02.09.2015, 21:04 #1Standart Power
- 05.12.2013
- 211
- 77
- 27
07.09.2015, 10:28 #2Big Gun
- 24.09.2011
- 14,676
- 5068
- 5891
Немного информации по новой модели: Specifications are preliminary and may change
SPECIFICATIONS
GENERAL
Type: Amateur HF transceiver
Frequency range: TX: 10-160 m
RX: 0.03-30 MHz
Tuning steps: 10 Hz / 1 KHz
Mode: AM/SSB/CW
Channels/memory management:
Repeater shift/offset: No
Power supply: 13.8 VDC ±15%
Current drain/power consumption: RX: Max 3.5 A
TX: Max 23 A
Antenna impedance/connector: 50 ohms / SO-239
Dimensions (W*H*D): 229*84*217 mm (9*3.3*8.5")
Weight: 4 Kg (8.8 lbs)
Other features: CAT interface
RECEIVER SECTION
Receiver system: Double conversion superheterodyne
1st IF: 67.899 MHz
2nd IF: 24 KHz
Sensitivity: AM (6 KHz, 10 dB S+N/N)
1.8-30 MHz: 2 uV
SSB/CW (2.4 KHz, 10 dB S+N/N)
0.5-30 MHz: 0.25 uV
Selectivity: AM
6 KHz (-6 dB), 20 KHz (-60 dB)
SSB/CW Wide
2 KHz (-6 dB), 4.5 KHz (-60 dB)
CW Narrow
300 Hz (-6 dB), 1.2 KHz (-60 dB)
Image rejection: 80 dB
AF output power/speaker: 10 W at 5% distortion / 4 ohms
External speaker connector: 3.5 mm, 4-16 ohms
TRANSMITTER SECTION
RF output power: AM: Max 25 W (carrier)
SSB/CW: Max 100 W
Modulation system: AM: Low-level (early stage)
SSB: Balanced
Max FM deviation: No FM
Spurious emissions: Less than -50 dB
Microphone impedance/connector: 200 to 10 kohm (600 ohms nominal) / 8-pin
MISCELLANEOUS
Manufactured: Japan, 2015-201x
Additional info:
Related documents:
Modifications:
Options/Accessories:
- -Александр, UA8U (ex. RZ9UI, RA9UGR)
07.09.2015, 10:39 #3High Power
- 06.06.2009
- Тверь
- 42
- 912
- 198
- 79
картинка уж больно на фотошоп смахивает. смущает микрофонный разъем, кнопки какие то кривые и уж больно дизайн смахивает на IC-718.
С таким курсом все равно дешевле 45 стоить вряд ли будет.Последний раз редактировалось RA3ICK; 07.09.2015 в 10:42.
07.09.2015, 14:32 #4
08.09.2015, 21:28 #5Standart Power
- 16.06.2008
- Киев
- 408
- 218
- 651
И тем не менее...
UT4UCM. Михаил
08.09.2015, 23:53 #6Заблокирован
- 07.05.2008
- 78
- 724
- 361
- 1421
09.09.2015, 10:21 #7Very High Power
- 16.05.2003
- Иркутск
- 2,297
- 537
На Alinco, типа там dx-sr8 что-то, похож... Дизайн точно такой же..
09.09.2015, 11:49 #8Покинул форум
- 19.02.2007
- 51
- 3,460
- 2209
- 4770
Как-то морально устаревшим он выглядит...
09.09.2015, 12:00 #9Silent Key
- 13.01.2003
- Жабомишодраківка
- 13,850
- 3918
- 1415
Создалось впечатление, что купили неиспользованные устаревшие коробки у АЛИНКИ и туда чего-то напихали. Одни ПЧ чего стоят: 68МГц и 24КГц. А кнопки - вааще отстой. Как на вьетнамском калькуляторе.
А сзади, мелким шрифтом, это инструкция пользователя???
-73- Игорь
10.09.2015, 23:15 #10Standart Power
- 05.12.2013
- 211
- 77
- 27
3Спасибо
