GPS2GoogleEarth - это первая GPS программа с полной поддержкой Google Earth. Она конвертирует GPS данные напрямую в формат Google Earth KML
файл.
GPS 2 Google Earth v2.2 (5.4 MB): http://www.s-gps.com/downloads/GPS2GESetup.zip
User Manual GPS 2 Google Earth (188 kB): http://www.s-gps.com/downloads/GPS2G...r%20Manual.pdf
ДЛЯ АНГЛОЯЗЫЧНЫХ:
Hardware requirements:
Pocket PC (Windows CE) + GPS receiver (NMEA protocol)
Connect to GPS:
Connect GPS to PPC. GPS2GE works with standard NMEA protocol GPS receivers. Depending on the type of GPS receiver, it can be connected via cable, Bluetooth, CF-Slot or SD-Slot. The application also works with GPS receivers that are integrated in the PPC.
In the Devices tab you can click Auto-Detect. GPS2GE will then automatically find the GPS. If you use Bluetooth GPS, it might be necessary to activate Bluetooth before clicking Auto-Detect. If GPS2GE doesn’t find the GPS, you can also select the GPS manually. After having selected the GPS, click connect.
Capture Data:
On the top of the next tab you can see latitude and longitude and the number of satellites fixed. GPS2GE supports paths and placemarks. Paths are used to log tracks. Placemarks are used to mark a single place like a house.
To every single placemark can be attached name and description. These information additional information are also displayed in Google Earth.
Export Data:
The Export tab allows to specify name and destination of the KML file. "Generate KML" will create the file.
KML files can only be created, if logging of path is stopped.
Display Data in Google Earth:
The KML then have to be copied by drag and drop on desktop. By double clicking the KML file, Google Earth opens and displays the date.
By pressing the play tour button in Google Earth you can fly along the paths and placemarks you logged with the GPS. Enjoy fantastic views!
P.S.
Если интересно пишите на E-Mail будет ещё интересней.
Если не интересно, пожайлуста не скачивайте, умоляю, это ведь весь глобус, а прыщей на водителях APRS автомобилей там не видно :-((
