Цитата:
A Dick Tracey wrist radio it’s not! Instead it’s a small-compact lightweight 5-band CW xcvr that’s guaranteed to make you smile! Toss it your jacket pocket and go for a stroll in the park, beach, apartment balcony, cruise ship/mm, family camping weekend, fishing canoe voyage, junior’s soccer meet, or you name the event/activity! I’ve been chasing SOTA or POTA operators every opportunity I get! In fact I’ve been using the KH1 with it’s 4’ whip exclusively with surprising results! Granted QRP takes some getting used with listening more and talking less. And using some acquired “working DX” strategy to snagged some QSOs.
Every since I got the KH1 I can’t stop thinking about where to take it next. Having the logging tray is nice but also having the LOG capture feature of “Continuous logging of CW TX text; 32 kb EEPROM holds hundreds of QSOs” if nothing else a great log validation tool for SOTA/POTA activator OP who’s in the hot seat and can easily make typos while logging. (Noted this feature isn’t in the firmware yet) Changing keyer speed GUI is brilliant one tap of the - (minus) button reduces your speed 2WPMs or one tap of the + (plus) button increases speed in 2WPM increments so on the fly you match your senders speed.
The minor CONs: Speaker is tiny thus audio in quiet room is sufficient audio but earbuds are recommended for outdoors especially at the beach with the pounding surf! I’m still getting used to the paddle and keying while holding KH1 vertically I’m sure it’s just a matter of muscle memory time doing it. The paddle has adjustable spacing but not the tension. I prefer light touch but that might not be wise for hand holding the radio. So I’m adjusting to KH1’s medium touch tension.
Цитата:
Это не хендлик Дика Трейси! Вместо этого это малогабаритный, легкий 5-диапазонный CW-трансивер, который гарантированно заставит вас улыбнуться! Бросьте ее в карман куртки и отправляйтесь на прогулку в парк, на пляж, на балкон квартиры, на круизный лайнер, в семейный поход, на рыбалку на байдарке, на футбольный матч юниоров или на любое другое событие/мероприятие! Я гоняюсь за операторами SOTA или POTA при каждом удобном случае! На самом деле, я использую исключительно KH1 с 4' хлыстом и получаю удивительные результаты! Конечно, с QRP нужно приноровится, больше слушать и меньше говорить. И использовать приобретенную стратегию "работы на DX", чтобы получить несколько QSO.
С тех пор, как я получил KH1, я не перестаю думать о том, куда его применить в следующий раз. Наличие лотка для ведения журнала - это здорово, но и функция LOG capture, является отличным инструментом проверки журнала для SOTA/POTA активаторов, который в спешке может легко сделать опечатку при ведении журнала. (Замечу, что эта функция еще не включена в прошивку) Изменение скорости передачи в графическом интерфейсе осуществляется одним нажатием кнопки - (минус), что уменьшает скорость на 2 WPM, или одним нажатием кнопки + (плюс), что увеличивает скорость с шагом в 2 WPM, так что на лету вы подстраиваетесь под скорость вашего отправителя.
Небольшие минусы: Маленький динамик, поэтому в тихой комнате звук будет достаточным, но для использования на улице, особенно на пляже с шумом прибоя, рекомендуется использовать наушники!
Я все еще пытаюсь привыкнуть к ключу и нажатию весел при вертикальном положении KH1.
