16.10.2007, 07:16 #16Big Gun
- 05.06.2002
- 6,072
- 1378
- 332
16.10.2007, 11:33 #17Модератор
- 15.04.2006
- Москва, Россия
- 79
- 1,687
- 2930
- 545
Действительно, причина именно в высокоомности! Вот и в статье про гарнитуры в танковых шлемах, на которую была ссылка ранее, говорится:
"In 1943, the Army Air Corps and the Navy began to switch from the 2000 ohm high impedance R-14 receiver to the 600 ohm low impedance ANB-H-1 receiver. This low impedance headset was referred to as the HS-38 headset (the HS-33 was the same as the HS-38, but it included a headband for non-helmeted applications). The most obvious difference between the original high impedance HS-18 and the later low impedance HS-38 was in the ¼-inch PL-354 plug shell, which was purposely colored red to avoid improper integration with high impedance radio equipment. The ANB-H-1 receiver was similar in size and appearance to the R-14 receiver.
Eventually the armored corps also adapted the low impedance HS-38 headset, but the majority of headsets for most of the war appear to have used the original high impedance HS-18 headset. Through the use of a special Headset Adapter MC-385-C, it was possible to step down the tank radio's high impedance to the low impedance required for the newer low impedance receivers. Thus, as new headsets flowed through the supply chain, it was possible to use them without converting expensive radio hardware. The adapter was installed between the tank's phone jack on the BC-606 intercom control box) and a CD-307-A extension cord (with a PL-55 plug on one end and a JK-26 jack on the other). The CD-307-A extension cord was then connected to the PL-354 plug of the HS-38 headset."
Коротко говоря, в 1943 году американские летчики и моряки начали переходить от высокоомных наушников R-14 на 600-омные ANB-H-1, которые внешне выглядели точно так же. Гарнитуры на основе ANB-H-1 назывались либо HS-38 (для танковых шлемов), либо HS-33, если они были с оголовьем.
А чтобы использовать с новыми связными приемниками, имевшими низкоомный выход, прежние 2000-омные гарнитуры HS-18 и HS-23, которых вокруг было пруд пруди, разработали специальный переходник МС-385-С. Вот фото этого переходника и инструкции по его применению:
Но для нынешних SSB-трансиверов, наверное, и 600 Ом это слишком высокоомный выход...Последний раз редактировалось RA3CC; 16.10.2007 в 11:52.
73 - Валерий (RA3CC) .::. Посетите Радиомузей В.Громова rkk-museum.ru или радиомузей.рф
16.10.2007, 17:38 #18Silent Key
- 13.01.2003
- Жабомишодраківка
- 13,850
- 3918
- 1415
Интересная тема !
О раритетах с удовольствием почитал . Ещё раз с сожалением вспомнил тот ВС779 , который мы сдуру разобрали в середине 70-х. Зачем ? А чёрт его знает - какой-то КПЕ для UW3DI был нужен . Зря конечно это сделали . Молодые были , глупые . Каюсь ! Только шильдик от него о остался . ( 1943г ) .
А вот о наушниках - наверное - у многих есть что сказать . Я с начала 80-х ( !!! ) использую самодельные , в " корпусе " от противошумовых производственных . На ушах толстые льняные чехлы - летом не так жарко . А вот капсюля - динамические , Ом по 300 каждый , голубого цвета ( пластик ) от бытовых Польских телефонов !!! Попала эта парочка ко мне случайно - подарил человек , ремонтировавший в те времена телефоны - вот и приватизировал . Я ещё кочевряжился - не надо , мол ! Вояцкие есть ! Мне их чуть не силой впихнули в руки . Теперь уже больше 20-и лет с благодарностью вспоминаю человека . Наушники такие - что частот выше тысяч 5 Герц для них не существует ! И ниже сотен двух . То есть и остатки фона в UW3DI исчезали и шумок детектора тоже . И динамический диапазон у них куда больше военных наушников - нет дребезга на больших уровнях . Плюс к тому - можно включать на 150 ( вроде как низкоОмные ) и на 600 - а это уже вроде как и высокоомные . :-) . Сейчас проверялось и с KENWOODами и с YAESU - результат очень даже положительный !!! За эти годы только поролон пару раз менял ( за пару десятков лет он просто разложился ) и тряпочки на ушах периодически в стиральную машину кидаю . А наушники - КЛАСС !!!
Всем совет : на барахолках смотреть не только КПЕ от БАЛТИКИ и красивые приборы от трофейных МЕССЕРШМИТОВ , но и телефонные аппараты . Не пожалеете !-73- Игорь
17.10.2007, 00:18 #19Модератор
- 15.04.2006
- Москва, Россия
- 79
- 1,687
- 2930
- 545
Докладываю, что на сайте Радиомузея РКК уже произведена корректировка позывного UA0AAM, причем не только в перечне источников информации, которые мы использовали при подготовке списков аппаратуры, поставлявшейся по Ленд-Лизу, но и в тексте раздела "О коллекционировании аппаратуры Ленд-Лиза".
Этот раздел г-н Брудский очевидным образом не читал (соответственно, и ошибки в своем позывном там не заметил), а я советовал бы прочесть этот наш текст.
Мне кажется, текст написан достаточно легким языком, и каждый читающий наверняка найдет там кое-что новое и интересное для себя.
Кроме того, хотелось бы получить информацию о какой-то радиоаппаратуре Ленд-Лиза, не вошедшей в наши списки. Такая аппаратура наверняка есть, и особенно это касается морской американской радиоаппаратуры.
Дело в том, что по сухопутной и авиационной аппаратуре Ленд-Лиза есть официальные списки поставок (пусть с явными неточностями, но есть!), а про радиоаппаратуру US Navy, которая также поставлялась в СССР в годы войны, никаких систематических данных пока обнаружить не удалось.
Так что информацию про радиоаппаратуру US Navy времен ВОВ приходится собирать по крохам, по фактическому наличию экспонатов, вроде имеющегося в Радиомузее РКК приемника CHC-46140, входившего в состав военно-морского комплекта RBG.
В качестве примера приведу приемник CNA-46187-D из морского комплекта RAO-6, который в наших списках Ленд-Лиза пока что отсутствует:
Фактически это приемник NC-120 компании National, приспособленный для военных целей. И вдруг именно такой приемник обнаружился в Севастополе:
Хозяин приемника запросил за него $2,000 (две тысячи долларов), но такие деньги за приемник, явно пострадавший от послевоенных переделок, да еще и ржавый изнутри, я платить не захотел. А за предложенные мною $400 хозяин не захотел с ним расставаться.
Но факт остается фактом --- в СССР каким-то образом попал приемник из комплекта RAO-6. Это могли быть вовсе не поставки по Ленд-Лизу, а просто единичный факт передачи такого приемника с какого-то американского корабля, но все равно это интересно.
И в свои списки поставок по Ленд-Лизу мы, пожалуй, внесем и комплект RAO-6 вообще, и входивший в его состав приемник CNA-46187-D в частности.
А всех, кто читает это сообщение, еще раз просим помочь информацией про ту аппаратуру Ленд-Лиза, которая пока что отсутствует в списках, которые мы составили и разместили на сайте Радиомузея РКК.Последний раз редактировалось RA3CC; 17.10.2007 в 10:57.
17.10.2007, 06:56 #20Big Gun
- 05.06.2002
- 6,072
- 1378
- 332
Это капсюли польского производства фирмы ТОНСИЛ. Ими комплектовались телефонные аппараты АСТЕР .
Так вот эти динамические излучатели устанавливаемые в телефонной трубке как наушник, ещё великолепней работают - как динамический микрофон!
Удивительно мягкое, среднечастотное, "кенвудовское" звучание - просто поразительно. Сопротивление 300 Ом, а если аккуратно развальцевав, снять защитную крышку с отверстиями корректирующие АЧХ такого микрофона, то плучится микрофонный капсюль по частотному звучанию схожий с капсюлями YAESU.Последний раз редактировалось UN7CI; 17.10.2007 в 06:58.
Борис
17.10.2007, 14:32 #21Модератор
- 15.04.2006
- Москва, Россия
- 79
- 1,687
- 2930
- 545
Хочу добавить несколько слов про "резинки" американской гарнитуры HS-23, которая имеет наушники R-14.
"Резинки" наушников на исходном фото EW6OO на вид совершенно советские, послевоенные. Но уже во время войны у американцев гарнитуры HS-23 поставлялись со своими "резинками":
Это изображение гарнитуры HS-23 с "резинками" (cushion) МС-162 взято из недавно поступившего в Радиомузей РКК справочника по авиационной радиоаппаратуре, датированного апрелем 1943 года:
Американские "резинки" внешне очень похожи на советские. А кто с кого их копировал, это, наверное, каждому понятно...73 - Валерий (RA3CC) .::. Посетите Радиомузей В.Громова rkk-museum.ru или радиомузей.рф
21.10.2007, 14:29 #22
Привет, господа!
У меня такие наушники имеются до сих пор. Как память о моем дяде, который прошел всю войну.
Да, это лендлизовские американские наушники. Мало того, они произведены были фирмой SHURE, ныне производящей всемирно известные профессиональные микрофоны. И если Вы будете внимательны, то вспомните, что в современном фильме «Перл Харбор» главные герои летают на истребителях именно в таких наушниках!
До недавнего времени (до 1997 года) точно такое же оголовье имела профессиональная гарнитура SM-2 (SHURE) выпускавшаяся в том числе и для телеоператоров передвижных телекамер - как служебная связь между оператором и режиссером. После 1997 года фирма SHURE стала выпускать гарнитуру SM-2 с упрощенным и уже не раздвижным оголовьем.
В детстве я слушал на эти наушники самодельные детекторные приемники, позже, они были моими основными наушниками, когда я получал свой позывной и работал в эфире телеграфом. Они великолепно воспроизводят и АМ и CW.
Всего наилучшего!!!Последний раз редактировалось UA3ALW; 21.10.2007 в 14:36.
С уважением, Сергей Комаров :: 73! de UA3ALW pse k
01.11.2007, 11:39 #23Silent Key
- 03.04.2002
- Химки, Московская обл.
- 5,354
- 919
- 1389
Поскольку тема дискуссии ушла в другое русло, то был создан другой топик.
07.01.2010, 23:48 #24High Power
- 09.07.2006
- nr Moscow
- 617
- 26
У меня такая гарнитура в детстве тоже была. Дед приволок после демобилизации (заканчивал войну в Китае, в Даляне). Просто великолепные высокоомные наушники.. Еще вспоминается их мишурный провод, который непросто было заделать в современные разъемы, но убить перегибами оказалось просто практически невозможно. К 80-м годам оригинальные амбюшуры от активного использования рассыпаться начали, пришлось заменить на отечественные армейские, меньшего диаметра.
К сожалению при пожаре они сильно пострадали, теперь на память о них остался только один полностью уцелевший наушник.
Кстати, на surplus sales of nebraska если покопаться, все еще попадаются изделия (гарнитуры, микрофоны, запчасти) от аппаратуры времен WW-II со складского хранения. Например самое нижнее справа на этой странице - http://www.surplussales.com/Micropho...roAudio-2.html
Оригинальный вариант складской упаковки - закатанная консервная банка.
15.01.2010, 00:14 #25
