v1.32
- some minor changes in decoding algorithms,
- important change in path configuration: now you can freely define packet paths as 6-symbol names + 0-15 SSID. Older
firmware versions limited it to New-N paradigm paths,
- removed RF and IS checkboxes in beacon, weather and telemetry packets configuration. These checkboxes were redundant and
only took precious space in configuration memory. Now you should set RF rate and/or IS rate to a value of 0 to disable
beacon,
- IF YOU IMPORT YOUR CONFIGURATION FROM OLDER FIRMWARE VERSIONS PLEASE MAKE SURE TO CHECK IMPORTED SETTINGS BECAUSE
PACKET PATHS WILL NOT BE IMPORTED BECAUSE OF PATH FORMAT CHANGE,
- added temperature/humidity sensor false reading check for Davis weather station.
- added consecutive packets send burst mode option (in Radio Tab), when there is more than one packet in TX fifo, they are
sent one after another with only start/end flag between them (and not full preamble, quiet time, etc.). That's a standard
feature of most APRS devices, not implemented in my units earlier. Difference will be visible for telemetry parameter
packets, which were sent separately before,
- added first telemetry data packet delay after power-up (in Telemetry reports Tab). This gives time to gather enough
data before sending it to RF or IS (useful for 1h window stats or 10 min window stats),
- added telemetry params, data, and weather packets send command in telnet.
