работает граббер RA9CUA. http://ra9cua.nm.ru/
видно RA3YO, RU6LA, UA4WPF.
Сверху вниз RA3YO QRB 1050 km, RA6LA QRB 1000 km, UA4WPF QRB 466 km.
трассу RU6LA видно в Англии! граббер там в 3й моде, антенна- рамка магнитная, метр диаметром. приемник- самодельный сдр.
http://www.wireless.org.uk/grab/
В Германии, http://www.alice-dsl.net/df6nm/grabber/Grabber.htm
RU6LA, так же видно в верхнем, "быстром" окне, с модой близкой к 3й, где отображается весь диапазон.
на 777 в 90й моде там, видно еще RA3YO. больше никто из наших там не замечен.
Под утро увидел UA9CS (на скрине 137776,2)
RSGB сегодня засыпана рапортами для RU6LA:
Hi Ed,
RST 569 at 2200UTC last night.
regards
Uwe/dj8wx/jo43sv
A little weaker over here in NE China last night Ed but still full ID.
Dang Summer thunderstorms..
Laurence BY3A Bohai Bay
Hi Ed
Received again, may 2 around my midnight.
Mistuned by 2 other soundcards but it's there :-)
73 Ko, NL9222, JO22ke
от него есть скрин! видно RA3YO(читаем сверху), RU6LA(RU), EW6GB(трасса внизу):
Strong signal again tonight Ed in France, I looked at your position with
Google Earth.
F4DTL Nicolas JN18FP
RX : Icom IC7400
Ant: active miniwhip
(эта самая мини вип антенна PA0RDT) и рапорт Николаса:
Hello again Ed,
Just closed down at 2300z. The attached image shows your signal from
2050 to 2250z. It was just beginning to fade at the end.
I have dismantled my 136station to make way for more general antenna
work. The receiving arrangement used for 136kHz tonight was an HF
multiband quad and feeder with a loading and matching arrangement. The
receiver is an FT 990.
No other signals seen on the band.
Regards
Peter G3LDO
A very noisy band from local and not so local thunderstorms. RU6LA is around 6600kms from here started off with a lot of spectrum spread in his signal at his dusk, http://www.kl1x.com/1may137.jpg which reduced later.
Thanks for the signals!
Laurence BY3A - KL 1X Bohai Bay China OM89UA
Foggy and Smoggy now
Hi Lf,
capture RU,
Henny pa3cpm
best 73s
Ed, excellent here as well, up to about 6 uV/m! And the QRN has gone down now. Don't be confused by the 0.09 Hz sidebands visible on my grabber, they are only a modulation artifact from the noise blanker acting on the periodic DCF39 telegrams.
Markus, DF6NM
Hello Ed, LF!
I have seen your big signal on 137.778. You started at 19:30 and your signal is very strong, S/N is more than 18dB.
Lubos, OK2BVG, JN88KS
Hello Ed,more than 20 dB SNR here,very strong,good luck for DX reports.
The QRN is low.
RX : Icom IC7400
Ant: Wellbrook LFL 1010
А теперь, Уважаемая Публика, дайте ответ мне на такой вопрос: отчего активность в Европе, на ДВ, всегда гораздо больше, чем в России?
У нас могут только орать с квт-ами на 40м и беседовать на 80м о картошке? и все?
А диапазон мы нормально освоить не_можем?
стыд и позор, сказать по чести....
ведь любой оператор имеющий приличный кв трансивер, принимающий 136/500 КГц и антенну 160-80-40м, и компьютер с Argo или SpectrumLab МОЖЕТ легко быть хотя бы наблюдателем этого диапазона!
в тестовом режиме запущен граббер Сергея, RA4HGN в Самаре:
http://samaraham.ru/content/view/359/206/
Единственный из грабберов европейской России работающий сегодня.
Теоретически, прохождение на ДВ идет на спад. Поэтому многие энтузиасты ДВ "зачехляют" свою аппаратуру до конца августа.
Европейские "маяки" DCF-39 и HGA-22 слышно по прежнему очень громко, что говорит о возможности устойчивой связи на расстоянии порядка 2000 км.
Так же, наступает "антенный" сезон.
Дерзайте! Осень, пик дальнего прохождения на ДВ- не за горами.
по сообщению в Яху-групп Русского ДВ:
27.06.2009 beacon UA4WPF (W _--)DFCW 240 137.77950 20---24 utc
наблюдается в Москве, на антенну диапазона 80м. (1/4 слопер с мачтой 7 метров на крыше высотки)
http://qrss.nm.ru/28jun2009_UA4WPF/136.0_90_00002.jpg
http://qrss.nm.ru/28jun2009_UA4WPF/136.0_120_00002.jpg
актуально принимаемую картинку видно на граббере:
http://qrss.nm.ru/grabber.html
или qrss.nm.ru а там зайти в Grabber.
слабенько трассирует на граббере DF6NM :
Андрей, RN3AGC запустил новую версию своего сайта!
http://rn3agc.msk.ru/
Там описаны ВСЕ его SWL и QSO начиная с самого первого наблюдения в 2006 году.
А так же, краткое, но полное описание его длинноволновой радиостанции!
Теперь ЛЮБОЙ сомневащийся, может убедится лично, что для ДВ не_надо иметь "мачт высотой в 100м и бевериджей по 3 км".
Имея тривиальную антенну типа "веревка-в-40м" на балконе, КАЖДЫЙ(в Москве или окрест, как минимум) может ЕЖЕДНЕВНО проводить связи на ДВ от Зауралья до Великобритании.
