10.01.2007, 18:05 #1Very High Power
- 15.08.2006
- 1,491
- 732
- 633
2) Спутник PCSAT-1 aka OSCAR-44 (RX/TX)
SATELLITE DWNLNK UPLINK DIGI-PATH DESCRIPTION
PCSAT-1 145.825 145.828 ARISS,APRSAT,WIDEn-N packet to be gated to the FINDU system more easily.
Вот понаблюдал немного сегодня на отремонтированном контроллере KPC-3+ за спутником NO-44 (PCSAT-1):
16:48:20R EA7AHA>CQ,PCSAT-1* <UI Len=22>:PSE QSL if QSO via SAT
16:48:21R EA7AHA>APU25N,PCSAT-1* <UI C Len=17>::GM4VYU :73{97
16:48:23R UT4QU>CQ,PCSAT-1* <UI Len=60>::EA7AHA :Hello de Eugen. Ukraine kn77nu list@optima.com.ua
16:48:28R UT4QU>CQ,PCSAT-1* <UI Len=60>::EA7AHA :Hello de Eugen. Ukraine kn77nu list@optima.com.ua
16:48:36T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
16:49:44T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
16:49:50T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
16:50:06R DF9EY>CQ,PCSAT-1* <UI C Len=38>:=/4:P#P5{0- BHello to all de Manfred
16:50:18R MM0HMM-1>APU25N,PCSAT-1*,APRSAT,WIDE <UI C Len=42>:=5624.57N/00528.60W>73s,De David 145.825
16:50:21R GM4WMM-7>U9PTQQ,PCSAT-1*,WIDE,PCSAT-1 <UI R Len=39>:'yY'l R/]Stuart Orkney Islands IO89LB
16:50:31R UT4QU>CQ,PCSAT-1* <UI Len=35>::SM7KUQ :de UT4QU bye and best 73
16:50:37T EW6BN>APU25N,WIDE2-2 <UI C Len=53>:=5532.39N/02837.37E-Yuri, Novopolotsk KO45hm {UIV32}
16:50:54R UT4QU>CQ,PCSAT-1* <UI Len=35>::SM7KUQ :de UT4QU bye and best 73
16:50:57R IW4EPP>APRS,PCSAT-1* <UI Len=27>::BLN :73 at all folks
16:51:00R PCSAT-1>APRS1 <UI Len=67>::BLN1PCSAT:Alive and well during full sun period for a week or so.
16:51:44R PCSAT-1>BEACON,SGATE <UI Len=42>:T#115,132,135,136,120,214,00111111,0110,1
16:51:45R IW4EPP>APRS,PCSAT-1* <UI Len=54>::BLN :Packet Mail : IW4EPP@I4UKI.#MO.IEMR.ITA.EU
16:51:54R 2E0EXL>APRS,PCSAT-1*,WIDE <UI Len=62>:=5125.04N/00007.99W-73' Via Satellite Phil , London . {UISS50}
16:52:00R UT4QU>CQ,PCSAT-1* <UI Len=35>::EA7AHA :de UT4QU bye and best 73Последний раз редактировалось UA3IRS; 23.12.2007 в 22:12.
73! Юрий EW6X (ex EW6BN) Если не QRP, то 100Вт@палка/верёвка
10.01.2007, 19:29 #2Very High Power
- 21.10.2005
- Marktplatz 5, 94157, Perlesreut, Германия
- 80
- 2,823
- 30
- 14
а на передачу можешь?
Сообщение от EW6BN
73! Анатолий (DL8RCB)
10.01.2007, 19:41 #3Very High Power
- 15.08.2006
- 1,491
- 732
- 633
Нету пока антенны, хотя пурскал и так, но...
Сообщение от DL8RCB
И надо вообще-то UISS, а там был UI3273! Юрий EW6X (ex EW6BN) Если не QRP, то 100Вт@палка/верёвка
11.01.2007, 08:53 #4Very High Power
- 21.10.2005
- 80
- 2,823
- 30
- 14
да она UISS ,удобна в смысле оперативности, но тогда ставь sv2agw драйвер
Сообщение от EW6BN
11.01.2007, 11:34 #5Very High Power
- 15.08.2006
- 1,491
- 732
- 633
Да уже поставил, может сегодня послушаю сатты.
Сообщение от DL8RCB
А AGW и с кантрониксами дружит, только что грядка большая получается.73! Юрий EW6X (ex EW6BN) Если не QRP, то 100Вт@палка/верёвка
11.01.2007, 13:12 #6Very High Power
- 21.10.2005
- 80
- 2,823
- 30
- 14
для kpc-3, что выбираешь КАМ__?
Сообщение от EW6BN
и еще вопрос
TNC2S-SYMEK AFSK 1200/2200 + 300 baud ,650/850Hz если КВ какую частоту выставлять__?Последний раз редактировалось DL8RCB; 11.01.2007 в 14:16.
11.01.2007, 20:14 #7Very High Power
- 15.08.2006
- 1,491
- 732
- 633
2DL8RCB
Анатолий. был пост, но вы его наверное удалили, всё-таки отвечу.
В AGW есть KPC-3Plus.
А по настройке расчёт следующий:
Стандартом на КВ, как правило, являются частоты тонов "0"= 1600 Гц, "1"= 1800 Гц, т.е. Средняя = 1700 Гц.
Итак, на 30м указаны в источниках частота 10147,6 USB, т.о. 10147600+1700=10149300 Гц - это средняя частота излучения в эфире.
Далее в вашем примере 0=650 Гц, 1=850 Гц, средняя = 750 Гц. Отсюда находим 10149300-750=10148550 Гц - ваша искомая чатота настройки трансивера в USB.
С LSB наоборот, например LSB 7035000. 7035000-1700=7033300 Гц. Отсюда для вашей настройки TRX 7033300+750=7034050 Гц.
Для других диапазонов аналогично.
Ну и для точной подстройки можно попробовать покрутить +-50Гц.
P.S. Проскочил сегодня разок через PCSAT-1(NO-44)
EW6BN>CQ,PCSAT-1*,qAr,DK3WN-1:=5532.39N/02837.37E-Yuri, KO45hm via SAT {UISS50}Последний раз редактировалось EW6BN; 11.01.2007 в 20:18.
13.01.2007, 09:51 #8Very High Power
- 15.08.2006
- 1,491
- 732
- 633
via PCSAT-1
Вчера сотворил обычный J-pole на двойку, поставил его просто на балконе третьего этажа кирпичной пятиэтажки.
Вот утром провёл два QSO через NO-44 c MM0HMM-1 и UT4QU.
Пока ещё опыта маловато, не приспособился к UISS, но начало положено :-)
P.S. а вот и чудо антенна :-))Последний раз редактировалось EW6BN; 13.01.2007 в 11:24.
13.01.2007, 13:20 #9Standart Power
- 04.08.2006
- Москва, Россия
- 71
- 390
- 27
- 25
Юрий молодец! А с крос яги и xxxxx сможет. Я с Миром работал тоже с балкона на кусок провода от утюга - это штырь и два противовеса - усы от комнатной телевизионной антенны TV "Юность". Вот такая рогатина была закреплена к потолку балкона следующего этажа.
Юрий, искал в аське, хотел спросить, что всё же было с KPC3?
А вот, всё нашёл http://forum.qrz.ru/thread12900.html вопросов нет.
Всех с НОВЫМ ГОДОМ!!!!!!
P.S. А эта антенна на какой диапазон? 8-)Последний раз редактировалось RX3AOE; 26.11.2007 в 19:51.
73! Юрий, RX3AOE
13.01.2007, 16:20 #10Very High Power
- 15.08.2006
- 1,491
- 732
- 633
Да, голь на выдумки хитра... :-)
Сообщение от RX3AOE
А это параболла 10ГГц. :-))73! Юрий EW6X (ex EW6BN) Если не QRP, то 100Вт@палка/верёвка
13.10.2007, 13:42 #11
18.10.2007, 17:15 #12Very High Power
- 21.10.2005
- 80
- 2,823
- 30
- 14
1) О спутнике - http://www.ew.usna.edu/~bruninga/pcsat.html.
2) Зайдя по этой ссылке http://www.findu.com/cgi-bin/pcsat.cgi? можно видеть какие из них "активны".
3) Кликнув мышей по строчке увидим время последней орбиты Click here to see times in absolute UTC.
В качестве примера смотрите сегодняшнюю последнюю орбиту:Последний раз редактировалось UA3IRS; 02.12.2007 в 16:00.
06.11.2007, 08:36 #13Very High Power
- 21.10.2005
- 80
- 2,823
- 30
- 14
Денис привет! прими поздравления, я прозевал вчера и не посмотрел твой "пакет" если стянул кинь мне на мыло
http://www.findu.com/cgi-bin/find.cgi?RK9LWA
Добавлено через 1 час 1 минуту
вот теперь и я принял сегодня PCSAT-1 вот твоя сегодня орбита
20071106062849 : RK9LWA]UWPY57,PCSAT-1*,WIDE2-1,qAo,YO8SSQ:']9l -/]TM-D700E
не совсем понятна строчка если не лень напиши что прописано в кенвудеПоследний раз редактировалось DL8RCB; 06.11.2007 в 09:42. Причина: Добавлено сообщение
08.11.2007, 10:16 #14
10.11.2007, 11:47 #15Very High Power
- 21.10.2005
- 80
- 2,823
- 30
- 14
Последний раз редактировалось DL8RCB, 08.11.2007 в 08:29.
сегодня до смены символа73! Анатолий (DL8RCB)
