Показано с 1 по 15 из 23
    0104
    Гость
    Материнская плата AKORP
    Купил плату Akorp 6VIA85X которая имеет питание и АТ и АТХ, я подключил АТ,теперь после завершения работы нет картинки " можно выключить компьютер". Должно ли так быть или это просто глюк
    ua1osm
    Гость
    Почему нет финального текста
    http://www.pcchips.com.tw/q&a.html
    By using the Windows 98 SE ( Second Edition ) version, why my computer frozen at the Windows Logo screen while shutdown ?
    Only SiS main board will cause the problem, and you need a driver update.
    For those users who got the driver CD with V5.1 or early versions, please follow the next few steps below to solved the problem :
    Download the patch file from our web site, copy it to your hard disk and unzip it. (For SiS 530 chipset, you need Pach530.zip, for SiS 620 chipset, use Patch620.zip )
    If your board use SiS 530 chipset, you need to install the VGA driver form driver CD first, then executed the Setup file within the patch to complete the update.
    If your board use SiS 620 chipset, put your driver CD into the CD-ROM drive, simply executed the Setup file within the patch, and gives the path while program is asking for the VGA driver, follow the instructions to complete the update.
    If LAN chip is also built in, you need to update the LAN driver (Win9x.exe) for Windows 98 SE versions as well.
    Enter the BIOS Setup, enables the feature "Assign IRQ for VGA ".
    For those users who got the driver CD with V5.2 version, you only need a file update. Copy the drivers from your driver CD into the hard disk, download the new.ini file (for SiS 530 chipset, you need 530setup.ini, for SiS 620 chipset, use 620setup.ini) from our web site, replace the Setup.ini file withing the original driver, (eg. Copy 620setup.ini C:\vga\win9x\setup.ini ) then re-install it.
    17.08.2002
    ko85mo, RDA MO-56
    2,985
    396
    159
    OSM - это вы откуда скопировали?
    Нет картинки при выключении - глюк ОС - бывает на любых материнках. Я не помню как у себя устранил, но не через BIOS. Положительный результат может дать простая переустановка системы. Только надо при этом полностью снести ту что было, а то глюк может перенестись.
    Very High Power Аватар для R9UHN
    23.04.2002
    Междуреченск
    59
    1,797
    137
    113
    ВЫход есть ещё один -скачать и установить патч от мелкософт. Билл клянётся, что всё будет как надо.
    Но не надо забывать - что Акорп это отстой.
    0104
    Гость
    Акорп не отстой а самый лучший вариант для тех у кого не хватает денег,
    А поповоду переустановки винды пробовал (винт С форматнул) не помогло.
    Отключил ASPI в биосе картинка появилась но пропал сD-ROM
    17.08.2002
    ko85mo, RDA MO-56
    2,985
    396
    159
    Это только подтверждает, что Лев прав!
    0104
    Гость
    Лев вы конечно меня извините, но в данном случае вы не правы! Я часто вижу как мои приятели @бутся с компами на других материнках разных именитых фирм у меня помио описанного еще не одного глюка в работе не было. Поэтому я остаюсь приверженцем данной фирмы.
    17.08.2002
    ko85mo, RDA MO-56
    2,985
    396
    159
    У Вас еще все впереди!
  12. #12
    ONI
    Гость
    Если БП не ATX - однозначно - в БИОС выключить функцию ACPI, а CD-ROM пропал уже судя по всему по другой причине.
    И к стати, как и где пропал?
    1.Физически. (украли)
    2.БИОС не видит CD-ROM
    3.Windows не видит CD-ROM (хотя в БИОС все есть)
    Элементарно - пока лазили в корпус шлейф отошел, или еще чего.
    Патч у Гейтса был (или есть еще) он патчит драйвер ASPI,
    ну а если БП не АТХ то патч не поможет.
    А CD-ROM случайно не LG 50x?
  13. #13
  14. #14
    17.08.2002
    ko85mo, RDA MO-56
    2,985
    396
    159
    Жаль далеко живешь - смотреть надо. Может в Винде букву нечаянно у него отменил. Опять же, реестр посмотри - там есть ключи, которые отвечают за отображение того или иного диска в проводнике. На память не помню какие ключи, но в сети полно сведений по реестру - найдешь.
  15. #15
    15.04.2002
    mo-83
    51
    278
    47
    16
    Ребята, Windows 98 и 95 настоящий отстой, xxxxx и заслуживает только своего присутствия на секретутском компьютере в роли печатной машинки или форматирования под корень. (Извините ежели кого обидел, но более отстойней не видел системы). Поставьте Windows 2000 а ести процессор слабоват, то Windows NT 4.0. Вы надеюсь не игрушки на компе гонять задумали. А все остальное ПО работать будет, и никаких проблем с глюками подобного рода. Если юзаете Win2000 ISPI в биосе надо включить обызательно, чтобы комп гасился автоматом при выключении.
  1. ЧМ плата для FT-840
    от RA4CQ в разделе FT-840
    Последнее сообщение: 26.01.2010, 17:34
  2. Режим спикерфона в Acorp 56EMT
    от Smerch в разделе Компьютеры и сети
    Последнее сообщение: 17.07.2005, 22:57
  3. Материнская плата ST-MGXm
    от Детский Панадол в разделе Компьютеры и сети
    Последнее сообщение: 01.10.2003, 12:29
  4. ф020 - транковая плата
    от Anton в разделе Телефонная, сотовая связь
    Последнее сообщение: 03.04.2003, 10:29
  5. Acorp-56EMS
    от Al в разделе Компьютеры и сети
    Последнее сообщение: 16.07.2002, 14:23
