Info UR5EQF sw e Yaesu FT-920
Hello, recently I installed the software ur5eqf with the yaesu ft 920 ...
I was able to set it with the com port (in my case is 3), but I can not set the cat, the cat septum or better if I do not go out in tx or not the audio. So I have to lock the cat and run it manually .. Also can directly transmit AFSK and FSK, notwithstanding the command behind the tx ... Wonder if possibly there is any connection that uses the same setup ...
Yaesu FT920 sw: ur5eqf
FTDI FT232R chip interface iw9gtd
thanks John
