Вот что ответил GW3YDX:
Hello Anton
Here is our proposed solution.
Two Bandmaster 4 decoders:
BandMaster
Two "Bandpasser II" bandpass filter units:
Bandpasser II Bandpass Filters
With the antennas you have, there's no reason to automatically select antennas.
You might want to get a 6-pak or an 8-pak to handle the antenna switching.
EightPak
There is no connection to computer software for this stuff under "normal" operating conditions.
The band decoder gets the frequency information from the Icom's CIV jack and automatically selects the correct bandpass filter and this happens independently of the logging software as it is driven from the radio itself so there is no software compatibility to be concerned with and it works when there is no computer connected. The logging software therefore works independently of the above equipment.
Если кто разбирается в Array Solutions, все же лучше установить 6 pack для полной автоматизации процесса ?
Они (дилер+Array Solutions) исходят их этой схемы:
http://www.arraysolutions.com/Produc...on_Diagram.JPG
