Показано с 1 по 6 из 6
    Silent Key Аватар для UA3IRS
    03.04.2002
    Химки, Московская обл.
    5,354
    919
    1389
    Post Это FlexRadio FLEX-5000C™
    Новый трансивер от FLEX RADIO на основе новых технологий
    Подробнее см на http://www.flex-radio.com/Products.a...c=F5Kc_details
    FLEX-5000C Transceiver Specifications:
    General
    Rx Frequency Range: 10 kHz - 65 MHz (operating) 160 - 6 m (specified performance, Amateur bands only)
    Transmitter Frequency Range: 160 - 6 m (Amateur bands only)
    Frequency Stability: ±0.5 ppm 32 °F to 122 °F (0 °C to+50 °C)
    Operating Temperature Range: 14 °F to 122 °F (–10 °C to +50 °C)
    Emission Modes: A1A (CW), A3E (AM), J3E (LSB,USB), F3E (FM), F1B (RTTY), F1D (PACKET), F2D(PACKET)
    Frequency Steps: 1Hz minimum
    Antenna Impedance: 50 Ohms, unbalanced 6 - 1000 Ohms, unbalanced (With Optional Tuner ON, 160 - 10 m Amateur bands) 16 - 150 Ohms, unbalanced (With Optional Tuner ON, 6 m Amateur band)
    Power Consumption: Rx 1.5A (typ.); Tx (100 W) 25A(max.)
    Supply Voltage: DC: DC 13.8 V ± 10%
    Maximum Interconnect Cable Length: Firewire - 10 feet (3m), No restriction on DC power cable within voltage tolerance limits under load.
    Special EMI/RFI Requirements:
    1 snap on ferrite bead on DC power cable,
    2 snap on ferrite beads on FireWire cable (internal)
    1 snap on ferrite bead on FlexWire cable
    All beads to be located adjacent to rear panel of radio.
    Dimensions: (WxHxD): 17.67” x 8.7” x 14.67” (44.9cm x 22.1 cm x 37.3 cm)
    Weight: (approx.): 13 lbs (5.9 kg)
    Transmitter
    Power Output : 1 - 100 watts PEP CW and SSB (2 -25 watts AM carrier)
    Emission Modes Types : A1A (CWU, CWL), J3E (USB, LSB),A3E (AM), F3E (FM), DIGITAL
    Harmonic Radiation :
    Better than –55 dB (160 - 10mAmateur bands)
    Better than –65 dB (6m Amateur band)
    SSB Carrier Suppression :
    At least 55 dB below peak output
    Undesired Sideband Suppression : At least 55 dB below peak output
    Audio Response (SSB): Flat Response 10 Hz to 20 kHz, Software EQ optional
    3rd-order IMD : Better than –33 dB below PEP @14.2MHz 100 watts PEP
    Microphone Impedance : 600 Ohms (200 to 10k Ω)
    Balanced Line In Impedance : 600 Ohms (200 to 10k Ω)
    Receiver
    Circuit Type : Direct conversion, low IF
    Intermediate Frequency : Software selectable from DC to 20kHz
    MDS: 14 MHz Preamp off/on: 1.3/0.3 µV; MDS: -123 dBm/-133 dBm in 500 Hz BW
    IP3: +30 dBm at 14 MHz with preamp off at 2 kHz or less tone spacing (S5 IM3 method)
    Selectivity (–6/–60 dB):
    CW 500 Hz –6/-60 dB: 500/640
    SSB 2.4 kHz –6/-60 dB: 2.39/2.54
    AM 6.6 kHz –6/-60 dB: 6.60/6.74
    Image Rejection: 70 dB or better (160 - 6m Amateur bands)
ID:	8916   Нажмите на изображение для увеличения.
    Последний раз редактировалось UA3IRS; 08.10.2007 в 21:47.
    [SIZE=1][FONT=Verdana]73. Сергей ([B]UA3IRS[/B] aka [B]UR3IRS[/B]) :ru: :: OnLine: [url=facetime://ur3irs@gmail.com]FaceTime[/url], [url=callto://ur3irs]Skype[/url], [url=xmpp://ur3irs@gmail.com]Jabber[/url] :: Web: [url=twitter.com/ur3irs/]Twitter[/url], [url]aprs.ru[/url], [url]echolink.ru[/url], [url=https://www.flickr.com/photos/ur3irs/sets/]Flickr[/url], [url]ur7iwz.qrz.ru[/url][/FONT][/SIZE]
    03.04.2002
    5,354
    919
    1389
    Первые результаты испытаний этого трансивера см http://rw3ps.qrz.ru/news.htm
    Кто что может сказать про этот трансивер хорошего или плохого?
    27.09.2005
    Тула, Россия
    243
    25
    Flex-5000A уже в России! Ожидайте обзор.
    Но сначала немного дайте "покрутить".
    03.04.2002
    5,354
    919
    1389
    Давай скорее выкладывай обзор. Невтерпёж уже... 8)
    27.08.2012
    Omsk
    45
    305
    82
    46
    Прошло столько лет и где отзывы?
    Уже 6500 созрел, а здесь пусто.
    21.11.2011
    41
    12
    На Радиоэсперте есть обзор Flex-5000A
  1. FLEX RADIO system! New!
    от UA3IRS в разделе Общие вопросы
    Последнее сообщение: 24.12.2005, 14:18
