20.11.2011, 13:04 #1QRP
- 11.11.2011
- 29
TK-270: настройки
Нужны настройки Kenwood tk-270, перекопал ее всю,но не встает на передачу,таймер выключил,тоже не помогает,сверить бы настройки с рабочей станцией,буду очень благодарен(нужны настройки программирования с руки)
UH3TAP
20.11.2011, 13:19 #2Very High Power
- 01.05.2008
- 1,012
- 237
- 92
Эти пробовали?
TK370/270 high-band h/t radio instructions
To place unit in programming mode: With power OFF, hold down the !
button (upper side button above PTT (Push-To-Talk) key with a square
molded on it) with left index finger and the DIAL button with left
thumb. Turn on unit. Hold buttons down until SEL appears on the
display. Release buttons. Press TA button. CH 1 will appear in
display. Unit is now in programming mode.
To program (change) frequencies in any of the 32 channel positions:
Use the rotary channel selector knob to scroll to the desired channel
position (CH 1 through CH 32). Press the PTT key on the left side of
the unit. The channel's receive frequency will be displayed. To
change the frequency in small increments: use the rotary channel
selector knob to move up or down.
To change the frequency in 1 MHz (large) increments, press and hold
the ! button and use the rotary channel selector knob to scroll up or
down in 1 MHz increments. The same method is used to alter transmit
frequencies.
Programming sequence 'positions' for each channel (controlled by
pressing the PTT key while in programming mode and on the desired
channel). Repeated PTT pressing is known as scrolling.
1st - press of the PTT key - Receive frequency,
2nd - Receive tone,
3rd - Transmit frequency, 4th - Transmit tone,
5th - (off),
6th - (off),
7th - Channel in/out of scan list (Add or dEL),
8th - (off),
9th - (off),
10th - Transmit power (H) = high.
Tones - sub-audible tones are used to eliminate the reception of
undesired signals or to allow access to specific repeater sites
(tones 1 through 8, listed on channel card). Displayed numbers are
the tone frequency, in Hz (cycles per second).
To program/modify tones: while tone status is displayed (by scrolling
to position 2 for receive tone or 4 for transmit tone) in the
programming sequence, either rotate the channel selector knob until
the desired tone is displayed or use the LO key to turn the tone
function OFF or enable the programming of the tone function (display
the tone) from OFF. Note: The display of 023 is not a valid tone and
should be scrolled past and not be used.
To leave programming mode, use the PTT key to scroll until CH 1
through CH 32 or OFF is displayed. Turn radio off. Unit is ready to
be used when it is turned on again.
Non-Programming mode Functions
To add or delete a channel from the scan list: scroll to the desired
channel (using the rotary channel knob). Press and hold the lower
side button (below the ! button) and press the SCN button. Release
the buttons. A small "A" displayed above the channel number indicates
that the channel is in (added) to the scan list.
Squelch adjustment: To increase the squelch level (to eliminate
interference) or lower the squelch level (to receive weak
transmissions), first ensure that the .scan mode is off. Press and
hold down the lower side button (below the ! button) and then press
the LO button. Release the side button. Unit is now in squelch
adjustment mode (with SqL displayed). Squelch level is from 0
(unsquelched) to 9 (full squelch). 4 to 6 is normal range. Use rotary
channel selector knob to scroll to desired setting. Pressing the LO
key will exit the squelch adjustment mode.
To enter the 'car-to-car' (direct/talk-around/non-repeater) mode,
press the TA button. tA (and the channel number) will be displayed.
To exit, press the TA button again.
To illuminate the display window: press the ! button. Press the
button again to turn the lamp off.
20.11.2011, 13:23 #3Low Power
- 14.05.2008
- 69
- 99
- 6
- 14
20.11.2011, 13:39 #4QRP
- 11.11.2011
- 29
в настройки с руки залазию нормально,в тестовом режиме передача работает,только вот не далеко берёт.вот и хотел проверить что у меня не так после сброса настроек,а то мне прислали походу с кривой прошивой или что-то сам не то делаю
UH3TAP
20.11.2011, 14:18 #5Very High Power
- 01.05.2008
- 1,012
- 237
- 92
20.11.2011, 15:21 #6QRP
- 11.11.2011
- 29
Спасибо,но у меня 2 метровая)))попробую сравнить с этими настройками,только каналы на другую частоту надо настроить
Добавлено через 58 минут
а есть у кого под рукой такой аппарат,попробую скинуть все в заводские и по пунктам настроитьПоследний раз редактировалось UH3TAP; 20.11.2011 в 15:21. Причина: Добавлено сообщение
UH3TAP
