение для увеличения.
    Вложения Вложения
    Standart Power Аватар для RX3AOE
    04.08.2006
    Москва, Россия
    390
    27
    25
    Юрий молодец! А с крос яги и xxxxx сможет. Я с Миром работал тоже с балкона на кусок провода от утюга - это штырь и два противовеса - усы от комнатной телевизионной антенны TV "Юность". Вот такая рогатина была закреплена к потолку балкона следующего этажа.
    Юрий, искал в аське, хотел спросить, что всё же было с KPC3?
    А вот, всё нашёл http://forum.qrz.ru/thread12900.html вопросов нет.
    Всех с НОВЫМ ГОДОМ!!!!!!
    P.S. А эта антенна на какой диапазон? 8-)
    15.08.2006
    50
    1,502
    735
    644
    Да, голь на выдумки хитра... :-)
    А это параболла 10ГГц. :-))
    21.10.2005
    80
    2,823
    30
    14
    Цитата Сообщение от UA1WCF Посмотреть сообщение
    Вчера вечером точно ISS не было слышно
    __________________
    давай сверим время пролета орбит!
    время специально ставлю мск итак 44 - оскар у меня 15 23 низкая орбитаб но в москве где-то через 4-5 минут
    посмотри совпадают ли время орбит
    Изображения Изображения
  12. #12
    21.10.2005
    80
    2,823
    30
    14
    1) О спутнике - http://www.ew.usna.edu/~bruninga/pcsat.html.
    2) Зайдя по этой ссылке http://www.findu.com/cgi-bin/pcsat.cgi? можно видеть какие из них "активны".
    3) Кликнув мышей по строчке увидим время последней орбиты Click here to see times in absolute UTC.
    В качестве примера смотрите сегодняшнюю последнюю орбиту:
  13. #13
    21.10.2005
    80
    2,823
    30
    14
    Цитата Сообщение от DL8RCB Посмотреть сообщение
    ANDE, PCsat end Raft
    Денис привет! прими поздравления, я прозевал вчера и не посмотрел твой "пакет" если стянул кинь мне на мыло
    http://www.findu.com/cgi-bin/find.cgi?RK9LWA
    Добавлено через 1 час 1 минуту
    вот теперь и я принял сегодня PCSAT-1 вот твоя сегодня орбита
    20071106062849 : RK9LWA]UWPY57,PCSAT-1*,WIDE2-1,qAo,YO8SSQ:']9l -/]TM-D700E
    не совсем понятна строчка если не лень напиши что прописано в кенвуде
  14. #14
    21.10.2005
    80
    2,823
    30
    14
    сегодняшная орбита pcsat-1
  15. #15
    21.10.2005
    80
    2,823
    30
    14
    Последний раз редактировалось DL8RCB, 08.11.2007 в 08:29.
    сегодня до смены символа
  1. Спутник 'Ресурс-ДК'
    от UA3IRS в разделе APRS: Аппаратура
    Ответов: 7
    Последнее сообщение: 15.09.2006, 07:27
  2. PCSat для APRS
    Последнее сообщение: 06.12.2005, 17:18
  3. Спутник
    от alex_x в разделе Космические виды связей
    Последнее сообщение: 16.03.2003, 14:31
  4. Cпутник PCSAT (NO-44)
    от Andrew_Kr в разделе Старые темы
    Последнее сообщение: 10.05.2002, 16:52
