05.12.2002, 15:59 #10104Гость
Материнская плата AKORP
Купил плату Akorp 6VIA85X которая имеет питание и АТ и АТХ, я подключил АТ,теперь после завершения работы нет картинки " можно выключить компьютер". Должно ли так быть или это просто глюк
05.12.2002, 18:10 #2Прохожий73Гость
Картинка должна быть, попробуйте посмотреть установку АТ-АТХ в биосе мамки.
06.12.2002, 06:48 #3ONIГость
В биосе надо отключить функцию ACPI
06.12.2002, 14:03 #4ua1osmГость
Почему нет финального текста
http://www.pcchips.com.tw/q&a.html
By using the Windows 98 SE ( Second Edition ) version, why my computer frozen at the Windows Logo screen while shutdown ?
Only SiS main board will cause the problem, and you need a driver update.
For those users who got the driver CD with V5.1 or early versions, please follow the next few steps below to solved the problem :
Download the patch file from our web site, copy it to your hard disk and unzip it. (For SiS 530 chipset, you need Pach530.zip, for SiS 620 chipset, use Patch620.zip )
If your board use SiS 530 chipset, you need to install the VGA driver form driver CD first, then executed the Setup file within the patch to complete the update.
If your board use SiS 620 chipset, put your driver CD into the CD-ROM drive, simply executed the Setup file within the patch, and gives the path while program is asking for the VGA driver, follow the instructions to complete the update.
If LAN chip is also built in, you need to update the LAN driver (Win9x.exe) for Windows 98 SE versions as well.
Enter the BIOS Setup, enables the feature "Assign IRQ for VGA ".
For those users who got the driver CD with V5.2 version, you only need a file update. Copy the drivers from your driver CD into the hard disk, download the new.ini file (for SiS 530 chipset, you need 530setup.ini, for SiS 620 chipset, use 620setup.ini) from our web site, replace the Setup.ini file withing the original driver, (eg. Copy 620setup.ini C:\vga\win9x\setup.ini ) then re-install it.
07.12.2002, 22:51 #5Very High Power
- 17.08.2002
- ko85mo, RDA MO-56
- 2,985
- 396
- 159
OSM - это вы откуда скопировали?
Нет картинки при выключении - глюк ОС - бывает на любых материнках. Я не помню как у себя устранил, но не через BIOS. Положительный результат может дать простая переустановка системы. Только надо при этом полностью снести ту что было, а то глюк может перенестись.
08.12.2002, 03:21 #6Very High Power
- 23.04.2002
- Междуреченск
- 1,799
- 137
- 118
ВЫход есть ещё один -скачать и установить патч от мелкософт. Билл клянётся, что всё будет как надо.
Но не надо забывать - что Акорп это отстой.
16.12.2002, 13:19 #70104Гость
Акорп не отстой а самый лучший вариант для тех у кого не хватает денег,
А поповоду переустановки винды пробовал (винт С форматнул) не помогло.
Отключил ASPI в биосе картинка появилась но пропал сD-ROM
18.12.2002, 21:27 #8Very High Power
- 17.08.2002
- ko85mo, RDA MO-56
- 2,985
- 396
- 159
Это только подтверждает, что Лев прав!
19.12.2002, 15:37 #90104Гость
Лев вы конечно меня извините, но в данном случае вы не правы! Я часто вижу как мои приятели @бутся с компами на других материнках разных именитых фирм у меня помио описанного еще не одного глюка в работе не было. Поэтому я остаюсь приверженцем данной фирмы.
21.12.2002, 09:51 #10Very High Power
- 17.08.2002
- ko85mo, RDA MO-56
- 2,985
- 396
- 159
У Вас еще все впереди!
25.12.2002, 19:49 #11СтаРРыйГость
У меня таже мамка и картинки никогда и не было .
09.01.2003, 13:44 #12ONIГость
Если БП не ATX - однозначно - в БИОС выключить функцию ACPI, а CD-ROM пропал уже судя по всему по другой причине.
И к стати, как и где пропал?
1.Физически. (украли)
2.БИОС не видит CD-ROM
3.Windows не видит CD-ROM (хотя в БИОС все есть)
Элементарно - пока лазили в корпус шлейф отошел, или еще чего.
Патч у Гейтса был (или есть еще) он патчит драйвер ASPI,
ну а если БП не АТХ то патч не поможет.
А CD-ROM случайно не LG 50x?
09.01.2003, 14:12 #130104Гость
CD-ROM случайно не LG 50x, просто винда перестает его видеть,
11.01.2003, 11:05 #14Very High Power
- 17.08.2002
- ko85mo, RDA MO-56
- 2,985
- 396
- 159
Жаль далеко живешь - смотреть надо. Может в Винде букву нечаянно у него отменил. Опять же, реестр посмотри - там есть ключи, которые отвечают за отображение того или иного диска в проводнике. На память не помню какие ключи, но в сети полно сведений по реестру - найдешь.
14.01.2003, 10:36 #15Standart Power
- 15.04.2002
- mo-83
- 51
- 278
- 47
- 16
Ребята, Windows 98 и 95 настоящий отстой, xxxxx и заслуживает только своего присутствия на секретутском компьютере в роли печатной машинки или форматирования под корень. (Извините ежели кого обидел, но более отстойней не видел системы). Поставьте Windows 2000 а ести процессор слабоват, то Windows NT 4.0. Вы надеюсь не игрушки на компе гонять задумали. А все остальное ПО работать будет, и никаких проблем с глюками подобного рода. Если юзаете Win2000 ISPI в биосе надо включить обызательно, чтобы комп гасился автоматом при выключении.
