КАК РАСКРЫТЬ ALINCO DX70 на передачу?????:sos:
Ok, first an apology to all who sent msgs about these mods. Sorry for
the delay in getting these out here.
The Alinco DX-70 can be configured as follows:
Extended TX, open the RX up to 35Mhz and down to 30 Khz, Open the VHF
side from 45-60 Mhz RX/TX. All can be done quickly by , by removing or
changing a series of chip-resistors located in the detatchable front face
panel. This mod is a little tricky to perform, since it uses surface
mount devices, so I TAKE NO RESPONSIBILITY IF YOU BREAK YOUR RIG.
Alinco, further, in their mod sheet, warns that performing this mod
incorrectly will NOT BE COVERED via warranty. At first, I tried using a
Salami sized soldering iron--- take my word, get a good, very fine point
iron of about 15 or 20 watts max! Make sure it is static guarded too.
Ok...Here we go.
1. disconnect power
2. disconnect antenna
3. remove control head, disconnect control cable
4. remove 4 screws on back of control head,
5 remove (unsnap is more like it) the control head back panel.
6. THE MOD:
Once you have the back panel removed, and using the big VFO knob as
your guide (circuit board facing you, LCD display not facing you). The
VFO knob should be on the left side. On the right side, in the lower
right hand corner, you should see 2 distinct columns of chip resistors.
On the board, they are NOT labeled, but I will draw the diagram below
to help you. You cant miss these because there are 5 chip resistors in
the left-hand row, and the right-hand row has 7 chip resistors. Above
both rows is a solder-pad.
a(::) h(::)
g-
i-
b - j-
c - k-
d - l-
e - m-
f - n-
Several chip resistors will be soldered in, depending on the model
of your rig, and a solder pad is jumpered. Here are the mods per
Alinco:
a. 45-60 Mhz TX/RX - solder a 0ohm or jumper across location i
b HF RX down to 30 Khz - remove the jumper m
c. beyond just Mars Mod - TX/RX everywhere remove both jumpers c and e
d. HF RX up to 35 MHZ - solder a bridge across pad a
After performing the above mods, reassemble the unit.
7. DONT FORGET to reset the microprocessor (with the radio off, hold
the F button and simultaneously turn the power on.
All memories are wiped out, but the new bands are opened.
I've tried all mods with my Alinco rig and can confirm they work. I am
able to pick up business band communication in the 46 Mhz range (FM), and
cordless phones in 46/49 range. It TX's everywhere now too.
I do not take responsibility if you perform this mod incorrectly, and I
am not responsible for your operation practice if you choose to illegally
transmit out of band.
Thanks and again, sorry for such a delay in getting this out here.
73 de Joe BV/N0IAT Taipei, TAIWAN (FORMOSA)
На англицком но вроде всё понятно.
Так она и так везде передаёт , и КВ и 6 м , и непрерывно весь диапазон .
Перевод.
Alinco DX-70 могут быть раскрыты следующим образом:
расширение TX, RX от 30 кГц до 35 МГц , открыт ОВЧ
в полосе от 45-60 МГц RX/TX. Все может быть сделано быстро ,
путем удаления или установки ряда чип резисторов,расположенных в торце передней съёмной передней панели. Эта операция немного мудреная,
чтобы выполнять, поскольку используется поверхностный монтаж , так что Я не БЕРУ НИКАКУЮ ОТВЕТСТВЕННОСТЬ ЕСЛИ ВЫ ЛОМАЕТЕ ВАШУ ОСНАСТКУ.
Alinco, кроме того, в их mod листа, предупреждает что при выполнении этого мод будет отказано в гарантии.
Во-первых, использовать хорошо заточенный как карандаш небольшого размера паяльник 15 или 20 ватт Макс! Убедитесь, что он имеет защиту от статики.
Хорошо...и так начнём.
1. Отсоедините питание
2. Отсоедините антенну
3. Снимите блок управления, отключив кабель управления
4. Отвинтите 4 винта на задней части блока управления,
5 Снять крышку (освободить доступ) платы панели управления.
6 Собственно модификация:
Поверните блок управления к себе задом , и используйте большую ручку VFO как ориентир
Расположите правильно блок управления (печатная плата, обращен к вам, ЖК-дисплей не виден вам). Ручка VFO должна находиться с левой стороны. На правой стороне, в нижнем
правом углу, вы должны увидеть 2 отдельных колонки чип резисторов.
На плате они не помечены, но я сделаю диаграмму ниже
чтобы помочь вам. Вы легко разберётесь, потому что есть
5 чип резисторов в колонке слева и
7 чип резисторов в правой колонке.
Выше обеих строк имеются перемычки из припоя.
a(: h(:
g-
i-
b - j-
c - k-
d - l-
e - m-
f - n-
Несколько миниатюрных резисторов будут запаены в, в зависимости от модели вашей оснастки, и перемычки припоя.
Вот пример Alinco:
6.1.работа в полосе 45-60 Мгц TX/RX - паять 0ohm или перемычку через позицию i,
6.2 расширение полосы RX вплоть до 30 Khz - удалить перемычку m
6.3 Работа за пределами диапазонов Mod - TX/RX удалить премычки c и e
6.4 расширение RX вплоть до 35 МГЦ - паять перемычку через панель a
После выполнения вышеуказанных операций соберите устройство.
7. Остаётся сбросить микропроцессор ( нажимая кнопку F и одновременно включать).
Вся память будет стёрта, но новые полосы открыты.
Я попробовал все модули с моей оснасткой Alinco и могу подтвердить их работу. Я принимаю связь в дипазоне 46 Мгц (ЧАСТ.МОД.), и радиотелефон в 46/49 дипазонов. TX везде теперь тоже.
Я не беру ответственность если Вы выполняете этот модуль неправильно, и Я не ответственный за ваше действие практики если Вы решаете незаконно работать на передачу за пределом разрешённой полосы полосы.
Спасибо и извините за задержку.
