Программирование мк/сх с флэш-памятью
Нужно заменить мк/сх в Kenwood TS-2000.Part No 64F2633JXUC.
Она с флэш-памятью.Где можно найти программу и как прошить с помощью РС? Вот писали:
Reply from KENWOOD UK:
Our engineer has never had to replace this IC8 and therefore, we are
uncertain if it is programmed. However, if it is
not then you can easily flash program it with the user firmware and your pc.
If you wish I can investigate further and advise, if so please confirm.
What are the symptoms of the fault as our engineer believes that this could
be a misdiagnosis.
