25.07.2003, 16:36 #1serg4Гость
Расширенный диапазон на передачу FT-817
У меня к вам вопрос , есть ли возможность расширить диапазон частот на передачу и на приём на FT-817 ?
25.07.2003, 17:31 #2RV3ARГость
20-01-2001 add a comment
Extended TX for FT-817
Remove the front panel
Look down on the back of front panel, with the VFO knob just left of center. Look at the jumper locations just above the VFO knob on the circut board. Solder the first four jumpers and remove the solder at location five.
Reassemble the radio, and reset the cpu by pressing the HOME and the power button.
This will extend the xmit freqs. on HF,VHF and UHF
Another mod.
The following Yeasu FT-817 frequency expansion modification is identical to the version provided by the manufacturer for MARS/CAP application.
Remove any power or battery from the Radio.
Remove the 14 screws holding the top and bottom covers to the radio.
Remove the battery cover latch.
Remove the covers.
Remove the BNC retaining nut.
Carefully lift the 4 plastic tabs holding the front panel to the chassis and slightly move the front panel forward.
Disconnect the ribbon cable that connects the chassis and the front panel.
Remove the jumper at location on Front Panel (J4005)
Press and hold the "VFO/MR" key and the "F" key while turning on the radio.
Reassemble the radio.
Note: The manufacturer states that "this modification opens up transmit coverage for MARS/CAP ONLY!" Other published modifications also have the user bridge the "first four jumpers". The difference between the two modification schemes has not been tested by the author.
Proceed at your own risk.
AA7W
pigeon3@gte.net
73! Юрий.
25.07.2003, 18:35 #3serg4Гость
к сожалению владение английским языком у меня полный ноль ..
Можно сделать перевод ...
28.07.2003, 10:52 #4RV3ARГость
<к сожалению владение английским языком у меня полный ноль ..
Тогда Вы попали не туда.
28.07.2003, 20:00 #5serg4Гость
Большое спасибо за помощь
29.07.2003, 11:25 #6
- 15.04.2002
- mo-83
- 278
- 46
- 16
Попробуйте найти модификацию на www.mods.dk
Но без минимального английского увы, не обойтись
17.12.2003, 16:54 #7
Разбираешь АККУРАТНО аппарат, на мордочке (мордочку разбирать не надо!) около валкодера находишь 9 перемычек, размыкаешь 12345, замыкаешь 6789, делаешь резет, и ты счастливый обладатель трансивера с ТХ 1,8-56, 140-154, 420-470 МГц.
На картинке http://www.mods.dk/mods.php3?radio=yaesu&model=ft-817&selectid=1950#1950
у меня оказалась правильная нумерация перемычек КРАСНАЯ, не факт, что у Вас будет такая же.
А здесь http://www.mods.dk/mods.php3?radio=yaesu&model=ft-817&selectid=2369#2369
можно посмотреть, как перемычками установить диапазоны ТХ для разных стран, чтоб их РЧЦ ибн УГСН было довольно, не к ночи будь помянуто.
Не забудьте собрать аппарат.
Все эти операции Вы проделываете на свой страх и риск без каких-либо последующих претензий. У меня все прошло гладко.
08.08.2010, 20:14 #8
- 08.08.2010
Подтверждаю разблокировку. Только нужно сброс делать не кнопками HOME + PWR, а F + V/M + PWR. Одновременно нажимаете и включаете трансивер. Перемычки 6789 расположены около электролитического конденсатора: mods.radioscanner.ru/files/mod62/picture_picblock_a_1.jpg . Дополнительная информация: mods.radioscanner.ru/yaesu/mod62/
Последний раз редактировалось KT608B; 08.08.2010 в 20:34.
25.12.2010, 18:23 #9
- 04.10.2010
- 6
Скажите пожалуйста, можно расширить диапазон до 174 мегагерц?
Николай (US4MBN)
30.01.2012, 14:11 #10
- 27.01.2012
- 51
- 15
подскажите ребята как открать на передачу в авиа диапазоне?
30.01.2012, 14:32 #11
- 26.07.2009
- 3,317
- 291
- 121
