Страница 4 из 5 ПерваяПервая 12345 ПоследняяПоследняя
Показано с 46 по 60 из 61
Тема: WX: три в одном
  1. #46
    High Power Аватар для RN3DLL
    12.07.2010
    Балашиха, Московская обл.
    856
    429
    320
    v1.32
    - some minor changes in decoding algorithms,
    - important change in path configuration: now you can freely define packet paths as 6-symbol names + 0-15 SSID. Older
    firmware versions limited it to New-N paradigm paths,
    - removed RF and IS checkboxes in beacon, weather and telemetry packets configuration. These checkboxes were redundant and
    only took precious space in configuration memory. Now you should set RF rate and/or IS rate to a value of 0 to disable
    beacon,
    - IF YOU IMPORT YOUR CONFIGURATION FROM OLDER FIRMWARE VERSIONS PLEASE MAKE SURE TO CHECK IMPORTED SETTINGS BECAUSE
    PACKET PATHS WILL NOT BE IMPORTED BECAUSE OF PATH FORMAT CHANGE,
    - added temperature/humidity sensor false reading check for Davis weather station.
    - added consecutive packets send burst mode option (in Radio Tab), when there is more than one packet in TX fifo, they are
    sent one after another with only start/end flag between them (and not full preamble, quiet time, etc.). That's a standard
    feature of most APRS devices, not implemented in my units earlier. Difference will be visible for telemetry parameter
    packets, which were sent separately before,
    - added first telemetry data packet delay after power-up (in Telemetry reports Tab). This gives time to gather enough
    data before sending it to RF or IS (useful for 1h window stats or 10 min window stats),
    - added telemetry params, data, and weather packets send command in telnet.
  2. #47
    12.07.2010
    856
    429
    320
    Обещают к марту WX3in1 Dual :-) двухдиапазонный
  3. #48
    Low Power Аватар для UB9JBL
    16.02.2012
    Ханты-Мансийск
    50
    77
    7
    8
    Подскажите по настройкам WX3in1 Plus 2.0 , три дня не могу запустить в связке с GM-300. метео нет.
  4. #49
    16.02.2012
    Ханты-Мансийск
    50
    77
    7
    8
    Все, запустил.
  5. #50
    16.02.2012
    Ханты-Мансийск
    50
    77
    7
    8
    В Интернет не выходит...
  6. #51
    12.07.2010
    856
    429
    320
    DNS укажите 8.8.8.8
    Метеостанция подключена?
  7. #52
    16.02.2012
    Ханты-Мансийск
    50
    77
    7
    8
    Цитата Сообщение от RN3DLL Посмотреть сообщение
    DNS укажите 8.8.8.8
    Нет, метеостанция отсутствует - пока не до жиру, да и ЖЭУ летом собирается на доме ставить двухскатную крышу(сейчас ровная как блин). Думаю ближе к осени будет видно, куда 3-ю мачту ставить для метеостанции.
    А на 5 рисунке APRS IS Пассворд свой придумывать? При переводе инструкции указано, что его надо получить при регистрации ...чего то...
  8. #53
    12.07.2010
    856
    429
    320
    Тогда метео и не должно быть :-)
  9. #54
    16.02.2012
    Ханты-Мансийск
    50
    77
    7
    8
    не выходит WX3in1 Plus 2.0 в интернет.. надо "сливать" и "завязывать" с этим делом
  10. #55
    Low Power
    28.03.2011
    Истра
    46
    13
    13
    Коллеги всем привет! Я наконец то купил и настроил wx3in1mini. Теперь в Истре будет шлюз APRS!!! Правда всего 5 Вт.
    Но так и не смог понять как менять иконку гейта. Домик тоже ничего, но сам факт, что не могу докопаться просто бесит!!!
    Помогите плиз ткните носом где копать...
  11. #56
    Low Power
    28.03.2011
    Истра
    46
    13
    13
    Все спасибо разобрался сам! Как говориться прочитайте инструкцию если ничего не работает!
    Теперь буду с уровнями играться..и прочими тонкими настройками.
  12. #57
  13. #58
    16.02.2012
    Ханты-Мансийск
    50
    77
    7
    8
    Здравствуйте! Скажите, а можно как то WX3in1 Plus 2.0 опросить принудительно о его состоянии? Например: Въезжаю я в зону "видимости" диджика и что бы не ждать , когда он маякнет: да я такой то (UB9JBL-10) на этой зоне покрытия, а отправить ему команду/пакет/сообщение, на которое он ответит, что вот он я, живой здоровый и вот вам температура и питание 13вольт..
  14. #59
    14.03.2011
    Moscow
    117
    27
    19
    Цитата Сообщение от UB9JBL Посмотреть сообщение
    ....как то WX3in1 Plus 2.0 опросить принудительно о его состоянии?
    Для большинства транслирующих узлов APRS предусмотрены команды для тестирования состояния и других нужд.
    Они выполняются через отправку сообщения с командой на позывной.
    Список таких команд не регламентирован жестко и каждый создатель включает в поддержку то, что хочет.
    Наиболее популярные команды можно найти поиском в инете:
    ?APRSP - sends a location beacon.
    ?APRSS - sends the status text.
    ?APRSO - sends your active objects.
    ?APRSD - sends a list of stations that have been heard direct.
    ?APRST (or ?PING?) - sends the route by which the query was received.
    ?APRSH <callsign> - sends information on when <callsign> was last heard.
    ?VER? (not an APRS query, but some APRS software support s it) - sends information on the software version in use
    Думаю, что у WX3in1 Plus 2.0 могут быть и дополнительные команды, надо читать документацию. Проверьте по списку, возможно ответ с нужной инфой придет по одной из этих команд.
  15. #60
    QRPP
    17.08.2017
    49
    Никак не могу победить эту проблему. Может есть идея?
    Купил LaCrosse/Technoline WS-2350 + WX3in1 Plus 2.0
    Зарегистрировался в Weather Underground метеостанция WS-2350 все отправляет на сервер.
    WX3in1 тоже запущен как APRS I-GATE. Прописаны в настройках сервер пароль Weather Underground но погоду не ретранслирует. Я подумал возможно американцы сервера удалили с Weather Underground .
  1. Ответов: 10
    Последнее сообщение: 13.09.2018, 14:39
  2. Смартфон + радиостанция в одном флаконе
    от RN9RQ в разделе Беседка. Для любителей поговорить.
    Ответов: 15
    Последнее сообщение: 08.03.2011, 22:06
  3. KB усилитель 800 вт на одном транзисторе
    от RX3XX в разделе Усилители мощности
    Последнее сообщение: 27.10.2009, 05:15
  4. Телефония и радиовещание в одном ...
    от Totos в разделе Общие вопросы
    Ответов: 9
    Последнее сообщение: 27.10.2007, 18:14
  5. Три звуковухи в одном компе
    от RW3FY в разделе Компьютеры и сети
    Последнее сообщение: 16.09.2005, 20:25
