09.09.2008, 00:31 #1
- 04.08.2006
- Москва, Россия
- 71
- 390
- 27
- 25
SatPC32 12.8
SatPC32 12.8 for European Users
Программа показывающая местоположение орбитальных спутников, время пролета над вами, высоту спутника над землей, угол элевации (высоту над горизонтом), автоматически оповещающую вас звуковым сигналом о радиовидимости спутника, частоты борт-земля (downlink) и земля-борт (uplink) и прочую информацию.
The programs SatPC32.Exe (in the following: SatPC) and Wisat32.Exe (in the following: Wisat) calculate the tracks of earth orbiting satellites. The calculations are based on the SGP4/SDP4 model, the results therefore are highly accurate.Both programs are included in the SatPC32 program package. SatPC displays the audibility-areas of one or several selected satellites within a world-map and shows the results in text-lines below the map. Wisat represents the satellite positions in real-time in list-form. Both programs update their calculations continuously in steps of one second. The differences between SatPC and Wisat result from the absence of the graphic output in Wisat.
SatPC and Wisat steer the antennas and radio frequencies (CAT) for Doppler correction. Both programs allow multitasking with programs that provide data transfer with satellites like Wisp32. SatPC32 and Wisat32 then will take over the antenna- and frequency-control. The automatic switching on a satellite works synchronized with the data-program.
Официальный сайт | Homepage - http://www.dk1tb.de/downloadeng.htm
Size/Размер: 30,92 МБ73! Юрий, RX3AOE
