сегодня начались в добавок проблемы с метео станцией периодически шлет температуру в 999 градусов
Weather History for Weather Station IU041CU018 | Weather Underground
Завтра RN3DLL-10 переводится для теста покрытия на восток на частоту 144. 850 до воскресения по возвращению.
Тест откладывается, оставляю на рабочей частоте
TX delay (ms) 350
Quiet time (ms) 600
Владимир, а в эту ночь я передачу оставил включенной)
APRS PACKET RECEPTION:
RF packet starts detected: 1439
RF packets received (CRC OK): 29
RF corrupted packets received (HEADER ERROR): 688
RF corrupted packets received (CRC ERROR): 617
RF corrupted packets received (END FLAG NOT FOUND): 105
RF decoding efficiency (total): 2.0%
RF decoding efficiency (last hour): 1.8%
RF bytes received: 2070
APRS PACKET TRANSMISSION:
RF beacons sent: 8
RF weather packets sent: 16
RF telemetry PARAM packets sent: 0
RF telemetry DATA packets sent: 0
RF messages gated from APRS-IS: 0
RF 3-rd party packets gated from APRS-IS: 0
RF bytes sent: 2877
APRS DIGIPEATER:
APRS packets repeated: 5
APRS packets dropped: 24
APRS-IS I-GATE:
APRS-IS server reconnects: 1
APRS-IS current server: russia.aprs2.net:14580
APRS-IS current server IP: 194.186.45.251
APRS-IS connection status: authenticated
APRS-IS beacons sent: 0
APRS-IS weather packets sent: 0
APRS-IS telemetry PARAM packets sent: 0
APRS-IS telemetry DATA packets sent: 26
RF packets gated to APRS-IS: 15
OTHER STATS:
WeatherUnderground weather packets sent: 50
Device uptime: 0 days, 4 hours, 13 mins
За последней час что то изменилось!
RF packet starts detected: 922
RF packets received (CRC OK): 804
RF corrupted packets received (HEADER ERROR): 60
RF corrupted packets received (CRC ERROR): 53
RF corrupted packets received (END FLAG NOT FOUND): 5
RF decoding efficiency (total): 87.2%
RF decoding efficiency (last hour): 96.0%
RF bytes received: 87282
RF beacons sent: 3
RF weather packets sent: 7
RF telemetry DATA packets sent: 2
RF bytes sent: 7046
APRS DIGIPEATER:
APRS packets repeated: 55
APRS packets dropped: 749
APRS-IS I-GATE:
APRS-IS server reconnects: 2
APRS-IS weather packets sent: 23
APRS-IS telemetry DATA packets sent: 12
RF packets gated to APRS-IS: 55
OTHER STATS:
WeatherUnderground weather packets sent: 117
Device uptime: 0 days, 1 hours, 57 mins
примерно с 19-45 3-09-2013 по 1-40 4-09-2013 работал не в штатном режиме
DNS 8.8.8.8 недоступен
заменен на рабочий DNS
разработчикам оставил запрос на возможность указания резервного DNS
]из-за частых сбоев DFL-800 замен на DFL-860E
ЗЫ: Видимо из-за парочки конденсаторов
Вложение 105461[ATTACH=CONFIG]105462[/ATTACH
Configuration upload failed. There is something wrong with the backup package.
Заново
Можно подменить заголовок в файле и он принимает, но там не много настроек, поэтому быстро в ручную переконфигурировал.
Model: DFL-860E
Firmware Version: 2.40.01.08-17754
Mar 5 2012
IDP Signatures: 24652 Signatures
Last updated 2013-09-25 18:54:56
Выключил на профилактику
