Страница 1 из 4 1234 ПоследняяПоследняя
Показано с 1 по 15 из 48
    18.10.2010
    76
    14
    FT-857, 897 и автоматические тюнеры
    Кто нибудь пробовал стыковать FT-857, 897 с внешними автоматическими тюнерами других производителей Icom AH-4, Alinco EDX-2, WAT-500 и т.д.
    High Power Аватар для UU3JC
    22.02.2007
    Симферополь, Крым
    516
    90
    27
    Из ныневыпускающихся тюнеров от LDG
    AT-897Plus заточен под FT-897
    * Microprocessor controlled
    * 2000 fast memories arranged by frequency
    * Switched L tuning network
    * Mounts on the side of the Yaesu FT-897 with four M3-0.5x10 screws (included)
    * Dual function tune control button
    * Continuous coverage 1.8 to 54 MHz
    * Power rating HF: 0.1 to 100 Watts
    * Latching Relays
    * CAT control at 4800 baud with extra CAT Port
    * Tuning time: 1 to 7 seconds, 4 average
    * Antenna impedance: 6 to 800 Ohms (Approximately up to 10:1 SWR, 3:1 on 6M)
    * Tunes nearly any coax fed antenna. Use optional Balun for long wires.
    * Power requirements: 11 to 14 volts DC @ 300 milliamps during tune
    * Operating voltage supplied via the CAT Port (cable supplied with tuner)
    * Enclosure sizes: 11.5D x 3.25H x 1.5W (measured in inches)
    * Weight: 2 pounds
    YT-100 для FT-857.
    * RF Power: 1 to 100 watts SSB, CW and digital modes.
    * Latching relays for ultra low power consumption
    * Built-in CAT interface for FT-100(D), 857(D) and 897(D) radios.* Powered from Yaesu radio over CAT port.
    * CAT thru port for computer control of radio. 4800 baud.
    * 2000 memories sorted by frequency.
    * 1.8 to 54 MHz coverage (continuous coverage for MARS)
    * Tunes 4 to 800 ohms. (16 to 150 on 6M)
    * SO-239 in and out connections for dipoles, verticals, beams, G5RV, OCF, Cobra, ect.
    * Dimensions: 7.0”L, 7.0”W, 2.0”H. Weight: 20 ounces
    * Includes 1 foot CAT interface cable and 1 foot coax jumper.
    15.01.2003
    Novokuibyshevsk
    1,084
    134
    47
    FT-857D + LDG Z-100.
    Постоянно в экспедициях таскаю с собой. Z-100 настраивает всё в РАЗУМНЫХ пределах. Всегда размещаю его около антенны.
    18.10.2010
    76
    14
    Спасибо за ответы. У меня есть LDG Z-100 и я его использую, и еще есть WAT-500 для кенвуда, у него больший предел согласований и он герметичный, вот его я хотел бы стыковать с FT-857.
    13.01.2003
    Жабомишодраківка
    13,850
    3918
    1415
    YAESU FC 20 = VSWR до 1:7
    18.10.2010
    76
    14
    А как управляете тюнером?
    13.01.2003
    Жабомишодраківка
    13,850
    3918
    1415
    Через соответствующий хвост .
    Low Power
    17.02.2009
    Темрюк
    3
    17
    Имею автоматический тюнер MFJ-993 B, прекрасно работает со всеми трансиверами. через соответствующий кабель управляется, как FT 857. IC 7200. TS 430. Одним словом прекрасный тюнер. рекомендую!!!
    19.01.2011
    OM-24
    981
    367
    361
    Какой тюнер предпочесть для FT-857 из: YT-100, Z-100 Plus, Z-11 ProII? И почему?
    24.04.2008
    2,393
    234
    132
    Тот который удовлетворяет Ваши требования.
    И почему?
    Потому что удовлетворяет.
    Они по смыслу/качеству/надежности.... все одинаковы. Но чем то, да отличаются.
    Просто выбирать надо под конкретные задачи. А есть еще 200 и 600. А вдруг усилитель купите?
    А может Вам лучше 897? Автомат с САТ. Вы опишите чего хотите. А то писать про их отличия долго... Тогда бы и посоветовать было б проще.
    19.01.2011
    OM-24
    981
    367
    361
    Вот уже 3 дня как есть 857 .
    Тюнер нужен в основном для выездов, для работы на "компромиссные" антенны. Ну и дома, если без РА. Если с РА, предполагаю согласовывать трансивер с РА с помощью самодельного ручного тюнера.
    Ну вот, как-то так, если кратко...
  12. #12
    24.04.2008
    2,393
    234
    132
    http://www.cheapham.com/products/LDG-Z%252d11ProII.html
    http://www.cheapham.com/products/LDG-YT%252d100.html
    http://www.cheapham.com/products/LDG-Z%252d100Plus.html
    или
    http://www.ldgelectronics.com/c/252/products/1/49/3
    http://www.ldgelectronics.com/c/252/products/1/9/1
    http://www.ldgelectronics.com/c/252/products/1/52/1
    Кратко и образно.
    z100-базовая модель. один вход, один выход. питание. управление. одна кнопка. нажали, трансивер включил несущую, тюнер настроился. или нажали тангенту, тюнер подстроится. или найдет в памяти...
    z11- тоже самое, но можете в ручную менять емкость и индуктивность наблюдая за ксв метром трансивера. есть возможность записать в память свои настройки. и выбора мин ксв при котором прекращается авто настройка...
    y100- питается от сат. работает через сат. или кнопкой. полный автомат(в смысле нет возможности вмешаться. а автоматы они все), ничего делать не надо...
    но. отличаются они только кнопками. база одна. весь выбор, в том что именно нужно. не хотите автомат... хотите полностью ручной 100про... и тд...
    Добавлено через 1 минуту
    позравлям!
    Вы полазьте по ссылкам... выберите под то как им пользоваться хотите...
    они отличаются как копейка, двойка, треха, шестерка...пятерка...семерка...
    Последний раз редактировалось RN3AHT/WWW; 25.04.2011 в 23:58. Причина: Добавлено сообщение
    Игорь (RN3AHT)
    Разрешение имеется.
  13. #13
    15.01.2003
    Novokuibyshevsk
    1,084
    134
    47
    Значит тюнер нужно ставить около антенны.
    У меня Z-100 запихан в пластиковую коробку и имеет соответствующие выводы(управление на DB-9, PL-259 in и out, клемники для out).
    Есть к нему два куска 50 ом кабеля по 14 метров и два кабеля управления по 14 метров. Возможно последовательное включение , общая длинна от трансивера до тюнера 28 метров или раздельное включение для разных антенных систем.
    Постарайтесь обходится без тюнеров около трансивера, лучше настроить антенную систему.
    Кстати,это и к походным вариантам относится.
  14. #14
    19.01.2011
    OM-24
    981
    367
    361
    То, что выполняемые функции почти одинаковы, это понятно. Интересует - в чем различие по управлению. В Z-100 и Z-11 имеется выход 3,5мм Radio. Если я правильно понимаю, он соединяется с разъемом АСС трансивера. При нажатии на кнопку Tune на тюнере, с тюнера по этому кабельку закорачивается на землю контакт разъема АСС "Запрос передачи", трансивер начинает передавать несущую, тюнер настраивается. А выходная мощность при этом уменьшается автоматически или ее уменьшает трансивер, как следствие большого КСВ? Это один вопрос.
    y100- работает через сат.
    Вот здесь можно поподробнее? Механизм хотелось бы понять... У YT-100 на заднице 3 разъема - Computer, Radio и Remote. Тоже хотелось бы поподробнее узнать о назначении каждого, что вкусного у этого тюнера появляется дополнительно по отношению к двум предыдущим.
    А в каких случаях возле трансивера?
    Согласен, только не всегда возможность есть...
  15. #15
    Администратор Аватар для RW3AH
    08.02.2006
    3,571
    5920
    1400
    Приветствую!
    У меня работает с недавнего времени LDG "AT-200pro" в связке с FT-857d
    Этот LDG просто незаменимая и замечательная штуковина. Одно НО - релюхи сильно трещат при настройке.
  1. Антенные тюнеры. Какой выбрать?
    от RK3YXH в разделе Линии питания и механика
    Ответов: 20
    Последнее сообщение: 27.11.2008, 16:28
  2. Ответов: 3
    Последнее сообщение: 05.06.2002, 12:53
