Показано с 1 по 11 из 11
Like Tree1Спасибо
  • 1 Размещено RV3AR
Тема: Расширенный диапазон на передачу FT-817
    serg4
    Гость
    У меня к вам вопрос , есть ли возможность расширить диапазон частот на передачу и на приём на FT-817 ?
    RV3AR
    Гость
    20-01-2001 add a comment
    Extended TX for FT-817
    Remove the front panel
    Look down on the back of front panel, with the VFO knob just left of center. Look at the jumper locations just above the VFO knob on the circut board. Solder the first four jumpers and remove the solder at location five.
    Reassemble the radio, and reset the cpu by pressing the HOME and the power button.
    This will extend the xmit freqs. on HF,VHF and UHF
    Another mod.
    The following Yeasu FT-817 frequency expansion modification is identical to the version provided by the manufacturer for MARS/CAP application.
    Remove any power or battery from the Radio.
    Remove the 14 screws holding the top and bottom covers to the radio.
    Remove the battery cover latch.
    Remove the covers.
    Remove the BNC retaining nut.
    Carefully lift the 4 plastic tabs holding the front panel to the chassis and slightly move the front panel forward.
    Disconnect the ribbon cable that connects the chassis and the front panel.
    Remove the jumper at location on Front Panel (J4005)
    Press and hold the "VFO/MR" key and the "F" key while turning on the radio.
    Reassemble the radio.
    Note: The manufacturer states that "this modification opens up transmit coverage for MARS/CAP ONLY!" Other published modifications also have the user bridge the "first four jumpers". The difference between the two modification schemes has not been tested by the author.
    Proceed at your own risk.
    AA7W
    pigeon3@gte.net
    73! Юрий.
    15.04.2002
    mo-83
    278
    47
    16
    Попробуйте найти модификацию на www.mods.dk
    Но без минимального английского увы, не обойтись
    Без позывного Аватар для Phantom
    10.07.2003
    Желтая Гора
    204
    Разбираешь АККУРАТНО аппарат, на мордочке (мордочку разбирать не надо!) около валкодера находишь 9 перемычек, размыкаешь 12345, замыкаешь 6789, делаешь резет, и ты счастливый обладатель трансивера с ТХ 1,8-56, 140-154, 420-470 МГц.
    На картинке http://www.mods.dk/mods.php3?radio=yaesu&model=ft-817&selectid=1950#1950
    у меня оказалась правильная нумерация перемычек КРАСНАЯ, не факт, что у Вас будет такая же.
    А здесь http://www.mods.dk/mods.php3?radio=yaesu&model=ft-817&selectid=2369#2369
    можно посмотреть, как перемычками установить диапазоны ТХ для разных стран, чтоб их РЧЦ ибн УГСН было довольно, не к ночи будь помянуто.
    Не забудьте собрать аппарат.
    Все эти операции Вы проделываете на свой страх и риск без каких-либо последующих претензий. У меня все прошло гладко.
    08.08.2010
    Подтверждаю разблокировку. Только нужно сброс делать не кнопками HOME + PWR, а F + V/M + PWR. Одновременно нажимаете и включаете трансивер. Перемычки 6789 расположены около электролитического конденсатора: mods.radioscanner.ru/files/mod62/picture_picblock_a_1.jpg . Дополнительная информация: mods.radioscanner.ru/yaesu/mod62/
    QRPP
    04.10.2010
    6
    Скажите пожалуйста, можно расширить диапазон до 174 мегагерц?
    Low Power
    27.01.2012
    59
    15
    подскажите ребята как открать на передачу в авиа диапазоне?
    26.07.2009
    3,317
    291
    121
    Никак.
  1. Р-160 не работает на передачу...
    от UR0IQ в разделе КВ: Военная аппаратура
    Последнее сообщение: 20.05.2007, 00:44
  2. Как раскрыть на передачу FT-920 ?
    от RU4LG в разделе FT-920
    Последнее сообщение: 09.11.2006, 10:45
  3. Разблокировка на передачу IC-735
    от EW1LN в разделе IC-735
    Ответов: 11
    Последнее сообщение: 29.10.2006, 15:56
  4. GP-300 не работает на передачу
    от UA9M в разделе УКВ: MOTOROLA
    Ответов: 12
    Последнее сообщение: 21.10.2006, 23:23
  5. IC-718. Работа на передачу
    от UA3GBQ в разделе IC-718
    Последнее сообщение: 19.10.2004, 12:05
