08.01.2013, 18:59 #1
Info UR5EQF sw e Yaesu FT-920
Hello, recently I installed the software ur5eqf with the yaesu ft 920 ...
I was able to set it with the com port (in my case is 3), but I can not set the cat, the cat septum or better if I do not go out in tx or not the audio. So I have to lock the cat and run it manually .. Also can directly transmit AFSK and FSK, notwithstanding the command behind the tx ... Wonder if possibly there is any connection that uses the same setup ...
Yaesu FT920 sw: ur5eqf
FTDI FT232R chip interface iw9gtd
thanks John
08.01.2013, 19:17 #2Silent Key
- 07.01.2010
- Рязань
- 3,407
- 2344
- 2349
You want to work digital modes? For using UR5EQF program, and connectedness with her problems, Council wrote to its creator, Vladimir, or www.ur5eqf.com
Sorry, my english is not perfect, the more ItalianСтанислав.
08.01.2013, 19:33 #3Very High Power
- 12.08.2006
- Рязань
- 2,629
- 882
- 290
Отпишитесь что в параметрах COM порта для YAESU надо устанавливать 2 стоповых бита. Может поэтому CAT и не работает. Надеюсь Omni-Rig установлен правильно и его параметры идентичны COM порту.
Извините но мой русский не так уж и хорош, а что говорить об английском
73! Владимир (RC2SC)
09.01.2013, 17:41 #4Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,497
- 2569
- 7703
You have to set values of STOP bits in Omni-Rig interface window like the same in COM port settings in windows. It may happen that CAt is not working at your end with FT-920.
