Показано с 1 по 6 из 6
Тема: TK-270: настройки
    11.11.2011
    29
    3
    TK-270: настройки
    Нужны настройки Kenwood tk-270, перекопал ее всю,но не встает на передачу,таймер выключил,тоже не помогает,сверить бы настройки с рабочей станцией,буду очень благодарен(нужны настройки программирования с руки)
    01.05.2008
    1,010
    236
    92
    Эти пробовали?
    TK370/270 high-band h/t radio instructions
    To place unit in programming mode: With power OFF, hold down the !
    button (upper side button above PTT (Push-To-Talk) key with a square
    molded on it) with left index finger and the DIAL button with left
    thumb. Turn on unit. Hold buttons down until SEL appears on the
    display. Release buttons. Press TA button. CH 1 will appear in
    display. Unit is now in programming mode.
    To program (change) frequencies in any of the 32 channel positions:
    Use the rotary channel selector knob to scroll to the desired channel
    position (CH 1 through CH 32). Press the PTT key on the left side of
    the unit. The channel's receive frequency will be displayed. To
    change the frequency in small increments: use the rotary channel
    selector knob to move up or down.
    To change the frequency in 1 MHz (large) increments, press and hold
    the ! button and use the rotary channel selector knob to scroll up or
    down in 1 MHz increments. The same method is used to alter transmit
    frequencies.
    Programming sequence 'positions' for each channel (controlled by
    pressing the PTT key while in programming mode and on the desired
    channel). Repeated PTT pressing is known as scrolling.
    1st - press of the PTT key - Receive frequency,
    2nd - Receive tone,
    3rd - Transmit frequency, 4th - Transmit tone,
    5th - (off),
    6th - (off),
    7th - Channel in/out of scan list (Add or dEL),
    8th - (off),
    9th - (off),
    10th - Transmit power (H) = high.
    Tones - sub-audible tones are used to eliminate the reception of
    undesired signals or to allow access to specific repeater sites
    (tones 1 through 8, listed on channel card). Displayed numbers are
    the tone frequency, in Hz (cycles per second).
    To program/modify tones: while tone status is displayed (by scrolling
    to position 2 for receive tone or 4 for transmit tone) in the
    programming sequence, either rotate the channel selector knob until
    the desired tone is displayed or use the LO key to turn the tone
    function OFF or enable the programming of the tone function (display
    the tone) from OFF. Note: The display of 023 is not a valid tone and
    should be scrolled past and not be used.
    To leave programming mode, use the PTT key to scroll until CH 1
    through CH 32 or OFF is displayed. Turn radio off. Unit is ready to
    be used when it is turned on again.
    Non-Programming mode Functions
    To add or delete a channel from the scan list: scroll to the desired
    channel (using the rotary channel knob). Press and hold the lower
    side button (below the ! button) and press the SCN button. Release
    the buttons. A small "A" displayed above the channel number indicates
    that the channel is in (added) to the scan list.
    Squelch adjustment: To increase the squelch level (to eliminate
    interference) or lower the squelch level (to receive weak
    transmissions), first ensure that the .scan mode is off. Press and
    hold down the lower side button (below the ! button) and then press
    the LO button. Release the side button. Unit is now in squelch
    adjustment mode (with SqL displayed). Squelch level is from 0
    (unsquelched) to 9 (full squelch). 4 to 6 is normal range. Use rotary
    channel selector knob to scroll to desired setting. Pressing the LO
    key will exit the squelch adjustment mode.
    To enter the 'car-to-car' (direct/talk-around/non-repeater) mode,
    press the TA button. tA (and the channel number) will be displayed.
    To exit, press the TA button again.
    To illuminate the display window: press the ! button. Press the
    button again to turn the lamp off.
    Low Power
    14.05.2008
    99
    6
    14
    Если у Вас действительно TK-270
    Если транковая то с руки не программируеться
    11.11.2011
    29
    3
    в настройки с руки залазию нормально,в тестовом режиме передача работает,только вот не далеко берёт.вот и хотел проверить что у меня не так после сброса настроек,а то мне прислали походу с кривой прошивой или что-то сам не то делаю
    01.05.2008
    1,010
    236
    92
    Слил дамп с кенвуда о котором идёт речь. с одной частотой 468.825 MHz
    Перед залитием этого свою слить не забыть!!!!
    11.11.2011
    29
    3
    Спасибо,но у меня 2 метровая)))попробую сравнить с этими настройками,только каналы на другую частоту надо настроить
    Добавлено через 58 минут
    а есть у кого под рукой такой аппарат,попробую скинуть все в заводские и по пунктам настроить
  1. Настройки FT-817 для 'цифры'
    от RD3AMP в разделе FT-817
    Ответов: 23
    Последнее сообщение: 24.01.2015, 19:44
  2. SpectraLab для настройки УПЧ
    от UA9SUW в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 19:28
  3. Настройки Kenwood tk-270
    от UH3TAP в разделе SOS
    Последнее сообщение: 19.11.2011, 22:15
  4. Настройки браузера IE 7
    от sashaP в разделе Программное обеспечение
    Последнее сообщение: 20.12.2007, 18:53
  5. Настройки для RTTY
    от N1WQ в разделе RTTY
    Последнее сообщение: 21.04.2007, 23:08
