Вложений: 2
Это FlexRadio FLEX-5000C™
Новый трансивер от FLEX RADIO на основе новых технологий
Подробнее см на http://www.flex-radio.com/Products.a...c=F5Kc_details
FLEX-5000C Transceiver Specifications:
General
Rx Frequency Range: 10 kHz - 65 MHz (operating) 160 - 6 m (specified performance, Amateur bands only)
Transmitter Frequency Range: 160 - 6 m (Amateur bands only)
Frequency Stability: ±0.5 ppm 32 °F to 122 °F (0 °C to+50 °C)
Operating Temperature Range: 14 °F to 122 °F (–10 °C to +50 °C)
Emission Modes: A1A (CW), A3E (AM), J3E (LSB,USB), F3E (FM), F1B (RTTY), F1D (PACKET), F2D(PACKET)
Frequency Steps: 1Hz minimum
Antenna Impedance: 50 Ohms, unbalanced 6 - 1000 Ohms, unbalanced (With Optional Tuner ON, 160 - 10 m Amateur bands) 16 - 150 Ohms, unbalanced (With Optional Tuner ON, 6 m Amateur band)
Power Consumption: Rx 1.5A (typ.); Tx (100 W) 25A(max.)
Supply Voltage: DC: DC 13.8 V ± 10%
Maximum Interconnect Cable Length: Firewire - 10 feet (3m), No restriction on DC power cable within voltage tolerance limits under load.
Special EMI/RFI Requirements:
1 snap on ferrite bead on DC power cable,
2 snap on ferrite beads on FireWire cable (internal)
1 snap on ferrite bead on FlexWire cable
All beads to be located adjacent to rear panel of radio.
Dimensions: (WxHxD): 17.67” x 8.7” x 14.67” (44.9cm x 22.1 cm x 37.3 cm)
Weight: (approx.): 13 lbs (5.9 kg)
Transmitter
Power Output : 1 - 100 watts PEP CW and SSB (2 -25 watts AM carrier)
Emission Modes Types : A1A (CWU, CWL), J3E (USB, LSB),A3E (AM), F3E (FM), DIGITAL
Harmonic Radiation :
Better than –55 dB (160 - 10mAmateur bands)
Better than –65 dB (6m Amateur band)
SSB Carrier Suppression :
At least 55 dB below peak output
Undesired Sideband Suppression : At least 55 dB below peak output
Audio Response (SSB): Flat Response 10 Hz to 20 kHz, Software EQ optional
3rd-order IMD : Better than –33 dB below PEP @14.2MHz 100 watts PEP
Microphone Impedance : 600 Ohms (200 to 10k Ω)
Balanced Line In Impedance : 600 Ohms (200 to 10k Ω)
Receiver
Circuit Type : Direct conversion, low IF
Intermediate Frequency : Software selectable from DC to 20kHz
MDS: 14 MHz Preamp off/on: 1.3/0.3 µV; MDS: -123 dBm/-133 dBm in 500 Hz BW
IP3: +30 dBm at 14 MHz with preamp off at 2 kHz or less tone spacing (S5 IM3 method)
Selectivity (–6/–60 dB):
CW 500 Hz –6/-60 dB: 500/640
SSB 2.4 kHz –6/-60 dB: 2.39/2.54
AM 6.6 kHz –6/-60 dB: 6.60/6.74
Image Rejection: 70 dB or better (160 - 6m Amateur bands)
